BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Anyone on Upgraded Trans Mounts?
      10-20-2019, 08:33 PM   #1
Tchao
Boost Addict
Tchao's Avatar
Drives: E30, E82, F30
Obviously for us 3 pedal folks...
Anyone running poly (or solid) trans mounts on stock engine mounts?
Im worried if I dont upgrade the engine mounts also the stiffer trans mounts will fail sooner. I know this was an E30 problem but making things fully poly on a rust box E30 made more sense than this nicer DD now.
Also how was the NVH afterwards?
I want to upgrade because Im starting to miss gear gates when the car weight transitions in autocross/canyon runs etc.
N55 PWG | Three Pedal Club | E30TU
      10-20-2019, 08:47 PM   #2
VAF30
VAF30's Avatar
Drives: 14' F30 335i
I'm actually 8AT .. but was just looking for the same .. found some solid metal from the UK I think but went with OEM to replace.. I had Delrin solid in the diff and changed them out for super pro .. as the NVH was pretty noticeable.. so I would imagine solid on the tranny would be loud too.. though I ran solid metal back in the day on my M3 E36.. Let us know what you find ..!
2014 F30 N55 EWG - BigBoost 3.3 Turbo Kit - N52 Exhaust Cam - BPC MILV - ER FBO - AFE Momentum CAI - XDI-35 - MPE w Carbon tips - MHD Custom Tune by efi_bob at Stage Fabrication - 19" Apex Arc 8 w 255/35 square - Bilstien B14 Coil-overs - GC Camber plates - Solid Sub-frame bushings - Powerflex Diff Bushings - BMW L/S Diff - XHP Trans tune -600whp 511wtq on pump 93 with Meth PI
      10-21-2019, 07:40 AM   #3
JaredG_F30
JaredG_F30's Avatar
1028
Drives: 2014 335i, M-Sport, Manual
I would say go with the 70A durometer poly mounts. These worked well on my E36 M3. I think 80A or solid would just be way too harsh for anything other than a dedicated track car.
https://www.ecstuning.com/b-ecs-part...02705ecs02a~a/
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      10-21-2019, 09:45 AM   #4
Tchao
Boost Addict
Tchao's Avatar
Those are the exact ones I was eyeing.
Jared, did you upgrade motor mounts too on your E36 or was it only trans? If so how long did the trans mount last?
      10-21-2019, 10:14 AM   #5
JaredG_F30
JaredG_F30's Avatar
1028
Just trans mounts as the stock mounts were pretty worn and there were all these horror stories of money shifts due to tranny moving durning high G maneuvers. They lasted until I wrecked the car (RIP Emmy), about a yr. If you go with 70A poly mounts please post a review here. This is something I would consider doing as my plan for this car is to be a track rat after I pick up another DD.
      10-21-2019, 11:48 AM   #6
romemedrano
Drives: BMW F30
Thumbs up
I just bought CONDOR speed shop trans mount/ solids since 1x I had issue on saturday on upshift on the new shifter I got. Ill post pics when they come in etc and installed.
