10-19-2019, 01:32 AM | #1 |
Rep 151
Upgraded b58 fmic?
So i remember when i purchased my car there was no word on the horizon about an fmic. Then the mysterious csf one came out and i decided to wait for reviews. None came out. There is one video of anthony zepeda installing it but nothing aside from that.
I get cherry red turbos 2-4 times a week and i love tracking the car so i dont want to blow my stock turbo. Any ideas on these two products? Ps list any others you can find.
I bought this car like 2 years ago cuz of the supra hype. Someday itll be a 900 awhp beast. Maybe?
10-19-2019, 02:05 AM | #2 | |
Rep 500
sspade2460.00 |
10-19-2019, 07:57 AM | #3 |
Cheapskate
4442
Rep 4,992
an intercooler or radiator upgrade won't save your turbo or stop it from glowing red. If you're concerned about EGTs then you need a richer afr on your tune.
Everybody runs into some sort of issue/modification with the radiators i've seen. and it's not needed for most of us. spend the money on other upgrades. |
buran0.00 |
10-19-2019, 02:48 PM | #4 | |
Rep 1,219
Yes tuned, well it runs way richer then stock, so nothing to worry about u less your running 23-24psi
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
10-19-2019, 02:53 PM | #5 | ||
Rep 151
10-19-2019, 04:06 PM | #6 | |
Rep 151
10-20-2019, 08:25 AM | #8 |
Cheapskate
4442
Rep 4,992
wheels
tires brake pads charge pipe injection pure turbo custom tune meth etc etc etc. literally anything else. what tune runs 25 psi? |
10-20-2019, 06:24 PM | #9 |
Rep 585
MHD maps have options for standard, Sport Cooling Mode For Intercooler & Sport / Race Cooling Mode For Coolant.
"Optimizes the cooling for better air intake temperature on the B58 water to air intercooler. Reduces the coolant temperature for better performance, lower oil temperature and less engine stress." I can confirm that using the middle "Sport" setting coolant and oil temps are lower than stock. Stock coolant and oil temps were typically 110 degrees C, now 95 - 97 degrees for coolant and about 104 for oil. IAT would also benefit. The track setting would be a good option for track days.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph Last edited by OzBMR; 10-20-2019 at 09:27 PM.. |
johnung4510.50 |
10-21-2019, 06:37 AM | #10 |
Rep 128
I don't see how lowering temps of the main coolant circuit, which is used for the engine and oil, will benefit IAT temps.
IAT is governed by charge air cooler, which sits on a separate coolant circuit (the secondary coolant circuit). Unless the MHD cooling map actually affects BOTH main and secondary coolant circuits, that particular text appears to be a bit misleading. |
10-21-2019, 06:52 AM | #11 | |
Rep 151
10-21-2019, 07:26 AM | #12 | |
Rep 1,597
10-21-2019, 07:27 AM | #13 |
Rep 1,597
10-21-2019, 07:41 AM | #14 |
Rep 28
10-21-2019, 07:59 AM | #15 | |
Rep 128
They both are run by separate water pumps. Only the secondary coolant circuit has an electric water pump. The main coolant circuit is mechanical water pump only. You can't just "increase input voltage" on a mechanical water pump. I have no issue with how it can be done. I'm only trying to make sure that people are aware changing one coolant circuit will have nil impact on the other. Last edited by CrushJelly; 10-21-2019 at 08:05 AM.. |
10-21-2019, 08:07 AM | #16 | |
Rep 5,377
10-21-2019, 08:23 AM | #17 | |
Rep 1,597
10-21-2019, 10:21 AM | #18 | ||
Cheapskate
4442
Rep 4,992
10-21-2019, 02:25 PM | #19 | |
Rep 128
If MHD is controlling the electric water pump, then it should have no impact on then engine/oil coolant circuit. Yet it does, as users report lower engine water temps and lower oil temps. So it has to also be controlling the Heat Management Module for the main coolant circuit. My presumption is that MHD does control the Heat Management Model, but there has never been any actual proof from logs or otherwise that it's also controlling the electric water pump for the secondary coolant circuit. Hence I very much doubt it is actually doing so - and the claim that it lowers IATs is currently unfounded. Happy to be proven wrong - with evidence of IAT logs or logs of the electric water pump running higher rpm than normal. |
10-21-2019, 08:20 PM | #20 | |
Rep 1,597
10-22-2019, 08:19 PM | #21 |
Rep 585
I asked MHD about the changes made for the separate cooling circuit for the charge cooler and this is a summary of their response.
With stock settings the electric pump only activates when there is 20 degrees C or more of difference between ambient and IAT. They have lowered the minimum value so the pump starts circulating coolant earlier. They do not alter the pump voltage or max values. It should therefore provide some benefit up to the point where IAT and ambient have 20 degree C differential, after that no difference. This is a bit like the intercooler water spray that Mitsubishi had for the EVO IX's. With stock maps it would never activate as the settings required coolant temps to be over 100 degrees C before it would spray and temps in those cars never went over 94.
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph Last edited by OzBMR; 10-22-2019 at 11:18 PM.. |
BMWILUVU809.00 |
10-22-2019, 08:21 PM | #22 | |
Rep 151
