01-11-2020, 01:19 PM | #1 |
Rep 245
Blew my charge pipe today...okay to drive?
Well, it finally happened...albeit not as I expected it to. The car is a bone stock F30 N55 xDrive 6MT with 60k miles and no mods besides a Stage 1 BM3 on 93 octane (installed maybe 6months ago). I've never tracked the car and rarely even take it to redline. The car is very well-maintained and by no means abused or ragged out.
I was driving my kid to a birthday party this morning in the pouring rain. About 3 blocks from our house, I ran over a huge puddle which splashed water up onto the hood and windshield. I was maybe doing 20-30mph at low revs in 2nd or maybe 3rd gear. A couple of blocks later, I heard/felt a weird click and lost power. At first, I thought the car had popped out of gear, so I engaged the clutch and reseated it in both 2nd and 3rd. Revs were there but power was WAY down. No CELs at first. I immediately fired up my Kiwi 3 with Dashcommand app and there were several codes including p00bd (air flow too high), p0172 (system too rich bank 1). A CEL finally came on the dash after few miles and new codes popped up including p0300 (multiple cyl misfire) along with p0305, p0303, and p0304 (misfires in cyl 5, 3, and 4, respectively). My first thought was that water had gotten into the intake, but the symptoms didn't improve after driving around for a while. Once I got home, did a quick search here and saw someone had a blown charge pipe with p00bd so I popped the hood and there it was. Obviously I'll be upgrading to a proper aftermarket CP now (YES, I KNOW THAT I SHOULD'VE DONE THAT ALREADY)...but I guess my question is: can I drive it for a few days until I get around to changing it or will that damage the motor/turbos/etc? My wife drives the SUV during the winter so my other option is to drive the 997, but that's on MPSS. Luckily it's up in the 40-50's right now, but it's getting down into the high-20's to mid-30's overnight all next week which is suboptimal for those tires. Anyway, I just wanted to share my story as yet another example of a blown CP with a flash.
-PCA Instructor #201804533
-B58 F30, 6MT, M Sport, M Perf Exhaust, Dinan Springs, BM3 Stg 1 -My B58 F30 Build Thread https://f30.bimmerpost.com/forums/sh....php?t=1981176 -My F80 Build Thread https://f80.bimmerpost.com/forums/sh....php?t=1757458 -My N55 F30 Build Thread https://f30.bimmerpost.com/forums/sh....php?t=1739248 |
01-11-2020, 01:39 PM | #2 |
Rep 503
Bad idea. I have no idea how you even made it home. I've blown my charge pipe 3 times (yes 3!) and everytime my car completely lost power (on the freeway) and it was all I could do to get pulled over in a safe area. Maybe, MAYBE, you could physically drive it, but with the CP pulled open like that you can get something pulled into the engine and cause serious damage.
01-11-2020, 02:47 PM | #3 |
¯\_(ツ)_/¯
945
Rep 1,762
That's why it's recommended to get metal charge pipes as soon as you get one of these cars.
01-11-2020, 02:50 PM | #4 | |
Rep 10,473
01-11-2020, 10:14 PM | #6 | |
Rep 5,393
01-11-2020, 10:20 PM | #7 | |
Rep 5,393
Replace o-rings on both ends of charge pipe for the same reason. The o-ring near the intercooler connection is actually a square shaped directional o-ring. Install it in the wrong direction and it will leak. See attached diagram. Hope this helps! |
01-11-2020, 10:26 PM | #8 | ||
Rep 5,393
01-11-2020, 10:28 PM | #9 |
Rep 10,473
01-12-2020, 01:05 AM | #10 |
Rep 1,827
I agree, don't drive it. Take the 911 out, if you go sideways, all the more fun! In all seriousness, SuperSports below 40 have the potential to be sketchy, but drive carefully and you should be fine...does it happen to be a 4S? In any case, way better than risking engine damage on the Bimmer.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
01-12-2020, 01:16 AM | #11 |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
I gambled and won. I owned a x1 N55 and on my way to work the stock CP gave up the ghost. Car ran but like crap as expected for about a total of 30 miles until I took it to the dealer that evening.
01-12-2020, 01:30 PM | #12 | |
No 55mph
1621
Rep 8,476
ER only pipes I would use Yeah, I know, they cost more. In this case it true u get what u pay for
IK6SPEED4487.00 |
01-12-2020, 01:34 PM | #13 |
Rep 10,473
And they do not develop boost leaks in 6 months either.
01-12-2020, 01:47 PM | #14 |
Rep 4,325
you do get what you pay for with ER, nothing wrong with that...these are also good for a lot less and i've yet to see anything negative about quality or fitment
https://www.ctsturbo.com/product/cts...pe-set-xdrive/ https://www.ftpmotorsport.com.tw/pro...e-pipe-awd-4wd |
DrBall125.50 |
01-12-2020, 05:16 PM | #16 | |
Rep 40
"CAUTION: This product is intended for OFF ROAD USE ONLY. Not legal for use on pollution controlled vechiles upon public road/highways. THIS PRODUCT IS FOR SALE FOR ALL 49 STATES EXCLUDING CALIFORNIA. " Does it not have all the smog hook-ups?
2013 335i xDrive Melbourne Red my first BMW BMW, you might find better but you can't pay more |
01-12-2020, 05:50 PM | #17 | |
No 55mph
1621
Rep 8,476
They also include (2) threaded Meth Bungs in case you ever want to run Meth. If not used they have threaded plugs Believe me, I have had both ER pipes on my 435 since 2015 and it has passed our yearly regular & emissions inspections here in PA without a problem. I have the black version so I doubt they even know it's not OEM... I didn't see that statement in the description on XPH site where I bought mine & wouldn't have worried if I did. CP not a smog related part at all - hell, half the members on here have installed catless DP's - now that IS smog related
johnung4528.00 |
01-12-2020, 06:13 PM | #18 | ||
Rep 1,827
01-13-2020, 01:12 PM | #19 |
Rep 2,499
It's only needed if you are tuned/modified like OP is. (I don't think they know what "bone stock" means). The incidence of charge pipe failure on true stock cars is too low for it to be a proactive maintenance item.
01-14-2020, 12:51 PM | #20 | |
Rep 245
Anyway, thanks for the recs. Apparently I had email notifications turned off so I missed all these responses in the last couple of days. Since then, however, I've already scheduled to have it replaced at my local indy shop which happens to be a VRSF dealer (whatever that means) so it'll be getting a new VRSF CP installed this week. Weather has been fine so the MPSS on the 997 hasn't been an issue. Btw, I had forgotten about the warranty on the CTS CP, otherwise I may have considered it. Thanks again for the recs. And to all you guys who find this thread at some point in the future via the search function: YES, YOU ABSOLUTELY NEED TO UPGRADE YOUR CHARGE PIPE WHEN YOU FLASH THE CAR. I'm a 40+ year old professional with a kid's car seat in the back, for crying out loud. I'm lucky to get above 5k RPMs once a week. This car really isn't ragged out, and the damn thing blew anyway.
01-14-2020, 06:39 PM | #21 | |
Rep 10,473
Plenty of stock cars have blown OEM Charge Pipes. |
alohasurftoad3076.50 |
01-14-2020, 11:08 PM | #22 |
Rep 2,499
