06-26-2019, 09:42 AM | #1 |
Rep 146
Weird dots on windshield distracting at night any idea how to remove?
My f36 GC has these weird splotches on the windshield don't know how they happened and I used meguiars window cleaner didn't do anything any idea how I can remove them?
06-26-2019, 10:27 AM | #4 |
Rep 146
No don't think so there not really indented or anything not really sure what they could be, also those in the pics aren't all of them, I waxed my windshield do you think it could be because of that? And if so any strong windshield clears that would get rid of it
06-26-2019, 10:39 AM | #6 |
Rep 1,802
Clean well, and then follow up with RainX original windshield treatment. It makes water bead off, but an unexpected, yet nice, effect is that it dissolves spots and haze off, so you get no glare at night.
06-26-2019, 02:30 PM | #7 |
Rep 4,876
Hard to see from the pictures, but over time (where I live) the glass gets sand blasted. I end up with a lot of those little "stars" in the glass.
Yours does it look larger, so not convinced it's the same issue. |
MmmmmM22588.50 |
06-26-2019, 05:26 PM | #9 |
Rep 146
So I took another look if I look closely enough they almost look like very small bubbles that have been popped
I'll take a better picture when it's a bit dark from the outside |
06-26-2019, 05:30 PM | #10 |
Rep 1,908
Look like tree sap, try hot water or clay bar if no luck you could try this...
https://www.meguiars.co.uk/guide-meg...glass-sealant/
Happy Motoring
Evdok |
06-26-2019, 05:50 PM | #12 |
Rep 1,827
My windshield is crazy pitted, might be the same issue. Nothing you can really do about it other than replace the windshield. If it's something ON the glass, then clay bar as others suggested, or you can try polishing with compound, or in extreme cases, try scraping with a brand new razor blade. I'd still lubricate the blade and apply VERY light pressure.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
06-26-2019, 05:59 PM | #13 |
Rep 2,499
The OEM F30 windshields are crap and notoriously soft and susceptible to rock chips. Mine has a ton of tiny chips that usually aren't too noticeable. Maybe that's what you're seeing.
06-26-2019, 06:16 PM | #14 | |
Just Copacetic!
177
Rep 616
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite '19 230i MSptPkg AlpWhite |
06-26-2019, 08:21 PM | #16 | |
Rep 146
Edit: if it were rock chips do they charge for it at end of lease does anyone know? Thanks |
06-27-2019, 07:57 AM | #18 |
Rep 55
It looks/sounds like some sort of tree sap to me. My secret weapon on tree sap is denatured alcohol. Soak the tip of a wadded up paper towel and hold it on the spot to let it dissolve the sap and it'll wipe right off. You can get it in the paint thinner aisle of almost any big box or hardware store. It's safe on paint too.
Current...2014 328i xDrive M-Sport
Past.......2008 Saab 9-3 Turbo-X, 2004 Saab 9-5 Aero, 1994 Saab 900 Turbo Commemorative Edition, 2001 Saab 9-5 SE V6 |
06-27-2019, 08:32 AM | #19 |
Rep 136
if its not chipped, id suggest buying some plastic razor blades (safer than traditional). Use some clay lube or QD to ease the abrasion. you can also use some heat from a hair dryer to loosen up the material.
06-27-2019, 11:31 AM | #20 |
Rep 20
Looks exactly like my windshield. I'd have to guess its rock chips because I've clayed the glass and applied P&S Bead Maker to it and the spots are still there.
06-27-2019, 11:42 AM | #21 | |
Rep 1,641
If it is not something on the glass, such as a chip or sap, etc., it could be in the glass. On my old e46 330 I had glass that had a defect in the laminating process (if I recall correctly). I had these little bubble like things appear over time. Not sure what caused it and I had to get my windshield replaced. Only time that ever happened, but....perhaps another weird possibility. |
06-27-2019, 01:39 PM | #22 |
Rep 1,509
I use Bar Keepers Friend on windshields. If you are very gentle, it cleans well and won't scratch. DO NOT use other kitchen cleansers, like Comet.
