BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F30 JB4 Stage2 Dyno Testing
      04-07-2013, 01:38 PM   #309
Monstr6
Drives: 2013 335i M sport
when wiring the stage 2 the directions say to tap in to the yellow wire and black/blue stripe wire. its showing these wires by the passenger side strut. I only found these wires by the DRiver side strut. After looking further thru threads i seen another post that i may need to tap into Red wire and Blue/red stripe wire near the driver side strut.
Has anyone else have this issue? What is the correct wires to tap into?
My car is 2013 AT 8 with Xdrive.
      04-07-2013, 07:12 PM   #310
GET A GUN
Drives: 2013 335i F30
Originally Posted by tdizzle View Post
That will be a 'noticable' difference. Adding a DP and swapping to Map 2 should feel more dramatic than stock > Map 1 on stage 2.
That's like 100 wtq over map 1.
Make sure your running high octane fuel when running map 2. Don't wanna blow that motor.
2013 335i F30 N55
      04-08-2013, 11:39 AM   #311
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
2014 Audi SQ5  [0.00]
Anyone noticed rougher starts since hooking up stage 2? Almost as if the battery is low and having trouble turning over? Could be completely unrelated to the tune but I have been experiencing this quite often over the last week or two.
      04-08-2013, 01:03 PM   #312
F30form
Drives: '13 Mini Cooper S Hardtop
Sounds like the motor is running more advanced vs stock which can make it harder to start.
      04-08-2013, 07:46 PM   #313
GET A GUN
Not during starting.
It's not the JB4. Have had mine for months and no issues.
2013 335i F30 N55
      04-08-2013, 09:05 PM   #314
TreDirtyFive
Drives: X3 M40i
mine has been flawless as well...from stg 1 to stg 2 with absolutely no issues and the best support to boot.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      04-08-2013, 10:28 PM   #315
RollingLower42
RollingLower42's Avatar
71
Drives: 2012 BMW 335I
Will you really blow your motor if you are on map 2 and on low octane?
      04-08-2013, 10:54 PM   #316
GET A GUN
Yes.
2013 335i F30 N55
      04-09-2013, 01:20 AM   #317
RollingLower42
71
Yes.
Sorry for so many questions, but what is the exact reason why it would?
      04-09-2013, 06:45 AM   #318
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
As long as you have access to 93 octane, you're good.... Seperate user error I've been having - I tend to hold my volume down button on the steering wheel when I turn down my music and it keep switching to Map 0 without me knowing! Frustrating. I now have a yellow sticker on the volume down button so I don't use it, lol
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      04-09-2013, 09:09 AM   #319
tdizzle
Drives: 2017 F80 ZCP
I believe map 2 is used for high octane/e85 mix and/or down pipes. I'm not sure you'd even want to use it with just 93 octane.
      04-09-2013, 09:12 AM   #320
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
I've been running Map 2 with catless downpipe + 93 octane and is has been a wonderful trip from 26mpg to 18mpg but aside from that everything has been running great.
Just need to find out what is causing these rough starts in the morning. Only seems to happen with cold starts.
      04-09-2013, 12:14 PM   #321
RollingLower42
71
I have never seen 93 octane in my area yet..
I have been running map 2, but I use a mixture of 91 with 100 octane.
I also have another gas station that has E85, and when I cant get to the 100 octane station, I fill up mostly with 91 and mix in maybe 4 gallons of E85..
The 100 octane runs best though. Since I am on map 2, I will make sure to fill up with the 100 octane as much as possible.
      04-09-2013, 02:18 PM   #322
TreDirtyFive
Drives: X3 M40i
There is no E85 / autolearning map at this time (which would most likely be map 5) and it is recommended to use map 7 with a 60/40(e85) mix of E85 or race gas...with or without DPs.
      04-09-2013, 04:13 PM   #323
RollingLower42
71
So if I want to stay on map 2, stick with the mixture of 91 and 100 octane, correct? What sort of mixture is best or recommended?
      04-09-2013, 04:17 PM   #324
bonsai
OG 3er
Drives: 2016 F80 M3/2018 F82 M4 Compet
Please excuse the noob question:
What's the ETA on a JB4 Stage2 for my 2012 335i?
      04-09-2013, 04:17 PM   #325
TreDirtyFive
Drives: X3 M40i
Actually, you can do map 2 if you have a DP but "preferably" at least 93 or higher octane as well.
      04-09-2013, 05:07 PM   #326
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
You can purchase a version of it now. It's not a mass production kit but more of a alpha/beta test kit. But it is definitely an upgrade!
      04-10-2013, 06:47 AM   #327
abe12345
Drives: 2013 F30 335i M-Sport Manual
any ETA for JB4 Stage 2 for 2013 f30 335i MT? like for the final version not a beta version?
      04-10-2013, 06:14 PM   #328
Jeff_in_Oviedo
Delivered!
Jeff_in_Oviedo's Avatar
Drives: '13 F30 335 M Sport
Eek, just installed the stage 2, and now I get a drivetrain malfunction, reduced performance. Anybody have any ideas?
Delivered!: 2013 F30 335i M Sport, 8-speed Sport Trans, Estoril Blue/Coral Red, 403M, Premium Pkg, Dynamic Handling Pkg, Driver Assist Pkg, HK Sound, Enhanced BT & USB
      04-10-2013, 06:22 PM   #329
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
Check your plugs. I had one of mine plugged in backwards. It is most certainly just a connection issue I had the same thing.
      04-10-2013, 06:39 PM   #330
Jeff_in_Oviedo
Delivered!
I thought that due to the way the plugs were made, it would be impossible to plug it in backwards. I just double-checked all of my connections. I didn't get a chance to start it again, so not sure yet. If I still get errors, then I will try unplugging all of the harness plugs and "return it to stock", just to make sure I can get back to a good state.
Is the CAN connection only needed for steering wheel control? I did hook it up, but I am curious if this is all it is for so far.
