10-11-2018, 08:32 AM | #1 |
Rep 231
Adaptive headlights
Hello,
I'm new to the bmw world. I'm willing to change the xenon lights to the adaptive lights for 435 2015 M sport package. Is it possible? Any recommendations? From where to buy? Is there any changes in the sockets that i need to make? Is there any programming needed ? Your help is appreciated. Thanks, Zeyad |
10-11-2018, 01:04 PM | #2 | |
Rep 10,473
However, the iihs rates the BMW F30 LED Adaptive Headlights acceptable (one notch above fail) instead of good. Stay with what you have, though others will post with their personal belief that they are better based on what they “think they see” instead of scientific evidence. Spend your money elsewhere. |
zeyad.habeeb58.50 |
10-11-2018, 01:44 PM | #3 | |
Rep 221
Or like IK6Speed suggested, changing to adaptive LED headlights? In either case, you're talking about getting new OEM headlight assemblies, which can be done, but will be very costly. However, I have the suspicion that you might be wanting to upgrade your halogen headlights to HID headlights. In which case, again you'd have to get new headlight assemblies, but you can get Depo brand headlights which can support HID but without adaptive capabilities for a much more reasonable cost. |
zeyad.habeeb58.50 |
10-11-2018, 02:03 PM | #4 |
Rep 26
OP said he has a 435, which I'm not sure is available with halogens. That said you can technically retrofit the Adaptive LEDs and xenons but the LEDs will be significantly more expensive for not really much gain.
I would check to make sure you don't already have adaptive xenons. I thought it was standard equipment, with the high beam assist being an option added to Driver Assistance Plus (which requires a KAFAS camera), as well as ZLP for the Full LED option. |
zeyad.habeeb58.50 |
10-11-2018, 02:35 PM | #5 | |
Rep 221
And yes, i would have thought all HIDs are adaptive. |
zeyad.habeeb58.50 |
10-11-2018, 08:31 PM | #6 |
Im real pressed.
104
Rep 203
The HID's are adaptive for the 2015 4 series doesn't matter if you have a 428 with ZERO options OP should have the adaptive headlight's, the lighting pkg. just added LED headlights which are also adaptive and auto high beams (which was completely different from the pre-LCI 3 series Lighting pkg)
Current Lineup: 2017 Tesla Model S 100D/2017 340i Xdrive/2015 Audi Q5 Prestige Quattro/2017 Kia Optima SXL
zeyad.habeeb58.50 |
10-11-2018, 10:00 PM | #7 | |
Rep 221
zeyad.habeeb58.50 |
10-11-2018, 10:24 PM | #8 |
Rep 2,499
All American N55 cars have adaptive HIDs (Bi-Xenons). These are significantly the best headlights you can get in America. The adaptive LEDs, like IK6SPEED said, are not very good. The non-adaptive LED headlights received a rating of "poor" which is the worst rating the IIHS gives.
I personally also think the reflector style housing of the adaptive LEDs looks much cheaper than the projection HIDs. There's also the headache of coding in all your changes and the significant cost of acquiring adaptive LED housings. What is your goal? Why do you want adaptive LEDs? The only positive thing about them is if you like the shape of the angel eyes. Otherwise, they're worse in every objective way. |
zeyad.habeeb58.50 |
10-12-2018, 12:44 AM | #9 | |
Rep 231
Led lights
To clarify, it has the hid lights But i want to switch to the led one because it's much nicer than the regular headlights. So I'm not sure if i need to change the OEM sockets or any programming has to be done to make them work. Thanks |
10-12-2018, 01:58 AM | #10 | |
Rep 10,473
Again, while they might look nicer to you, the performance is worse than the HID and only rated “acceptable” by the iihs, one notch above poor/fail. |
10-12-2018, 04:43 AM | #12 |
No 55mph
1619
Rep 8,476
You can pick up a lot of nice PERFORMANCE upgrades for $5k - I wouldn't waste my time spending it on LED headlights just for the different design angel eyes, but hey, it's your car...
10-12-2018, 08:22 AM | #13 |
Rep 878
How do I find out if my car has adaptive xenons?
10-12-2018, 09:41 AM | #14 |
Rep 10,473
10-12-2018, 11:12 AM | #15 |
Rep 3,752
10-12-2018, 11:14 AM | #16 |
Rep 3,752
10-12-2018, 02:11 PM | #17 |
Rep 878
10-12-2018, 02:18 PM | #18 |
Monobloc
331
Rep 447
Drives: '02 M Coupe - '19 F31 330ix
It will also say 'adaptive led' on the outside headlight housing if you have the option.
10-12-2018, 06:48 PM | #19 | |
Rep 10,473
However, if added on aftermarket, it would not be in VIN Decoder either. |
10-13-2018, 09:08 PM | #20 |
Im real pressed.
104
Rep 203
As other have stated why you would want to get LED headlight's over the Xenon's? We had a 2018 Lexus NX as a loaner car and the it's Bi-LED projector headlight's were WAYYY brighter than my reflector "Adaptive LED's" on my 340i. I prefer Lexus Bi-LED headlight's over my full LED's (FYI the NX didn't have adaptive headlight's and I'd rather have those) Heck, even our Model S has full reflector LED headlight's and they are on the same level as my 340i which Im not fond of...Our Optima which has LED projector headlight's and our Q5 which has Xenon's are brighter than both the Tesla and BMW...BMW should've made Adaptive Xenon's standard and LED's optional.
10-14-2018, 04:23 AM | #21 |
Monobloc
331
Rep 447
I appreciate the clarification!
-2023 Honda Odyssey Elite - Sonic Gray Pearl / Black
-2019 F31 330ix Individual - Champagne Quartz / Coral Red (M-sport, Exec, Premium, Track) -2004 Honda CRV AWD - Silver / Black -2002 S54 M Coupé - Steel Gray / Dark Gray/Black |
