11-20-2020, 07:08 PM | #1 |
Rep 325
This is the first log I took since installing my ps2 and running the mhd ots ps2 map on my pwg n55. I hope this link works cause I can't find any other way of linking to my datazap account.
My car is a f30 pwg n55 xdrive with basically stock fueling as I'm currently using the original b58 hpfp. I have a bit of ethanol left in the tank from my previous stg2+ e30 map. My analyzer says e17 and the rest 93 To my untrained eyes it looks pretty good to me except it seems I consistently get timing corrections on cyl2. Am I reading that correct? How much is too much on timing corrections? What can cause that in only cyl2 bad sparkplugs or coils? Here are the type of logs you guys requested 3rd gear from 2500-6500 https://datazap.me/u/bowenf30/mhd-ps...o=3&mark=23-24 https://datazap.me/u/bowenf30/mhd-ps...-21&mark=29-33 https://datazap.me/u/bowenf30/mhd-ps...-21-29&mark=39 |
11-21-2020, 10:19 AM | #3 |
Rep 325
11-21-2020, 10:22 AM | #4 | |
Rep 1,288
Bowenpuref3p 3rd gear manual... 4th gear auto.... also please include specs of car year RWD or Xdrive Man or Auto Fuel used Fuel system upgrades Etc: Last edited by FastF30; 11-21-2020 at 11:16 AM.. |
11-21-2020, 12:59 PM | #5 |
Rep 1,105
11-21-2020, 06:45 PM | #6 | |
Rep 325
My car is a f30 pwg n55 xdrive 6spd with a ps2 turbo and fbo. I'm running the mhd ps2 ots map for 93octane. I was running the e30 tune prior to the ps2 install so the tank has some ethanol still in it. My analyzer says it's currently e17 with the rest 93. I plan on getting a custom e30-e50 tune soon as I'm waiting until the 27th when dorch has their stg2 hpfp on sale. I'm just curious to see how the generic ots map is performing. I will say it certainly feels like it is running really good on the ps2 ots map. But you can tell this turbo has wayyyy more power to give with supplemental fueling and ethanol. |
11-21-2020, 09:25 PM | #7 |
Rep 325
I edited the first post to contain all the info and new logs that your guys recommended. Thanks in advance guys.
I took 3 logs in 3rd gear pulls from 2500 to 6500. Hopefully these are better then my previous attempts. My limited ability to read and understand logs says these look pretty good. I do see some timing pulls in only cyl2 and wondering if that is bad and what could cause it. Any input would be appreciated. https://datazap.me/u/bowenf30/mhd-ps...o=3&mark=23-24 https://datazap.me/u/bowenf30/mhd-ps...-21&mark=29-33 https://datazap.me/u/bowenf30/mhd-ps...-21-29&mark=39 |
11-21-2020, 09:47 PM | #8 | |
Rep 1,105
11-21-2020, 10:23 PM | #9 | ||
Rep 325
Should I have just mashed the throttle to 100% immediately? But I do know the wastegate is set properly as I set it to bmw vaccum spec a week ago before I reinstalled it with the ps2. I'll double check though to make sure. Did you see the timing pull only in cyl 2? Does that seem odd to you? |
11-21-2020, 10:29 PM | #10 | |
Rep 2,354
(A Dane in China) |
11-21-2020, 10:33 PM | #11 | ||
Rep 325
But before I do that I wanted to make sure the logs seem good before I turn up the boost. |
11-21-2020, 10:53 PM | #12 |
Rep 325
So since I have a few degrees of timing corrections that seem to only be in cyl2 I want to try swapping plug and coil to a different cyl to see if it travels.
So which is cyl2 on a n55? Is the cylinder closest to the front of the car cyl1 or cyl6? I'm guessing it's cyl1 but can't find the answer any where. |
11-22-2020, 12:55 PM | #13 | |
Rep 7,591
These logs generally look fine. You do have that small dip in boost but i think thats just the response of the PWG wastegate keeping boost under control. You are also close to load target (with that small dip), so i wouldn't really worry about a leak or WG issue unless a custom tune also has problems controlling boost. The timing corrections also look very minor so i wouldnt worry about those either. Overall the logs look fine. In one of the logs i noticed IATs went up a decent amount. What IC are you running? |
11-23-2020, 02:08 PM | #14 | ||
Rep 325
I'm running a vrsf street intercooler. I plan on going bigger after I install my dorch hpfp. I took one more 3rd gear log today it also looks good overall to me as well so I'm pretty happy with the ots ps2 map. It leaves a ton of power on the table but it runs really nicely. https://datazap.me/u/bowenf30/mhd-ps...62&mark=18 |
11-23-2020, 03:52 PM | #16 | |
Rep 7,591
Skimmed though the log and it looks fine. You do have a slight dip in rail pressure at one spot but i dont think its because you are actually running out of fuel. Load control looks very good. Depends on your pursuit of perfection lol. But realistically, misc corrections of a couple degrees here and there are more or less unavoidable. You need to look at actual timing to see how much correction you are getting relative to target. If you are running 8 degrees and pulling 6, i would say thats too much, especially if its happening across multiple cylinders and all the time. |
11-23-2020, 04:08 PM | #17 | ||
Rep 325
Regarding the timing your saying rather then looking at timing corrections look at actual timing numbers and compare to what the tune is asking for correct? Everyday I start looking at logs the numbers are slowly becoming easier to understand and it's easier to see patterns. Your thread is truly helpful thanks a ton for taking the time to create it. |
11-23-2020, 04:29 PM | #18 | |
Rep 7,591
Bowenpuref3p92.50 |
11-23-2020, 05:37 PM | #19 | ||
Rep 325
I'll post up the log once I get a chance to actually make the log. |
