10-25-2020, 05:32 PM | #1 |
Rep 424
Full lock rub only in Sport mode
Went from stock 19" 442m 225/40 - 255/35 to 19" 235/40 -255/35 with ET30 square 8.5j. Stock m suspension rwd not lowered. I'm hearing little rub from from but only when I'm in sport mode. In Comfort full lock no rub? Should I be concerned ?
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
10-25-2020, 06:07 PM | #2 |
Rep 496
If you do use sport mode then you should be concerned.
But from your description, I think if you can find the place of rubbing contact, you may easily be able to bend the metal/plastic a bit to resolve it. |
10-26-2020, 06:24 AM | #3 |
Rep 424
Edit: today I noticed it only rubs if I'm backing up, full lock, and turning right in sport mode. If I go left it doesn't rub. I wonder if it's because the front two tires have a bit different tread wear? They're sottozero3s
I'm gonna try and visualize where it's rubbing I think it should be ok to run this setup for a 4 months
10-26-2020, 08:10 AM | #5 |
Cheapskate
4447
Rep 4,993
Doesn't really make any sense but it's likely that you sitting in the driver's seat is reducing your clearance in the front right wheel well. Either way it should be fine but you can fix it if it's annoying.
10-26-2020, 08:15 AM | #6 |
Rep 424
Maybe because the dampers are stiffer and somehow that contributes to less clearance on full lock? I'll mess around with it today and try to figure out why this is
10-26-2020, 08:16 AM | #7 |
Rep 424
Could be this. I need to turn fulllock and look in the wheel wells to see where it rubs exactly. Weird that it only does it one way.
10-26-2020, 08:44 AM | #8 | |
Rep 849
Drives: BMW 435i
It's a head scratcher for sure...
10-26-2020, 08:58 AM | #10 |
Rep 424
Going from stock 19x8J ET36 to 19x8.5J ET30 the wheels are more flush now so adding a spacer will push them out past 'flush' likely resulting in more rubbing
10-26-2020, 09:04 AM | #11 | ||
Rep 3,873
Only the Adaptive Suspension is affected by the mode (Comfort vs Sport) and even that only changes the stiffness and response, not the height! Stiffer suspension means less bouncing, so less rubbing.... And the OP does not even mention Adaptive Suspension.... It makes no sense to me.
10-27-2020, 10:30 AM | #12 | |||
Rep 424
Originally I thought it was only in sport mode but after looking closely it rubs in comfort mode too so that was a false report on my end. Does the speedo report wrong with downsizing the front sidewall to 35 since OEM is 40?
10-27-2020, 11:47 AM | #14 |
Rep 424
aside from the speedo will there be any issues running 35 profile tires instead of the 40? I know a bunch of people run 35 in front but not sure if thats an x drive thing or what not. For RWD does it make any negative difference except for the speedo and ride quality?
10-27-2020, 12:22 PM | #15 | |
Rep 116
A 35 vs 40 profile in and of itself isn't going to affect much, sidewall and overall diameter is what you need to pay attention to. |
10-27-2020, 01:15 PM | #16 |
Rep 519
How often do you drive around in reverse, at full lock, while only going right?
I would just drive it if it doesn't rub under normal driving conditions...
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
10-27-2020, 01:18 PM | #17 | ||
Rep 424
10-28-2020, 03:38 AM | #19 |
Rep 833
Drives: BMW F36, E36, E93
Since the speedo is "connected" to the rear wheels and the rear wheels didn't change, I can't seen any circumference impact?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required Last edited by BWbimmer; 10-28-2020 at 03:45 AM.. |
10-28-2020, 03:53 AM | #20 |
Rep 116
I believe BMW uses the front wheels for speed
10-28-2020, 04:00 AM | #21 |
Rep 833
So you are saying if you are doing a burnout, then the speedo stays at 0?
Then this must have changed with the F series
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
10-28-2020, 04:59 AM | #22 |
Rep 116
Couldn't find a burnout video, but found one doing a rolling burnout, and the speedo was reading 40mph at the top of 3rd lmao. I guess that's why f series have a specific "dyno mode"
