11-07-2017, 08:52 AM | #23 |
Rep 16,054
It's top rated, and it's not just a reader. A reader tells you what error codes mean, the 510 lets you do much more useful tasks, like registering a new battery. One saved trip to a dealer for service will pay for it. It's on sale now for $149 direct from the mfr.
11-07-2017, 09:11 AM | #24 |
Rep 291
http://www.nydailynews.com/news/nati...icle-1.2817657
I wouldn't mess around with this one boys. Installing the correct battery and proper coding could be essential to the continued privilege of living and driving Bimmers! Not worth saving some pennies... |
fe7565552.50 |
11-07-2017, 10:01 AM | #25 |
Rep 38
Get a Carly code reader, about $80. Then you can read codes, register batteries, dink with the Idrive and live happily ever after.
Nedmon
2015 535ix 2016 X3 |
11-07-2017, 12:01 PM | #26 |
Rep 64
I've used AGM batteries for almost a decade on a E60 550 and a E70 X5. My batteries were AGM purchased from, gasp, Walmart and Advanced Auto Parts. Only a handful of companies make batteries anyway. I just swapped the batteries and went on my way. It hasn't shortened the battery life to less than 4 years, so in my dual case experience, it's all good and its not the end of the world if you don't register the battery.
11-07-2017, 12:03 PM | #27 | |
Rep 64
Wrong battery installed and possibly defective battery. There is no correlation between this incident and registering a battery and BMW's. Also, the battery is in the trunk the HVAC doesn't pull air from there. |
11-07-2017, 12:18 PM | #29 | |
Rep 1,329
Seriously, don't be a fearmonger.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
11-07-2017, 01:19 PM | #30 | |
Rep 291
Coded wrong or not at all could cause the alternator to overcharge the battery and a possible failure. |
11-07-2017, 01:38 PM | #31 | |
Rep 5,984
11-07-2017, 02:13 PM | #32 |
Rep 16,054
Incorrect coding wouldn't cause venting of hydrogen sulfide if the battery was AGM, because AGM are sealed under pressure. If the internal pressure does get high enough for the pressure relief valve to open it would vent hydrogen and oxygen. If they vented H2S they wouldn't be allowed to be mounted inside the car. BTW, they're mounted inside the car because engine heat reduces their capacity when mounted under the hood.
One need not be Sherlock Holmes to deduce from the information available that the likely cause was replacing the original AGM battery with a far less expensive flooded lead-acid battery, which can emit H2S if improperly charged, although it's quite rare. The other foot to fall would have been that of a product liability lawyer going after the battery manufacturer and Porsche for a few million, but more likely the fault was that of an indy mechanic who probably wasn't worth chasing for relative pocket change. |
11-08-2017, 08:29 AM | #33 | |
Rep 1,329
My firs E46 battery lasted longer than any battery in a car I have ever owned. It was pushing 8 years when I first had to replace it.
01-27-2018, 06:13 AM | #34 |
Rep 93
Hi all, I have replaced new battery and registred, but battery have different capacity, ogiginal was 90ah 900a, and new one is 95ah 850a , is there any change to change that values in car , by ISTA+ or esys ,
Waiting for your advice guys, cheers |
01-27-2018, 06:42 AM | #35 |
Rep 5,984
It only specifies new flooded cell or AGM code values. Odd that higher AH is lower CA. They should be directly related.
01-27-2018, 06:47 AM | #36 | ||
Rep 5,984
01-27-2018, 08:44 AM | #37 |
Rep 16,054
Li batteries are used already in some M models. They aren't cheap, about $1000 more than AGM. Solid batteries may never make it into cars as starter batteries. The current focus is to develop them for electric cars. If they eventually deliver what's promised of them they may be the final nail in the coffin of the internal combustion engine.
01-27-2018, 08:56 AM | #38 | |
Rep 5,984
01-27-2018, 02:15 PM | #40 |
Rep 5,984
Mine is like 600 CA enough to get up and go. My point is lithium ion batteries aren't that expensive to make as they are in everything these days. A larger one could easily match the power of an AGM and still be smaller and lighter at a lower cost.
01-27-2018, 04:17 PM | #41 |
Rep 16,054
I don't know what CA is. I do know that the only rating that matters is amp/hours. If Li batteries could be made to match the power of an AGM while being smaller and lighter then someone would be making them, getting very rich, as everyone would want them, and by everyone I mean every car manufacturer.
Polo088161605.50 |
01-27-2018, 05:07 PM | #42 | |
Rep 15,858
F80/82. Cost goes up! |
01-28-2018, 12:47 AM | #43 | |
Rep 5,083
01-28-2018, 12:17 PM | #44 | |
2020 Z4 M40i - 2022 M4C Convt
3126
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
If the old battery is weak & AGM if you don't register it the battery will charge at too high a rate. Expect to replace it sooner then if you registered it. Something you can do yourself a few minutes with a phone app. BTW you can get a good 90ah AGM battery for $200 at Autozone. same battery as the SEARS Die Hard. Depending on the store have it installed free.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
