06-02-2021, 04:38 PM | #1 |
Rep 5
Please help. Too lean and too rich codes
I have a 2013 335 xdrive 166k miles and when the car is warm and I turn it on it shakes and it “gasps for air. During a cold start it doesn’t do it. I get the too lean and too rich code at the same time. I change the maf sensor and that didn’t help: so I have no idea what I could be. Any ideas? Thank you.
06-02-2021, 04:40 PM | #2 |
Rep 7,733
Super vague. We need actual codes, mileage, mods/tune if any, any recent service before the issue started, did it start suddenly one day or get worse over time, datalogs if you are tuned, etc etc. Otherwise we are just guessing.
If we are guessing, and you are getting both rich and lean codes, top of my list would be O2 sensor(s) |
06-02-2021, 04:57 PM | #3 | |
Rep 5
P0172 system to Rich bank 1 And P0440 No mods or tunes that I know off. Any guess? Last edited by Birdmandoom; 06-02-2021 at 05:20 PM.. |
06-03-2021, 01:33 AM | #5 |
Rep 5
06-03-2021, 04:57 AM | #6 |
Rep 842
MAF or o2 sensor would be where i start looking
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
06-03-2021, 01:43 PM | #7 |
Rep 3,221
So no power loss, only happens when warm and it is smooth after it settles? Check the turbo inlet pipe foe the pcv connection. Could be cracked and sucks in air after it is warm.
06-03-2021, 02:41 PM | #8 |
Rep 5
Correct not a huge power loss but maybe a little. And it settles after 15 seconds or if I press the gas it settles as well. But what I don’t get is if it was sucking in air it would keep sucking it in all the time, not just when I turn it on?
06-04-2021, 04:58 AM | #9 |
Rep 656
Small vacuum leaks can be masked with some revs and or extra fuel. Cold start high rpm does both so you won’t see during that time. When warm and your idle is too low you might stumble because the ecu can’t compensate for the extra unmeasured air. Then at higher rpms the car is taking in a larger flow of measured air relative to the tiny vacuum leak. If your code reader has the ability to look for fuel trims a vacuum leak would cause them to be way off.
06-04-2021, 12:45 PM | #10 |
Rep 7,733
I suspect it will be very difficult to diagnose a vacuum leak from fuel trims, even if he could access them, which it sounds like it probably can't given hes not tuned and can't datalog. There always some +/- fuel trims and other factors, ethanol fuel % and learned LTFTs among them, will influence STFTs.
Im also fairly certain the DME doesn't use closed loop fueling at all on cold start. I havent logged a cold startup but on every other platform that's how it is. So, that's probably why you dont have the issue when its cold. You can certainly start with a boost/pressure test and check for a cracked inlet. If you CP is stock that's another obvious thing to check as well. |
06-06-2021, 03:58 PM | #11 | |
Rep 5
09-11-2024, 08:22 AM | #12 | |
Rep 7
09-11-2024, 12:24 PM | #14 |
Rep 7
