08-06-2018, 09:10 AM | #1 |
Rep 395
F30 Homelink Mirror Retrofit
I was thinking about retrofitting a homelink mirror (the one with the 3 buttons) to my 2017 330e (EU spec) so I can set it up for my gates which I know are compatible with the homelink
Something like this: https://www.ebay.ie/itm/BMW-2012-201...gAAOSwUwlbINsb My question is do I need to code anything or is it plug and play? Homelink option seems to be a US spec thing so I wonder is there also a homelink module elsewhere in the car or is everything needed for that to work in the mirror itself? |
08-06-2018, 09:23 AM | #2 | |
Rep 3,020
I retrofitted one myself. My car had auto dim only, I retrofitted a new mirror and gained the compass and homelink successfully.
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
08-06-2018, 10:27 AM | #3 |
Rep 395
I did find a few threads alright but now I wonder if the frequencies are ok, for example if I get a mirror from Ebay US will it work with my 433hz gate remote control? Apparently different countries homelink mirrors run on different frequencies.
08-06-2018, 10:28 AM | #4 | |
Rep 3,020
I got mine locally from a buddy so it was a straightforward update.
2016 BMW F80 ZCP
08-06-2018, 10:39 AM | #5 | |
Rep 395
For the installation, is it straightforward enough? No need to mess with the rain/light sensor etc? |
08-06-2018, 10:42 AM | #6 | ||
Rep 3,020
Shroud comes off and then the mirror pops off. There a bunch of DIY on here and YouTube. Harness for power is plug and play. The pinning is what will determine what has power and what doesn't.
2016 BMW F80 ZCP
08-06-2018, 02:10 PM | #7 |
Rep 395
Still unsure if just getting any F30 mirror with auto dip is enough or will it mess with my other options since according to http://bmwfans.info/parts-catalog/F3...r_mirror#pos_2 it looks like if you have driving assistant, road sign detection, high beam assistant there is a particular mirror to get?
Any idea what homelink version is in those mirrors? Apparently I need version 7 at least for my gate system. Last edited by sd_dracula; 08-06-2018 at 02:23 PM.. |
08-09-2018, 02:09 PM | #8 |
Rep 395
Do you need to disconnect the battery when taking out the old mirror in order to not get xmas lights on the dash or no need?
08-09-2018, 02:36 PM | #9 | |
Rep 3,020
2016 BMW F80 ZCP
08-22-2018, 02:15 PM | #10 |
Rep 395
So I got the mirror and installed it, all checks out functionality wise, the compass thing is cool.
But unable to program the buttons. Followed this and also official homelink videos but no luck I have a set of gates Mhouse WU2 running at 433.92 MHz for the transmitters and according to the compatibility list they are supported by homelink (see attached) any tips? Maybe I'm doing this wrong. Looks like the gates do have rolling codes but not sure about this magical "learn button", it does have one but pressing that and then the homelink button doesn't do much. Unless these US mirrors work on different frequencies and don't accept 433.92 mhz Last edited by sd_dracula; 08-22-2018 at 03:43 PM.. |
08-23-2018, 01:12 PM | #11 |
Rep 395
Well for anyone else in Europe trying to get on the homelink wagon by getting a US mirror don't bother, homelink has confirmed the frequencies are lame:
I am afraid, that if your Homelink system is a US version, it hence uses radio frequencies which are different from the EU versions. Some of these frequencies are reserved for special purposes such as police radio, emergency services, public authorities, etc. Therefore, it is not permitted to use the US frequencies in Europe and the other way round, making it impossible to operate an EU garage door opener with a US Homelink System |
10-30-2018, 03:54 PM | #12 |
Rep 24
HI
i just recently retrofired my homelink mirror i bought from ebay 2016 BMW 328 320 335 FITS 13-17 REAR VIEW MIRROR 9345387 my car is F31 2014 328d wagon homelink ad auto dim work fine but now my rain sensor and light sensor doesnt work anymore i find out the compass display you can change the number 1-12 (by pressing and holding the little button under) is that the mode to change? can anyone who retrofit give some input much appreciate Thanks |
10-31-2018, 10:22 AM | #13 |
Rep 614
Drives: 2016 F36 M Sport
I've been wanting to do this as well. Do you know if it would be a direct swap if my mirror doesn't even have the auto dim? I wasn't sure if the car was already set up for those features even with a basic mirror.
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
11-25-2018, 05:25 PM | #14 |
Rep 134
Just plugging in the homelink mirror cause an error in the FEM module. The FEM need to be coded to add the homeling/compass mirror properly.
2016 435i xdrive Gran Coupé
2011 E82 1M Custom Frozen Brilliant White 2006 E60 M5 Alpine white SMG DELETE 6MT swap. Gone : 135i 2008 | Gone : 2008 535i Touring| |
12-08-2018, 05:54 PM | #15 | |
Rep 276
D90D25 interior rear-view mirror: oncorrect variant fitted and D90D2D garage door opener: unexpected LIN-slave What do i need to code? Cause i cant find anything about it. |
12-20-2018, 06:40 AM | #16 | |
Rep 43
12-21-2018, 01:46 PM | #18 |
Rep 276
04-28-2022, 07:22 AM | #21 |
Rep 18
Hi.
I solved it by simply removing the control unit check on the mirror. In practice, now the control unit no longer controls which mirror I use, and no longer shows these 2 annoying errors. Obviously the mirror works in everything. Here's how to "fix": BDC or FEM 3120 PfInternalMirror PF_INMI_LIN_VAR -> set to nicht_aktiv PF_UGDO_LIN_VAR -> set to nicht_aktiv UGDO -> set to aktiv Let me know! |
04-28-2022, 08:05 AM | #22 | |
Rep 1,953
Drives: 2013 328i xDrive
