09-10-2018, 02:55 AM | #1 |
Rep 1,693
Someone needs to hurry up and release a smaller Stage 2 turbo.
N55s have been around for nearly 9 years now and there are still so few mild turbo upgrade options with both compressor and turbine upgraded. We only have the choice of "Stage 1" turbos with a far from ideal huge compressor to turbine size ratio then next step up is "Stage 2" monsters with absolutely monstrous compressors and big clipped turbines aimed for huge power.
We need something to fill the void between these options. There are good 9-blade Garrett-style 57mm inducer / 50.6mm exducer turbine wheels available for the N55 turbo now - A perfect option for a milder "Stage 2" upgrade turbo when paired with the right sized compressor. Someone needs to offer this. I don't think people know what they're missing in terms of insane response and capable of making great power on low boost. I've been looking out for something for years. |
09-10-2018, 05:02 AM | #2 |
Rep 2,357
Stage2.......monstrous......
Stage2 is a fine stage1 in my book. There has to be some solid gains from changing a turbo.
(A Dane in China) |
SeanWRT3179.00 |
09-10-2018, 05:57 AM | #3 | |
Rep 1,693
A little smaller wheeled version of existing Stage 2 turbos with full unclipped Garrett-style turbines would be absolute response monsters and still max stock HPFP. Existing Stage 2 turbos do lose that initial snappiness in D mode in Auto cars at low RPM. It doesn't have to be like that. Such a turbo would have very "solid gains" for PWG owners and smaller gains for EWG owners (similar to gains from Stock PWG to Stage 1). |
09-10-2018, 10:27 AM | #4 | |
Rep 2,357
(A Dane in China) |
09-10-2018, 12:56 PM | #6 |
Rep 775
Dinan is a 'tween size.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
09-10-2018, 01:09 PM | #7 | |
Rep 504
TTE460 is what you need, it has gains over stock ewg turbo and will max out stock hpfp.
09-10-2018, 03:39 PM | #8 |
Rep 1,693
09-10-2018, 03:40 PM | #9 |
Rep 1,693
09-10-2018, 03:41 PM | #10 |
Rep 1,693
09-10-2018, 06:22 PM | #12 | |
Rep 1,693
It's a big heavy car with an automatic transmission. You definitely lose the snappy responsive throttle feeling that the stock car has in D mode with the PS2. It's not about the RPM at which it reaches full spool. It's about transient response, how quickly it responds to sudden throttle changes. |
09-10-2018, 06:27 PM | #13 | |
Rep 2,639
If you legit want full spool at 2k, prepare to fork out money for broken parts as low end power/torque will break things. |
Insane435476.50 |
09-10-2018, 07:01 PM | #14 | |
Rep 1,693
As I said earlier, it's not about RPM threshold, it's about the turbo's transient response. Low RPM boost threshold is good too of course. 13psi by ~2300 would be great. Plenty of people do a lot more than that with stock turbos. With safe timing, that is certainly not damaging to anything. It's when people try and get 20psi as early as possible with bulk timing that breaks things. |
enjoythemusic364.00 |
09-10-2018, 08:28 PM | #15 | |
Rep 2,639
Insane435476.50 |
09-10-2018, 08:43 PM | #16 | |
Rep 1,693
There is a perfect mid-way point in there for me hence why I don't want to keep the tiny stock PWG turbo but I don't want a PS2 either. Enlarged turbine is just as important as enlarged compressor though. I'm not interested in a "Stage 1" compressor upgrade only. |
akgambino271.50 |
09-11-2018, 05:19 AM | #17 |
Rep 504
what’s the drawbacks of clipped turbine? later spool up? anyway i’ve seen good dyno results using this turbo (460+ crank hp). about ps2 - fully agree, it’s a bit too much considering how weak stock fuel system is. along with ps2 you should upgrade hpfp also, and together it’s quite a lot of $.. I’m not big fan of tons of extra wiring under the hood, meth controllers, meth tanks etc.. good if you can have power on pump gas or sometimes mix a bit of e85 for keeping octane high. just a metter of taste
09-11-2018, 06:31 AM | #18 | |
Rep 1,693
09-13-2018, 05:34 AM | #19 |
Rep 2,357
Define "full spool" makes a bit of a difference whether we talk 10-15 or 20psi + from what rpm in what gear...maybe an electric car is what you want. Full spool at all rpm
(A Dane in China) |
09-13-2018, 06:09 AM | #20 | |
Rep 1,693
I simply want the right turbo for my needs. A ~5mm bigger turbine and a ~3mm bigger than EWG compressor (~8mm bigger than PWG) would be pretty spot on. There is a very big jump between stock turbine and PS2 and an in between option would be really great for a lot of people's needs. I don't really get what's hard to understand about that. I'm pretty close to just buying a used EWG turbo and MEVD172G and considering it close enough. Not ideal but better than what I have and with EWG, it's easier to tune and I can use a MPPK tune as a starting point. Last edited by bradsm87; 09-13-2018 at 06:23 AM.. |
09-13-2018, 08:23 AM | #21 | |
Rep 2,357
(A Dane in China) |
09-13-2018, 03:47 PM | #22 |
Rep 1,693
It's way more to do with the wheel sizing and design than the bearing type. If ball bearing made that much difference, more cars would come from the factory with BB turbos.
