10-22-2019, 08:01 PM | #23 |
Rep 6
When the HPFP is doing that big dip below target, the AFR is quite rich (less than 11:1) and when the pressure get close to target is leans out a bit. Maybe the air/fuel mixture isn't getting burned and its dumping the raw mixture on the o2 causing it to measure rich?
I am currently having the same issue on my car with 3 different OTS maps in bootmod3 but stock map runs fine. Could you try logging your spark dwell time? I've noticed a big correlation between coil dwell times less than .5msec and a bad missfire/stutter. Stock dwell times rarely ever go below .5msec. |
10-22-2019, 08:58 PM | #24 | |
Rep 7,606
10-23-2019, 10:09 AM | #25 | |
Rep 4,140
The problem I think, points towards a weak pump though. |
10-23-2019, 08:14 PM | #26 |
Rep 6
That actually makes perfect sense. I had never looked up how they worked before. So it it looks like its actually consuming more of the oxygen through the burn process. Still weird for it to be rich with the HPFP dipping like that.
10-23-2019, 08:42 PM | #27 | |
Rep 7,606
OP - You seem to be missing a lot of parameters. I think you need to do more logs with, at a minimum, lambda target afr added in. Then we can see for sure if for some reason the target AFR dips, causing it to go rich and the HPFP crash, or if it just goes rich without a target AFR drop. |
10-23-2019, 08:54 PM | #28 | |
Rep 4,140
10-24-2019, 01:12 PM | #29 |
Modder of everything I own
147
Rep 491
I can log it this weekend, out of town until Fri. I'll post a couple of logs for comparison.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
10-25-2019, 06:34 PM | #31 | |
Rep 461
Love to see logs for this. |
10-27-2019, 09:14 PM | #32 |
147
Rep 491
Here's 1 log, had to find a good stretch of road but here's a wot gear 3/4/5
https://datazap.me/u/zole2112/102719...log=0&data=1-4
10-27-2019, 09:29 PM | #33 |
Rep 1
Fuel Pump issues
I'm currently running Stage 2+E20 mix from MHD Tuning and it's been great but as of recent i've been getting fuel cuts, and as time passes they get more significant, i've adjusted my mix, re flashed and I do see the fuel rail pressure drop on WOT usually 3rd, 4th and 5th gear are the terrible, I live in CA so I only have 91, I ONLY use Shell 91 V power with the (new formula) i've heard from multiple people shell is better than chevron... anyways I attempted to remove the filter from my HPFP for more flow, i've heard of many N54 owners running like this for years w/ all fuel filters taken out except one LPFP filter, and 1 owner with NONE and has had no issues for years and is showing improved flow, I was looking just to remove mine but I was unsuccessful I seen the filter on the "inlet" side of the HPFP but it looks like it's maybe glued in... i was able to take a clean pick tool and poke a hole in the side of the "mesh" of the fuel filter hopefully this will improve some flow...
10-28-2019, 01:14 PM | #34 | |
Rep 1,105
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
10-28-2019, 01:48 PM | #35 | ||
Rep 7,606
10-29-2019, 08:37 PM | #36 |
147
Rep 491
I don't think so, always been like that with no real variation from that. If there was a boost leak it would be more variable than that. Had my logs checked multiple times from Terry, always said they looked good with no issues.
10-29-2019, 09:16 PM | #37 | |
Rep 7,606
It may not be a boost leak, but is there another reason you are pretty far from target? I dont see a way to check actual load vs. target load in your log to compare those |
10-30-2019, 11:46 AM | #38 | |
Rep 1,105
JB4 was a great solution before full flashing became available but to each their own. But being off target by 1psi or so is considered common but yours seems pretty off. Also, yes would be great to see the target load and actual load to compare more data points.
10-30-2019, 12:22 PM | #40 | |
147
Rep 491
10-30-2019, 12:24 PM | #41 |
147
Rep 491
You are absolutely right, sorry about the thread hijack. Anyway, I don't think you will exceed the stock HPFP capability with a stock turbo unless you went too high on ethanol content.
10-30-2019, 03:01 PM | #42 | ||
Rep 7,606
It would be helpful to just turn on nearly all parameters (I think i only unchecked a few) and then do some more logs. High load, high RPM, and low ambient/IAT would probably be the situation where the HPFP crashes. |
10-31-2019, 03:14 PM | #43 |
Rep 6
If you flash your stock tune, then flash the custom tune, does it still do it? I ask because when you flash tunes, it resets you LTFT and I've noticed that temporarily fixes my issue. Reseting adaptations does not reset my LTFT(at least not in bootmod3).
But like you my tune ran well for a few days (when my LTFT is 1.00) then a few days later it is 1.15 or above, runs really rich and stumbles at high throttle. My logs also show a HPFP dip below target when this occurs. Stock flash has no problem. I think MHD logs it as a percentage though. So your LTFT would be something like +20% instead of 1.20 I'm starting to suspect it's heat related. When EGTs get really high, the DME will richen up the mixture to try and keep things cool. There are no EGT sensors on our motors so its actually a calculated value but mine gets to around 1950F pre turbo and 1450F post turbo. I wonder if your logs show anything similar |
03-01-2021, 10:46 AM | #44 |
Rep 130
I have the same first 3 codes as you. I get the Drivetrain light but she starts up right after I restart her. Hasn’t stalled on me in 5 months. I notice it happens around 1/4 tank of gas. I was thinking the lpfp then replacing the hpfp. What were your symptoms ?
