02-28-2017, 04:09 PM | #1 |
Rep 855
Budget M Performance Brake Upgrade
I thought with as much conflicting information as there is on this forum I would clear a couple of things up.
The blue, yellow, orange and red calipers are all the same calipers manufactured by Brembo just painted different colors. The standard 335i front brakes (unpainted grey) come with 340mm blank front rotors and the mounting flanges are not long enough to accommodate the larger 370mm rotor as see in the attached photo. It is possible that this could be remedied with an adapter bracket (I am working on a solution). The blue $650 M Sport front brakes come with 370mm blank front rotors. The yellow/orange/red M Performance front brakes come with 370mm dimpled and slotted rotors. So for budget sake if you have a 335i then just decided which color you like and paint or powder coat your calipers that color. Now go to Rock Auto and purchase CENTRIC part # 12634142, 370mm dimpled and slotted front rotor, for $122.79 a piece. Now you have M Performance front brakes. This part is only applicable for people who did not have Brembo 2 piston rear calipers and had the single piston Bosch rear calipers stock: For the rear you will need the Brembo 2 piston rear calipers, which are all the same regardless of color, and 345 mm rear dimpled and slotted rotors. The part numbers for the Brembo 2 piston rear calipers are 34216799461 for the left and 34216799462 for the right. They are $600 a piece new from Tischer BMW but can be had for 50-60% secondhand. For the rear rotors go to Rock Auto and purchase CENTRIC part # 12634147, 345mm dimpled and slotted rear rotor, for $123.79 a piece. Once you have upgraded your front and rear brakes you will want to code the car to the M Performance 370 F/ 345 R specs. So now if you started with grey unpainted Brembo calipers in the front and Bosch single piston calipers in the rear and follow these steps you will have a complete M performance spec brake system for a MAXIMUM of $1700 but it can easily be achieved for under $1000.
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i Last edited by BIMMERGUY91; 03-01-2017 at 08:25 AM.. |
02-28-2017, 04:17 PM | #2 |
Rep 855
Turner Motorsports also gives a very good breakdown of the 5 different brake setups used on the F30 here: https://www.turnermotorsport.com/t-b...ke-Differences
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
the dope steez403.00 |
02-28-2017, 04:47 PM | #3 |
Rep 2,981
Drives: 2013 BMW F30 EBII
This doesn't work on older Gray M sport 4 pot brakes as the mounting point to the car for the brakes are different and can only use 340mm rotors. I think I read somewhere that the 2015 and newer 335 M sport brakes are the same as the M Performance front, but not 100% sure on that. Different mounting radius which allows for the larger rotor.
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread Last edited by roll_the_dice; 02-28-2017 at 04:56 PM.. |
03-01-2017, 08:10 AM | #4 | |
Rep 855
2014 335i M Sport
03-01-2017, 08:18 AM | #5 |
Rep 855
I am going to work on developing a bracket to adapt the standard grey 335i brembos to work with the 370mm rotors. They are literally the same caliper even with the same stampings but the mounting holes are extended on the painted calipers.
Another option is just painting your grey Brembo 335i calipers, installing slotted and dimpled 340mm rotors, installing the 2 piston Brembo rear calipers with 345mm dimpled and slotted rear rotors and coding to the M Performance brakes. It might look a little funny due to the rear rotor being 5mm larger than the front but the only advantage the 370mm front rotor has over the 340mm front rotor is added heat dissipation. The swept area of the pad and the stopping power are identical.
2014 335i M Sport
03-01-2017, 08:22 AM | #6 | |
Rep 356
Also, the 370mm disc will have more stopping force than the 340mm disc due to the fact that the disc is 15mm further away from the centre, creating a larger lever effect. Despite the fact that the pad is the same swept area. Physics 101. x Last edited by Stoo; 03-01-2017 at 08:27 AM.. |
Breno_Piece50.00 |
03-01-2017, 08:22 AM | #7 | |
Rep 2,981
M Sport Brake Upgrade 2 (S2NH/S2NHA) (pads, calipers, rotors): Sometime during 2012-2013 production BMW changed the M Sport Brake option to include larger front and rear rotors, a different front caliper (still 4-piston Brembo), and 2-piston Brembo rear calipers. It was a $650 option but still called "M Sport S2NHA" and could be added to ANY trim package (even a base model). This kit was the same as the M Sport offered in Canada/Europe. The calipers should be blue with an ///M logo but there's a slim chance they could be grey/unfinished with no logo. The front pads were a similar aggressive Euro-spec pad as above. The rotors are blank but the dimpled/slotted rotors from the M Performance brake kits are a direct fit if you want to change their appearance. Specs: Front: Brembo 4-piston calipers, grey or blue; 370mm blank brake rotors Rear: Brembo 2-piston calipers, grey or blue; 345mm blank brake rotors My car came with standard single pot brakes, so I don't know the validity of the statement above. I don't "think" it is true, but someone with the M Sport S2NHA package would have to chime in. I am upgrading now to M performance brakes and had bought some grey calipers used also before I found the M performance kit used...so that is how I was able to take the comparison picture. I also received 340 and 370mm rotors and both are big, but the 370's are huge and slotted/dimpled as the 340's are blank rotors.
My Build Thread |
03-01-2017, 08:26 AM | #8 | |
Rep 855
2014 335i M Sport
03-01-2017, 08:37 AM | #9 | |
Rep 2,981
My Build Thread |
03-01-2017, 08:40 AM | #10 |
Rep 2,981
I just checked and the hat on the 370 is larger than the 340. The 340 rotor hat will fit inside the hat on the 370mm rotor.
My Build Thread |
03-01-2017, 08:53 AM | #11 | |
Rep 855
As far as the calipers being radially mounted I'm pretty sure you are incorrect. The part of the caliper I circled in the pictures above are the lug mounts.
2014 335i M Sport
03-01-2017, 08:56 AM | #12 | |
Rep 855
2014 335i M Sport
03-01-2017, 09:00 AM | #13 | |
Rep 356
As its only 15mm, I think it'd be extremely difficult to achieve. |
03-01-2017, 09:08 AM | #14 |
Rep 855
You may be right. I will have to look and see. Another option would be what roll_the_dice said and adapt a cheap OEM radial mount caliper to work like a Porsche caliper. ECS Tuning did something similar with the E9X
2014 335i M Sport
03-01-2017, 10:51 AM | #15 |
Rep 855
Ok just an update on the brake situation here. I am thinking that the complete front and rear budget solution is going to be the following:
Front: F30 370mm rotors, 03-06 Cayenne "18Z" Brembo 6 piston front calipers and pads. Rear: F30 345 mm rotors, 03-06 Cayenne Brembo 4 piston rear calipers and pads. This is going to give you better heat dissipation, more braking power, better brake modulation and not to mention it will look extremely badass all for right at $1000 using all new or remanufactured parts. No junkyard or used parts. Brake bias should be within a couple % of the stock bias. This is pretty similar to what some companies have done on the E9x chassis.
2014 335i M Sport
03-04-2017, 07:46 AM | #16 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Does looking at M235i or M240i seem funny? Then you really probably have not noticed it as all M135i/235i/240i cars come with front rotor size of 340mm and rear 345mm. If you look at the rotors from the side they look the same diameter, 5mm from 10ft away will hardly be a difference to see it as an eye sore. It looks just fine imo. I purchased my rear yellow calipers (new) for $400 bucks + rear rotors and painted the front. Looks great I may powder coat them this year to a different color.. Here is how it looks from the profile with 2 different rim setups. The only thing I did different is I changed the M Performance logo to a single M letter in the front.
FBO-PS1 and stuff
BIMMERGUY91113.00 |
03-06-2017, 08:50 AM | #17 |
Rep 855
Wow gorgeous car. I didn't realize the M235/M240 came with 340mm front and 345mm rear. Where did you get your calipers for $400 new?
2014 335i M Sport
03-06-2017, 10:13 AM | #18 |
Rep 1,467
This is exactly what I have been waiting for, an alternative to the m performance brakes. I need to decide between adding the 2 pot rears or going with the cayenne brakes.
Where can i get the 2 pot rears only at?
03-06-2017, 11:17 AM | #19 |
Rep 855
You can order them from BMW or just look for some on Ebay or the forums.
2014 335i M Sport
03-06-2017, 11:37 AM | #20 |
Rep 1,467
Do you know the part number? And just to be clear, this would be ordering just the rear portion of the m perf brakes??
03-06-2017, 11:43 AM | #21 |
Rep 855
2014 335i M Sport
03-06-2017, 11:44 AM | #22 |
Rep 855
https://getbmwparts.com/parts/index....&siteid=214672
2014 335i M Sport
