02-16-2020, 10:57 AM | #3081 | |
Rep 2,302
E-Sys 3.27.1 doesn't work anymore correctly with the current psdzdata. You should use older psdzdata if your car didn't get an update lately. Because Launcher Pro 2.8.2 also doesn't work with newer E-Sys versions (except 3.28, but it also needs older psdzdata). Edit: If you only want to VO code something you don't need the Launcher Pro and you can start E-Sys directly from it's folder. Then you can also use a newer E-Sys version and the current psdzdata. |
X1604M57.00 |
02-16-2020, 11:01 AM | #3082 | ||
Rep 152
Drives: 2018, F48 28i
I see so if I open the Esys directly using the newer PSdZ light. is coding process change or same as the launcher? |
02-16-2020, 11:16 AM | #3083 | |
Rep 40,793
E-Sys 3.27.1 supports Latest PSdZData except for CAFD Injection and Programming. FDL Coding and VO Coding works fine. It can be that Calculate FA is also not working as you suggest. I have not tested it myself.
02-16-2020, 11:25 AM | #3084 | ||
Rep 152
So I switched to PSD 62.3 and that's when the loop starts when I calculate FA.. thanks for the replies. mine is 2018 F48, built 2017 November Last edited by X1604M; 02-16-2020 at 11:30 AM.. |
02-16-2020, 11:30 AM | #3085 | |
Rep 2,302
But here you have the psdzdata Lite 4.17.11 which work definitely with E-Sys 3.27.1 https://mega.nz/#!ZGYhCYTY!AG4Mg5RJr...Uj6ELL2MNPBeEw Sometimes it's taking a little bit time to activate the FA, but should not take more than 1 minute. With Launcher you can do FDL coding (button "Code FDL"), which means you can change individual values with the FDL Editor. VO Coding (Button "Code") is changing values automatically relating to the FA. For VO coding you don't need the Launcher Pro. Here you can download E-Sys 3.31 if you want to use newer psdzdata and don't need a Launcher. https://mega.nz/#!TggkDQaQ!SOKuNwrPP...G4I8ohD3p_5x3M |
X1604M57.00 |
02-16-2020, 11:45 AM | #3086 |
Rep 152
I did missed this step below. this might be the reason I failed. my another question is what value to put in places of X. or leave as they are?
05) Make sure that there is an empty "dist" folder in each of the psdzdata chassis folders, and if missing, create as needed, e.g.: • C:\Data\psdzdata\mainseries\F001\F001_xx_xx_xxx\od x\dist • C:\Data\psdzdata\mainseries\F010\F010_xx_xx_xxx\od x\dist • C:\Data\psdzdata\mainseries\F020\F020_xx_xx_xxx\od x\dist • C:\Data\psdzdata\mainseries\F025\F025_xx_xx_xxx\od x\dist • C:\Data\psdzdata\mainseries\F056\F056_xx_xx_xxx\od x\dist |
02-16-2020, 11:50 AM | #3087 | |
Rep 40,793
X1604M57.00 |
02-16-2020, 11:54 AM | #3088 |
Rep 152
02-16-2020, 11:57 AM | #3089 |
Rep 40,793
Try using E-Sys 3.3x, Launcher PRO 2.8.2, and v4.21.32 PSdZData. PM sent.
X1604M57.00 |
02-16-2020, 12:53 PM | #3090 |
Rep 152
02-16-2020, 01:03 PM | #3092 | |
Rep 152
thanks you very much. I will try. I really appreciate. |
02-16-2020, 01:10 PM | #3093 |
Rep 40,793
02-16-2020, 01:13 PM | #3094 |
Rep 152
03-03-2020, 07:17 AM | #3096 |
Rep 40,793
03-23-2020, 01:49 PM | #3098 |
Rep 26
Hi there. Was about to get my software updated. Got a problem on TAL Calculation .
https://drive.google.com/drive/folde..._TBgwW72xGK2hC Check Link for Screenshots. Thanks |
03-23-2020, 02:06 PM | #3099 | |
Rep 40,793
03-23-2020, 02:08 PM | #3100 |
Rep 40,793
PM sent.
04-07-2020, 02:55 AM | #3101 |
Rep 3
Drives: 2013 F31 320D xDrive
Could you send me new PSDZDATA? thanks!
04-07-2020, 09:43 AM | #3102 |
Rep 8
Hi, I am trying VO coding, but i made the change 6nh to 6nk, for bluetooth in my F20, but when I have to do FDL with HU_entry, I click on code. And then de CAFD in HU_ENTRY dessapear.
I try the Connect => Read FA => Activate FA => Read VCM => Left-Click on HU_ENTRY => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on HU_ENTRY => Select CODE. But "Detect CAF for SWE" botton is not active, and now my BMW radio is still working but now it seems like a roll roice, i mean in the screen appear the option to deploy the spirit of ecstasys. Someone can helpme with that problem, I want to fix my problem at least to back to normal radio. i used ESYS 3.27.1 with psdz version 5.01.02.2015.08 I-STEP (current): f020-13-07-506 I-STEP (last): f020-13-07-506 I-STEP (shipment): f020-13-07-506 My car is a BMW 118i F20 production date 2013-10-17 Thank you |
