12-01-2017, 04:54 AM | #3301 | |
Rep 148
I definitely have the MOVE 2018-1 map (I also have NEXT maps, hence the confusion) Unlike NEXT map updates where the extracted files have 1, 2, 3, 4 folders etc. the MOVE extracted maps do not. |
12-01-2017, 05:05 AM | #3302 | |
Rep 2,152
guess i just haveto wait for them to play catch up not a lot else i can
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
12-01-2017, 07:10 AM | #3303 | |
Rep 40,774
NBT = NEXT NBT2 = EVO Why are you swapping one EVO for another? Just to go from ID4 to ID5/6? If you have factory fitted EVO ID4, and they replace it with ID5/6, it will most likely be ECE version, so you will no longer have Sat Radio tuner if that matters to you.
12-01-2017, 07:24 AM | #3304 | |
Rep 40,774
Ok. Well, all you should have to do is copy everything inside the NAVD_0000085F_255_004_240 folder to the root of a Fat32 Formatted (NOT NTFS or ExFat) USB Flash Drive, and insert in car.
12-01-2017, 08:17 AM | #3305 | |
Rep 148
Car has USB slot in the glovebox, which works straight away. |
12-01-2017, 09:32 AM | #3306 |
Rep 40,774
12-01-2017, 01:47 PM | #3307 |
Rep 63
Yes they did tell me I would lose HD Radio and Sat radio which is a bummer.
Interesting, I was told my NBT EVO could not be updated and to get ID5/6 I'd have to purchase their head unit. You're saying it's possible with just a software update? |
12-01-2017, 02:32 PM | #3308 | |
Rep 40,774
ID4 Hardware has 2 Gb of Ram. ID5 has 4 Gb. If you flash ID4 Hardware with ID5 Firmware, it will run slow, and suffer frequent reboots as it does not have enough memory. You will also need new ID5 Map FSC Code, which is expensive. Also, unless car has a functional ATM module, you will loose all Telemtics (e.g. RTTI).
12-03-2017, 01:22 PM | #3310 |
Rep 40,774
PM sent.
12-03-2017, 03:49 PM | #3311 |
Rep 331
Hi shawn, can you please help me in my problem ?
Is there a way to update maps when USB is not working in the car ? With Business and Move maps. USB is in the armrest but it seems that there is no cable connected to it. Glovebox does not have USB, only black cover. Can it be done with DVD somehow ?
2007 BMW 320d | Jet Black | M6 wheels | Eibach Pro-Kit | BlackLines | Chrome grill | H&R spacers | Alpine HiFi
12-03-2017, 03:51 PM | #3312 | |
Rep 40,774
12-04-2017, 12:18 AM | #3313 |
Rep 60
Drives: 2017 330i Sport
Can I have the latest North American for NBT EVO?
12-04-2017, 12:26 AM | #3314 |
Rep 40,774
12-04-2017, 06:59 AM | #3317 | |
Rep 40,774
12-04-2017, 07:20 AM | #3318 |
Rep 13
Hi Shawn,
could you confirm an important point about the navigation map? the maps for NBT EVO and NBT are different, those for an ID4 is not valid for an ID5? And if i interstood correctly the FSC code are different between iD4 and iD5/6. |
12-04-2017, 07:40 AM | #3319 | |
Rep 40,774
NBT2 ID4 and NBT2 ID5/6 are same map, but FSC Code is different.
12-04-2017, 09:19 AM | #3321 |
Rep 40,774
