11-13-2020, 02:30 PM | #23 | |
Rep 2,653
11-14-2020, 12:17 PM | #24 |
Rep 1,288
Ran the first run and it came out really nice... I'm running E20
https://datazap.me/u/fastf30/log-160...28-29-30-31-32 Ran the second one right after and not as nice.... https://datazap.me/u/fastf30/log-160...27-28-29-30-31 Can't put anymore "E" in there... guess gonna try some Boostane and do a 1st/2nd pull to check then do a long 4th gear pull... I think I'm gonna get a bigger IC also... It's 50degree out 44% humidity... amb pressure is 14.9... |
11-14-2020, 12:49 PM | #26 | |
Rep 2,653
11-14-2020, 12:49 PM | #27 |
Rep 1,288
11-14-2020, 12:51 PM | #28 |
Rep 1,288
I see your in NY & EWG... which means 93 octane... I'd do E20 and see what your logs say... my E20 mix is just about perfect... MHD did the E20 map for EWG because that's all it can handle supposedly...
11-14-2020, 12:54 PM | #29 |
Rep 2,653
Ok cool. Yessir... I'm in Westchester. Found a place that sells E85 and tested it at 82 last night.
11-14-2020, 12:59 PM | #30 |
Rep 1,288
11-14-2020, 01:20 PM | #31 | |
Rep 7,597
11-14-2020, 01:34 PM | #32 | |
Rep 1,288
On another note... my new coilovers kept this car flat.. accelerating, braking, everything... now it's a true sports sedan... |
11-14-2020, 02:25 PM | #33 |
Rep 1,288
P.s. I used the 1/4gallon "E85" to 1/8 tank measurment... I had 3/8 of a tank which I rounded up to 1.3 gallons of "E85"... worked pretty good...
11-14-2020, 02:56 PM | #34 | |
Rep 1,288
for those first time looking... the 268whp is not the cars max hp... this is a first gear pull... whp in fourth gear would be north of 400whp with perfect timing... |
11-14-2020, 03:27 PM | #35 | |
Rep 1,288
Though I was in second gear and then it kicked down on second run... so maybe that has something to do with turbo spooling up etc... P.s. Love VD... thanks for introducing it to me... Last edited by FastF30; 11-14-2020 at 03:39 PM.. |
11-14-2020, 05:52 PM | #36 |
Rep 2,653
I was able to get a few pulls in today. I decided to just give it the business and go E30... My HPFP was struggling a bit but recovered. Timings are dramatically improved for me. The car was holding boost all the way up to 5800RPM, never did that before. It felt great and strong. No breaking up despite the HPFP dropping off a bit:
https://www.bootmod3.net/log?id=5fb0...729b68b3a5b4f2 https://www.bootmod3.net/log?id=5fb0...90c66865b9c374
11-14-2020, 06:10 PM | #37 | |
Rep 1,288
11-14-2020, 06:27 PM | #38 | ||
Rep 2,653
11-14-2020, 06:39 PM | #39 | |
Rep 1,288
11-14-2020, 06:45 PM | #40 | ||
Rep 2,653
11-14-2020, 06:47 PM | #41 | |
Rep 1,288
That dip in fuel pressure looks like it's related to dip in Hp around that rpm... |
11-14-2020, 06:48 PM | #42 |
Rep 1,288
11-14-2020, 06:55 PM | #43 | |
Rep 2,653
What did you mean when you mention the fuel did being related to HP?
11-14-2020, 07:13 PM | #44 |
Rep 1,288
you have a dip in Hp @ 5200 your fuel was already dropping at that point... I only looked at your 4th gear pull log... I just looked at your 3/4/5 gear pull and you are in the 1600's .... I suggest you add a gallon of 93 and see... I ended up adding 2 gallons to get acceptable pressure when I was that low... but start with a gallon... 1st/2nd gear pull is where I saw the biggest drop...
