11-01-2015, 10:36 AM | #23 |
Rep 3,089
Glad it worked for you!!! Now you can hear all the other wonderful rattles and groans the car makes. My old Toyota camera was more quiet!
11-11-2018, 01:49 PM | #24 |
Rep 204
Drives: 2016 428i GC Alpine White
I've also tried and used the loop side of Velcro. That works very well, if you don't have the felt.
2016 428i GC
11-11-2018, 02:36 PM | #25 |
Rep 552
You could also bend the pin rod slightly so it pushes against the collar and is not floating loosely.
11-12-2018, 08:17 AM | #26 |
Rep 878
My drivers door has this annoying rattle. Hold the pin and it goes away but for me it’s random and on some days no rattle. I tried removing the circular surround using a trim removal tool but the damned collar didn’t want to budge.
11-15-2018, 07:17 PM | #27 |
Rep 204
It's a bit nerve wrecking, but it does come out. I used a trim tool on the sides of the collar... put a microfiber rage below the tool just in case. Then pry on left a bit, then on right and should come up. It's keyed, so when putting back it only goes one way.
2016 428i GC
02-25-2020, 05:14 PM | #30 |
Rep 44
You can find it at Wal-Mart or craft stores. And like previous posts said, it takes a lot of pressure to pry out. Don't be scared lol.
02-27-2020, 07:56 AM | #31 |
Rep 87
It's just velcro, you can buy it almost anywhere, including amazon. I did this on my front passenger door right after I got the car. You really don't need very much. I didn't superglue it on either, just the adhesive on the velcro was good enough and I only put about a 1/4" strip on, just enough to keep the pin from rattling.
02-29-2020, 10:05 PM | #32 |
Rep 1,827
I had some leftover adhesive felt (fake alcantara feel) so I wrapped the trim piece. Got rid of the door lock pin rattle.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
sspade2464.50 |
10-27-2020, 08:49 AM | #34 |
Rep 3
Drives: 2017 F80 M3 Comp
Just picked up a M3 with ZCP. I too have the door lock rattle on both passenger and driver side. I asked the dealer to fix, seem to work for a day or two, and came right back. I will try this before going back to the dealer which is 45 mins away. Thanks!
10-27-2020, 08:30 PM | #35 |
Rep 54
I had the same issue and used electrical tape and put them around the door pins and pushed the tape down into the lock pin housing so I didn’t have to remove the pin itself. It really helped tone the rattling down but the rattles didn’t go away completely.
10-29-2020, 02:01 PM | #36 |
Rep 34
He’s right. About a 1”x1” piece of electrical tape worked for me. Just make sure you don’t put to much so the stalk doesn’t get stuck.
BMW 328i | Injen Intake | ER Charge/TIC Pipes | VRSF FMIC and Catless DP | BMS Oil Catch Can | Muffler Delete | Jb4-Map 2, 93oct |
01-12-2022, 10:41 AM | #37 | |
Rep 10
04-05-2023, 07:18 AM | #38 |
Rep 24
Drives: 2016 BMW 320i
Is there a way to remove the head of the lock pin itself? I found some replacements that push on and wanted to give them a try. They are a bigger in diameter so I know it will fix my problem.
