BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Seeking advice on front tire sizes for my Style 361 8x20" wheels
      10-18-2018, 02:15 PM   #1
TF3090
TF3090's Avatar
57
Drives: 2014 BMW 435i M Sport
Hey guys, total newbie here with a quick tire question. I have OEM style 361 wheels (8x20" ET36 front, 8.5x20" ET47 rear; OEM tire sizes are 225/35/20 front 255/30/20 rear). I've already replaced my rears with 255/30/20 MP4S tires, and am planning on getting a pair of MP4S tires up front to complete my set. I've also been planning on adding spacers on all four corners. My car is currently lowered on H&R Supersport springs, so my biggest concern is avoiding rubbing issues.
My first reaction was to replace my OEM tires with the same 225/35/20 size and then add spacers (10mm front, 12mm rear). Would it be possible to just put on 235/35/20 tires up front and no longer need the spacers up front? I've done some digging and it seems like 235/35/20 should work with these 8" wheels, but I'm not sure if the lowering springs affect the answer.
      10-18-2018, 02:40 PM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
RWD or xDrive?
With RWD just use 245/30-20 up front without spacers, and add 15mm (or 18mm) spacers for the rear wheels.
With xDrive it's a bit more complicated.
TF309057.00
      10-18-2018, 03:20 PM   #3
TF3090
TF3090's Avatar
57
Originally Posted by .BMW. View Post
RWD or xDrive?
Thank you so much for your help!
I am RWD. Do you think that would be fine to avoid rubbing issues as well, with in mind the H&R supersport springs I have on as well?
      10-18-2018, 03:34 PM   #4
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Should be no problem.
245/30-20 is slightly shorter than OEM 225/35 front tires.
TF309057.00
