BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Can I upgrade from 6.5 to 8.8 inch screen
proTUNING Freaks
      07-29-2023, 04:02 AM   #1
Leeg1633
Leeg1633's Avatar
Drives: 2013 BMW f31 330d xdrive
Hi all, I've searched the forum but can't find anything specific. When looking online I'm getting conflicting information. I believe I have CIC set up ( vin decoder information is below ) but online it says CIC should have a cd button where my media button is and I've also read that CIC video cable has 4 pins, mine had 6? Looking at my screen it says BMW L7 mid, there is also a BMW L7 high screen available which is larger, part number 9292248. Question is can I upgrade to this larger screen. I have attached photos below of my current idrive system. The controller originally had the small round dial on it, it is only a large one now as I have stuck it over the top of the small one.
      07-29-2023, 05:29 AM   #2
Leeg1633
Leeg1633's Avatar
I've just checked Bimmercode and I do have the below option for Breites displey
      07-29-2023, 08:22 AM   #3
SkyJawa
SkyJawa's Avatar
3641
Drives: F10 530d
What’s the build date, CIC in the F30 was only up to 11/2012, after that should be NBT. Most likely to be NBT…..
https://integratedautomotive.co.uk/w...ion-do-i-have/
      07-29-2023, 08:28 AM   #4
Leeg1633
Leeg1633's Avatar
On vin decoder my production date is showing as 20.06.2013.
My display has the red outline around the selection which points towards CIC... so confused!
      05-17-2024, 10:43 AM   #5
TurboWeasel
Drives: BMW 330D
For those with LCI cars and the ENTRYNAV HU, I fitted an 8.8" screen today to my 2016 330d.
It was a lot easier than I was expecting!
https://f30.bimmerpost.com/forums/sh...postcount=1135
I fitted the screen in preparation for a Carplay MMI box. No one wants the 6 inch life with Carplay.
danb19792316.50
      05-18-2024, 03:31 AM   #6
YODI
Drives: 2019 F31 320d M Sport
Mines a 2019 with the small nav, I want the bigger screen too so will take a look.
      05-18-2024, 07:34 AM   #7
TurboWeasel
Drives: BMW 330D
Should go in no problem. I paid £140 for the 8.8" screen from ebay, which came out of a 2015 F34. I thought about the 10" screen but apparently some chopping is required in the F3X, which I'm not down for.
All the split screen stuff works as it should and it seems to boot up faster as well, and faster response to the Idrive knob commands, which I didn't expect. I didn't know the screen had that kind of influence over the HU.
Well worth doing as the small screen just looks rubbish with the massive borders. A waste of real estate
YODI143.00
      05-20-2024, 03:05 AM   #8
Wibbles
Coding ECU's remotely
Wibbles's Avatar
456
Drives: M3LR
You need an APIX2 screen for that car, a screen from a 2015 model is not correct.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube
      05-21-2024, 03:19 AM   #9
YODI
Thanks as always, although I don't know what an APIX2 screen even is.
On my 2019 F31 can I just change the screen to the 8.8 and code it? Vin is WBA8H92010A967947
      05-21-2024, 03:37 AM   #10
TurboWeasel
Drives: BMW 330D
Sorry, I overlooked yours is that late. You likely have the Harman or Alpine NBT_EVO HU in your car and APIX2 is the touchscreen I believe.
      05-21-2024, 04:53 AM   #11
Wibbles
Wibbles's Avatar
456
Drives: M3LR
You need PN: 65508709339
YODI143.00
      05-22-2024, 06:34 AM   #12
spikeydoo
Drives: BMW 320i shadow
I fitted a 9339 successfully to a 2019 touring on the previous car
Coded the following
3005 DISPLAY_PIP_CONFIG > CID_DISPLAY_RES = 1280_480
3005 DISPLAY_PIP_CONFIG > CID_DISPLAY_SIZE = 8_8
3001 DISPLAY_VARIANTE = breites_display
3006 NAVIGATION > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
3005 DISPLAY_PIP_CONFIG > CID_TOUCH = aktiv
300B TOUCH_COMMAND > CID_HMI_TOUCH = aktiv
Worked perfectly for mine
YODI143.00
      05-22-2024, 06:37 AM   #13
YODI
Thank you both, Two for sale on ebay, one at £345 and one at £399
Wondering if it's just worth getting an Android one for that money
      05-24-2024, 05:11 AM   #14
TurboWeasel
Drives: BMW 330D
Android MMI box?
      05-25-2024, 02:51 AM   #15
YODI
Android MMI box?
That doesn't solve the small screen issue.
      05-26-2024, 06:09 PM   #16
Boosting35d
Boosting35d's Avatar
Drives: F31 335d
Hey guys, I’ve got a 6inch poverty spec screen in my 17 plate F31, I have no idea if I have Entry nav HU but I’m confident it’s got ID6
Could I buy any widescreen from any F series and do the coding and all work okay?
Would something like this work https://www.ebay.co.uk/itm/305581330...mis&media=COPY
I have BimmerCode but no esys :-(
TIA
      05-26-2024, 09:24 PM   #17
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
TIA
need to check realoem.com to see what part number your vehicle takes..
Post the last 7 of your vin and we can decifer for you..
      05-26-2024, 10:50 PM   #18
Boosting35d
Drives: F31 335d
Hey, thank you! VIN details….A254392
      05-27-2024, 04:49 AM   #19
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
65506844126
65508709338
65508709339
These are your part number choices.. first 2 are obselete now probably find a better deal on them compared to the last one that is the current one.
      05-27-2024, 04:51 AM   #20
Boosting35d
Drives: F31 335d
That’s very kind, thank you! This forum is pretty epic compared to other forums I’ve been on in the past!
      05-27-2024, 04:57 AM   #21
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
Welcome just paying the info back. We were all in same position before noone deserves a 6.5 screen shame on bmw!! Unfortunately that link u posted is a 2248 screen for older 12-14 models so it won’t work you will have to get one the part numbers listed above and there around 3-450$
      05-28-2024, 02:44 AM   #22
TurboWeasel
Drives: BMW 330D
TIA
If your iDrive menu is the list style, it's ID4, if it's icons, it's ID5/6.
Late 2016 early 2017 was a funny period for idrive as BMW did a hybrid thingy with the Magnetti Marelli NBT HU which was EntryNAV spec instead of Evo.
I'm not sure if Bimmercode can do APIX touch screen coding, but you can certainly try it.
If not, folk can remote code it for you, such as Wibbles on here.
