07-31-2016, 10:00 AM | #1 |
Rep 24
AFE air intake cause jerking
Hi All,
I installed a AFE Magnum cold air intake to my 435i. The transmission seems to jerk a little bit and even created more jerk when operate in Sport mode. Does anyone has experience the same problem? and How do you correct this problem. I've contact AFE regarding this issue. Their response was the car will automatically adjust after the burn-in period. I have great doubt on their response. I am thinking logically, there must be an unbalance ratio of air and fuel in the combustion chamber could lead to this problem. I appreciated your sharing and expertise advice. I do like the exhaust tonality with the AFE intakes. JB4 stage 2 Mport exhaust downpipe+catles |
07-31-2016, 10:42 PM | #2 |
Rep 953
YES! Finally, someone else has had this issue, although mine is with an injen intake. Have the same issue with the jerk especially in first gear in sport mode.
08-01-2016, 09:43 AM | #3 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
FWIW. Some systems are more sensitive than others to changes in the intake tract. In some cases the ECU has enough flexibility to adjust but some never do.
My COYOTE crate motor was tuned by FORD Racing for their intake tract. The motor runs a Spectre CAI in the car. The notes with the engine say that any change in the tract will require a fresh tune. So I took advantage of this for a custom performance dyno tune The notes with the Spectre indicate the position of the sensor (toward the front of the car) on the tubing with no alternative variation. So even where the pickup is located can be critical for a smooth running car A later change from the original intake manifold to the BOSS 302 had a note that the car must be retuned after the new manifold was installed. If the BMW system which has loser tolerances does not stabilize might be a good plan to get a performance tune or replace the CAI with a different one or go back to stock. Most all CAI's on a modern car don't make extra power but do create a good sound. IMHO the sound is not worth the performance issues that sometime comes with it.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
05-12-2017, 08:14 AM | #4 |
Rep 76
I've recently had the same problem after installing an Injen CAI in my 2014 335i. I have JB4, CP, catless DP, and now CAI. Never had the problem before CAI, but I also decided to run a 30% mix of E85 within a day of installing the CAI. So, I wasn't sure if it was the E85 or the CAI that's causing this. Been on for about 1.5 weeks. Going to run 1 more tank of 93 octane through it. If that doesn't fix it, going back with stock intake to see if that helps. Just to note, I had an AFE drop in high flow filter in my stock airbox, no problems.
05-12-2017, 08:19 AM | #5 |
Rep 2,957
Unplug your MAF sensor. Problem solved.
05-12-2017, 05:11 PM | #7 |
Rep 2,957
Why wtf? The maf sensor on aftermarket intakes causes issues with the jb4. Search the boards here its a known issue and resolution. Worked for me and many others
05-12-2017, 06:33 PM | #8 |
Rep 190,750
Mbanks is correct
Unplug the MAF sensor, JB4 will take care of the rest and problem is solved
mbanks211267.50 |
05-12-2017, 09:10 PM | #10 |
Rep 2,825
put your stock intake back on
saintpatty23.50 |
05-12-2017, 10:28 PM | #13 |
Rep 190,750
Intake is not causing any harm to the engine, the Jb4 suppress the code.
Same way how it suppresses the downpipe code since it does not cause any harm to the engine either
05-13-2017, 06:11 AM | #14 | |
Rep 2,957
05-13-2017, 09:47 AM | #15 |
Rep 2,825
Yup!!!! It's not the MAF sensor causing the problem.. that's part of your car! It is the shitty air Intake causing the problems...
05-13-2017, 09:19 PM | #16 | |
Rep 4,876
Unplug it, and the DME will go into a limp mode to deal with the failed input. I'd hardly call that a "solution". Sure it might work "ok", but it's not going to run 100% anymore. Just dump the aftermarket intake. |
05-13-2017, 11:43 PM | #17 |
Rep 14,115
Drives: G82 M4C X-Drive
All this for an air filter that gives you <5hp?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
05-14-2017, 12:25 AM | #18 | |
Rep 2,639
If you do have one or the other, I believe the tune will adjust the air accordingly. My car runs 100% better with the MAF unplugged. |
mbanks211267.50 |
05-14-2017, 01:48 AM | #19 | |
Rep 14,115
I'm curious as to how it knows which way to adjust without a sensor to tell it the mixture?
05-14-2017, 09:21 AM | #20 | ||
Rep 2,957
05-14-2017, 11:05 AM | #21 |
Rep 2,825
05-14-2017, 02:41 PM | #22 |
Rep 4,876
Exactly. At that point it's using some default canned mapping in the DME mixed with throttle position inputs (aka limp mode using alpha-n type fuel delivery as a backup from the superior speed density mode) to deal with a missing MAF input. It's definitely not 100% better. It just allows the engine to run.
