12-08-2022, 10:35 AM | #1 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
[CODING] Disable license plate lights when shifting into reverse - PERFECT FOR NIGHT
On the F3X platform the rear bumper is visible on the backup camera view, and at night the license plate lights reflect off the bumper making it very hard to see. Using e-sys I coded the rear electronics module (REM) to turn those lights off when I put the car into reverse. Shifting back into drive or any other shifter position turns the lights back on, they only turn off in reverse.
Much easier to see now! This may be possible using one of the phone apps but I used e-sys. Here are the coding parameters: Code:
[REM] MAPPING_UNIVERSAL_2_OUTPUT Werte=00(off) to Werte=22(kzl) [REM] MAPPING_UNIVERSAL_2_PART_OF_WL not_active to hard_on [REM] MAPPING_UNIVERSAL_2_FUNCTION Werte=0C(bremslicht) to Werte=0F(rfs) [REM] MAPPING_UNIVERSAL_2_PRIORITY Werte=02(priority_2) to Werte=00(priority_0) [REM] MAPPING_UNIVERSAL_2_FIXED_PWM Werte=00(pwm) to Werte=01(fixed) To adjust the KZL (license plate light) brightness, change the following value in hex. [REM] MAPPING_UNIVERSAL_2_PWM_LEVEL_1 Werte=00(off) to Werte=00 to 64(100%) |
