BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 08/2015 retrofit NBT EVO navigation is grayed out
proTUNING Freaks
      09-16-2018, 03:20 AM   #1
kelddamsbo
Drives: BMW F30 LCI 2016
Hi,
I have retrofitted NBT EVO from ENTRYNAV.
The numbers for the new NAV is:
HU : 65126829104
Screen : 65506822626
I have changed FA codes:
606 removed
609, 654 added
Then I set defaults for NBT and KOMBI (VO coding)
Then I changed the VIN in the new HU:
Use E-Sys => Expert Mode => FSC-Extended => WriteDataByIdentifierVIN to write VIN to NBT
I got the no signal on the screen, so I did the following:
CID_APIX_MODE -> apix2 (default apix1)
CID_COLOR_DEPTH -> 24 (default 18)
CID_COM_MODE -> mii (default spi)
Checked the followin, they should be okay:
CID_RESOLUTION -> 1280 x 480
DISPLAY_SIZE_RESOLUTiON = 8.8
DISPLAY_VARIANTE = breites_display and werte =02
Now there is signal on the screen, and everything is okay, but Navigation is grayed out.
I use an emulator.
Could it be a failure in the emulator, or should I removed the emulator and edit the FSC codes.
How do I edit the FSC codes ?
      09-16-2018, 10:01 AM   #2
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Drives: BMW 316d, BMW F40 116d
Why did you change the VIN of the NBT?
Shouldn't the emulator do that for you ... ?
      09-16-2018, 11:36 AM   #3
kelddamsbo
I put back the donor VIN, and not it Works, thanks a lot Ibo4 and yungming
      09-16-2018, 11:37 AM   #4
kelddamsbo
If I want to avoid the emulator, is there any way to edit the FSC to the new VIN, or do I have to buy new FSC codes from BMW ?
      09-17-2018, 06:49 AM   #5
jalami
Drives: f30
you have problems when coding in VO?
my problem is similar to yours.
      09-17-2018, 07:16 AM   #6
kelddamsbo
I actually succeded in VO coding, and all the main features is working now, thanks to Ibo4 and yungming.
The problems left now is:
1) Setting service partner hu nbt evo. How to do ?
2) Steering wheel contacts, right side Telephone and Radio is working, but it dont show up in KOMBI as before the retrofit ?
3) What is App ID 240 and 241 ?
4) How do I activate BMW Apps ?
I need to do the following:
5) Activate option 620 (Voice control) in VO
6) Flash NBT EVO (with old VIN?)
My FSC is now the following:
HU_NBT2[DiagAddress=99(0x63)]
WBA8F32000K700537 (donor VIN)
RootCertStatus not available
SWSigStatus accepted
SWTApplications
AppID 158(0x9E) ; Voice Control (aka voice processing system (SVS)) - S620A - ECE/US (NBT)
UpgradeIndex 1(0x01)
SWTType SWTclassic light
FSCStatus accepted
FSCCertStatus not available
AppID 160(0xA0) ; Navigation Application - S609A ECE/US (NBT)
FSCStatus accepted
AppID 240(0xF0) ; ??????
FSCStatus accepted
AppID 111(0x6F) ; SDARS (Sat Radio) - S655A
FSCStatus not available
AppID 159(0x9F) ; Text-To-Speech (NBT)
FSCStatus accepted
AppID 156(0x9C) ; BMW Apps - S6NRA
AppID 229(0xE5) ; M Lap Timer
AppID 241(0xF1) ; ??????
UpgradeIndex 38(0x26)
SWTType SWTshort
FSCStatus accepted
      09-19-2018, 10:18 AM   #7
kelddamsbo
Is solved by setting:
HU_NBT - BASIS_KOMBI_MMI_LIST - aktiv
HU_NBT - SETTINGS_INFO_DISPLAY - aktiv
Is solved 240 = ID4 Navigation Enabler, and 241 = European Map
I know, I have bought codes (AppID 156(0x9C) ; BMW Apps - S6NRA)
      10-03-2018, 01:28 AM   #8
kelddamsbo
Does anybody know how to set service partner in hu nbt evo ?
      10-06-2018, 07:47 AM   #9
bo0tn1c
Drives: BMW F30 M Sport
If you need an FSC code for your car then I can help.
the NBT EVO FSC Retrofit kit includes the following for your vin:
- Activation of navigation - 00DE
- Activation of voice control - 009E
- BMW APPS - 009C
- Satelite radio ‘ONLY FOR North AMERICA’ - 006F
- Lap -Timer - 00E5
Also, if you need Video in motion or Apple carplay for NBT EVO please PM me.
Installation is done via our Plug-and-Play usb solution and its all activated with in 40 seconds
      10-06-2018, 11:09 AM   #10
kelddamsbo
Thanks, I already have theese codes
      10-07-2018, 01:14 AM   #11
kelddamsbo
Yes the hotline and service call number
      09-19-2019, 02:14 AM   #12
igorko82
Drives: G20, F07, F31, F20, E87
Hello! It is very usefull topic about NBT EVO retrofit. I have the ENTRYNAV HU in may car (pre LCI) and i bought the NBT EVO HU with touch screen 8.8' and touch iDrvie controller. Is this all that i need to make NBT EVO work in my car? Do i need another cable to connect monitor, or ATM, or an emulator?
      05-03-2020, 09:05 AM   #13
relekexe
Drives: BMW <3
- BMW APPS - 009C
- Lap -Timer - 00E5
Hi, can you generate for me fsc file for navi activation? I've evo id4 thanks
      09-23-2020, 07:29 PM   #14
aurelianosperez
Drives: bmw 335
bmw f30 nbt hu to nbt evo retrofit
Hello everyone i have a bmw 335 2015 with a nbt hu with the bibiggest idrive controller with touch but i want to upgrade to nbt evo i already have a nbt evo headunit from a 2017 435 i already install and try to code but i cant to code with esys i have autohex2 and try to program and code but the software show me that these headunit is not compatible with the car i already have 609 in fa order so i need to change something else
or i need an adapter i dont know why i need to change
      09-25-2020, 11:36 AM   #15
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
I suggest going through the coding guides or checking with one of the sponsored vendors for some help as E-sys would be the preferred tool for your NBT EVO retrofit.
If you need some remote support, we can help with that as well.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
