BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Bootmod3 boost gauge config question
      10-17-2019, 03:38 PM   #1
Cpatel
Drives: N26 328i
Hello.
I just got a bootmod3 wifi agent. I want to view turbo boost but I can't configure the channel in a way to show me boost pressure properly. I've tried a few configurations and I see really weird numbers or the gauge stays at 0.
What options do I need to change (and which gauge do I need) in order to see boost in PSI the same way it was shown on JB4.
TY!
      10-17-2019, 04:20 PM   #2
andino
Drives: F31 328i xdrive
Use the map sensor for boost
2016 328ix F31 | Bilstein B14 PSS | MPBBK | ER Catted Downpipe | REMUS Sport Exhaust | VRSF Chargepipe | G-Plus FMIC | BM3 Stage 2 | K&N Drop In Filter | KC Front Strut Bar | VAC LCA Monoball | BMS OCC | Millway Camber Plates | KMAC FCA Monoball | KC RSB
      10-17-2019, 05:56 PM   #3
Cpatel
Drives: N26 328i
How is that done?
      10-18-2019, 06:47 AM   #4
MTWO
Drives: M2
Originally Posted by Cpatel View Post
Hello.
TY!
Click on reset settings in the about screen
      10-18-2019, 01:32 PM   #5
Cpatel
Drives: N26 328i
I figured it out. This app is so slow in terms of refresh rate, I tried many different refresh rates. And it constantly goes out.
Going to return the WiFi adapter. The JB4 app was so much smoother.
Anyone have any gauge monitoring app recommendations?
      10-19-2019, 07:09 AM   #6
MTWO
Drives: M2
Thatís odd. Mine flies. What phone are you using? Iím on iPhone XS.
      10-19-2019, 07:33 AM   #7
Green33
Drives: BMW F30 328ix N26
My agent is good as well. Real-time data on the dashboard using older iphone. Maybe try reinstalling the app on your phone and updating/reinstalling the wifi agent software. Also maybe you have a bad odb cable.
To see boost just go to the dashboard and click on the + at the bottom of the screen. Type boost and youíll have 3 options. Pre-throttle shows your boost.
      10-19-2019, 06:51 PM   #8
Cpatel
Drives: N26 328i
Are you using the official obd2 agent? I bought a homemade one off eBay
iPhone 7.
      10-19-2019, 07:45 PM   #9
Green33
I built mine myself using the DIY thread. Iíd recommend taking the microSD card out and rebuild the software for the Wi-Fi agent. You can follow along here.
https://f30.bimmerpost.com/forums/sh....php?t=1484555
Iím using iphone7 as well
If that doesnít work it might be cuz the seller used a raspberry pi 3B+ which according to the thread doesnít work. If you open the case and take a look to see which board is used that could save you some time.
Cpatel16.00
