BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Weird high frequency noise coming in from the vents?!?
      04-02-2014, 10:24 PM   #1
hoon
Drives: MY14 F31 M sports package
Hi guys, my two week old F31 is making a weird and very very annoying high frequency noise from the vents. it sounds like very high pitch bell ringing.
the noise occurs when the engine is on and fans are on. and it increases significantly as rpm passes 1200...
weirdly, the noise goes away when i press the AC button or turn the fan completely off. anyone of you had had this issue? Thanks..
Link: the noise is clear at 00:30
      04-03-2014, 12:49 PM   #2
gomichaelkgo
Drives: 2014 335i
Sounds like a faulty HVAC fan to me!
      04-03-2014, 03:08 PM   #3
ajfriedm87
Drives: Alpine White M4, CP, Manual
Had a problem like that on a truck of mine, it was the bearing on the fan. The sound is probably always there, just different vent settings make it more or less prominent in the cabin (IE when you put AC on or not). Does the sound change as you raise and lower fan speed? IF so- bearing in HVAC fan.
      04-03-2014, 06:25 PM   #4
hoon
hmm.. i dont think the sound increases as i change the fan speed.
yesterday i discovered(?) something new about this noise. you know the temperature thumb knob at the center? the more i move the thumb knob to the left (more blue), the sound becomes very prominent, and less so if I turn it the other way (more red)... .. maybe it really is faulty HVAC components..
      04-03-2014, 10:31 PM   #5
ft1330
Drives: 2014 335i
cant hear anything abnormal in the video. Air going through vent is bound to make some noise...
      04-04-2014, 12:55 AM   #6
ajfriedm87
Im sure someone on here has the schematics, but like I said if you can adjust the air mix or fan speed to alter the sound, theres some moving part in there putting out noise that you are just diverting around. So once again I blame the fan bearing
      04-05-2014, 02:41 AM   #7
hoon
Thanks guys, I'm going in to the dealership on tuesday.. hopefully they'll be able to figure something out..
      04-08-2014, 11:12 PM   #8
daberlin
daberlin's Avatar
Drives: F30 335i EBII MPPK/BBK
Be very curious as to what you uncover. I have the EXACT same noise and even though I can't hear it above the radio, etc., knowing it is there is driving me bonkers. BTW, I still hear this sound even if the fan is completely turned off. I plan on calling the dealer and scheduling an appointment. First time bringing the car in for an issue.
Update - booked in Valencia BMW at noon today.
Current Garage
2018 Audi SQ5
2014 991 Porsche Carrera 4S
1986 BMW 325e
1971 VW Super Beetle
      04-12-2017, 02:48 AM   #9
The.Lows
Drives: E91 330i '08 (272hp)
Up !
I have the exact same noise on the car that I just bought (April 2014 F31 335i xdrive).
Did you guys find out ? Or you may as well just have sold your car by now
      07-24-2019, 11:22 AM   #10
rugina
Drives: f34
hello...found someone the problem?
      07-27-2019, 08:10 PM   #11
kingmonkey8
Drives: BMW 428i
Most likely the HVAC fan bearing has gone dry.
Same issue with previous generation BMW's. You can try lubricating the bearings. Not sure how accessible it is.on the F30.
      07-27-2019, 08:26 PM   #12
deviantspeed
poopycat
Drives: 2017 F31 330ixT
I hear it. Faulty fan on a 2017 VW I had I for a few thousand miles, dealer said they all sound that way. Same high pitched noise.
I said nope, never sounded like this new. They said there is nothing they can do and literally walked away. Same with the tranny whine and the THUNK noise when starting in reverse. Oh and I was very nice, too. I was literally thinking WTF VW, so I came back to BMW. Couldn't be happier.
Usually BMW service is MUCH better and more attentive. Let's hope for the best for you, My older 2013 didn't do this either.
      07-28-2019, 04:57 AM   #13
rlmesq
Drives: 2018 440i M Sport
Sometimes it can be as simple as a piece of paper or a leaf stuck in an air duct.
      07-28-2019, 09:08 AM   #14
The Kurgan
Drives: 2012 BMW 328i Luxury Line RWD
Mine made the same noise, it was leaves and maple keys and other organic matter in my blower motor. Easy to access under the hood. I also pulled the cabin filter and alot of leaf debris fell out on the carpet.
      09-30-2020, 06:36 PM   #15
MetzgerMeister
Drives: F82 M4
My f30 330d is making this noise. I bought a brand new blower motor and it didn’t solve the problem. Next step is the bearing on the front of the AC compressor but I don’t see how that could travel all the way into the cabin. It’s not leaves or anything stuck in the fan.
The noise is there when AC is on and when it’s off, no changes in the hot/cold settings make any difference at all. It’s strange because the AC pulley is always running as opposed to only when the AC is turned on.
It only goes away when the fan is completely turned off.
      10-02-2020, 02:51 PM   #16
MetzgerMeister
Drives: F82 M4
I don’t know if anyone is following this thread or not but Imma post anyway
I made another discovery tonight (don’t know why I didn’t do this until now) but with the engine off I ran the fan on normal and with aircon on and there was no noise coming through the vents at all. Then I turned the engine on and the noise appeared instantly. Engine off again and no noise.
Therefore there’s nothing wrong with the blower motor or ac compressor. It’s just down to vibration acoustics coming in through the vents. The joys of owning a diesel!
      10-03-2020, 04:11 AM   #17
Moontan
Drives: 2014 F30 328i Sportline
You do know that the AC compressor doesn't kick in with the engine off?
      10-03-2020, 04:46 AM   #18
MetzgerMeister
Drives: F82 M4
Didn’t know that at all actually
      03-14-2021, 01:59 AM   #19
Maxgo
Drives: BMW 430D Gran Coupe
Hi, wich was the "dealer" solution for those of you?
      03-14-2021, 03:31 AM   #20
Maxgo
Well, I can also add more videos to this investigation.
The sound while driving:
https://www.youtube.com/watch?v=TbKenCPddOI
Operating the flaps, you can see that when directs to the footwell disappear or minimize
https://www.youtube.com/watch?v=jLWw0MtcRZA
This is the technical test, this proves that I'n not crazy, analyzing the waves, you can clearly see when the different operations are performed, first the blower is off, one band will disappear, and second, when the flaps are completely close, the stupid sound its not entering the car anymore. Around 1800 Hz...
https://www.youtube.com/watch?v=slJpqGHjymw
When you go outside the car, you can also ear it, it is resonating somewhere, because if you move to different positions, you can ear it also, that means that is not coming necesary from the front side right archwheel, where the video was recorder.
https://www.youtube.com/watch?v=ZLx1lYX6uI8
and yes, the stupid frequency is there, in this case at around 2100HZ...
Hope this helps to describe the issue!
      03-05-2023, 01:11 PM   #21
The@Thing
Drives: BMW F20 2012 116D ED
Did you solve this problem ? Please help me
      03-20-2023, 09:49 AM   #22
MetzgerMeister
Drives: F82 M4
It's actually the low pressure AC hose vibrating in the engine bay and this noise comes through the vents. BMW have a metal weight on these hoses from factory from a certain year (I think it's 2015 or 2016 here in Europe).
You can buy this weight from BMW:
Additional Weight - 64-5-39-322-952
Clamp - 07-12-9-952-119
It's an easy DIY but needs to be done from underneath the car.
Check - SIB 64 01 14
high frequency noise, noise
