01-15-2019, 04:48 PM | #1 |
Rep 445
Brake pad sensors
About 12k miles ago I replaced discs and pads all round and reused the sensors as they hadn’t triggered. All has been fine, but tonight I have a red warning saying front pads need replacing now. When I put my winters on the pads had loads of material on them - and that was a couple of weeks ago. Last set of pads lasted 50k miles so I’m confident they are not worn out.
Do the sensors break? If so, can I replace it without taking the pads out or do the pads need to come out (I didn’t look before as I swapped the sensor before the pads were in the Caliper). And finally is there a sensor on each side (I can’t remeber!) Thanks! |
01-15-2019, 05:30 PM | #4 |
Rep 5,776
01-16-2019, 04:37 AM | #5 |
Rep 709
You probably didn’t reset the brake service in the onboard computer, which is mileage based. I had the same issue.
I only replace the sensor if I damage it removing it from the pad. Not resetting the onboard computer is the only issue I’ve had. |
01-16-2019, 05:06 AM | #6 | |
Rep 445
It was showing 60,000 miles or something remaining |
