BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CIC/NBT FSC Generator - Windows/Linux/OSX
      08-27-2019, 06:29 AM   #221
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i
2018 GMC Acadia  [0.00]
2014 BMW 428i  [5.00]
Does this support the new 2020-1 NEXT maps?
___________________
2014 F32 428i 8AT M-Sport
      08-31-2019, 09:30 AM   #222
sjb0095
Hello,
Having problems with a FSC code hoping someone can help.
MAPS: Europe NEXT west 2019-2
F30 320D - NBT (not sure if its Evo)
VIN: J388717
Car Date: 2014-08-02
      09-02-2019, 01:09 PM   #223
fred-cbr
Drives: F22
Hello,
I can not generate a valid FSC code
Road Map EUROPE EVO 2019-2 ==> OK before Road Map EUROPE EVO 2015-3+
VIN: VZ34203
NBTevo_E16202A
I try with BMW CIC FSC gen v1.91 gui version
Thanks in advance
      09-02-2019, 01:42 PM   #224
atzebmw
Drives: BMW 335XD F30 LCI
Originally Posted by fred-cbr View Post
Hello,
The Generator doesn‘t work for Evo Maps.
      09-02-2019, 01:58 PM   #225
fred-cbr
Drives: F22
Thanks atzebmw for reply
I must use E-Sys? or can i install a another map?
      09-02-2019, 03:15 PM   #226
atzebmw
I also have the Evo-Map.
For this Map there is still no Generator available.
So i gave up to generate a FSC and bought it on Ebay for 30€ (Lifetime Code).
It is not possible to install another Map.
      09-03-2019, 01:29 AM   #227
fred-cbr
Drives: F22
Yes you're right
      09-09-2019, 07:42 AM   #228
seekey_
Drives: F11
Hello Jagaer,
is problem for F11,
FSC code please
VIN: G276820
ROAD MAP EUROPE NEXT east 2019-2
      10-05-2019, 03:52 PM   #229
Makky
Drives: F80 Competition
Jagaer Not sure what is wrong with my file, but it's not being accepted?
It works on my other keygen I usually use and I have used the same file for years.
      10-06-2019, 05:13 PM   #230
Onizukachan
Great Teacher
Onizukachan's Avatar
Drives: E46/3 M56 & F31d
imhaving sameissue
      10-07-2019, 03:39 PM   #231
Nachos23
HotBimmer
Nachos23's Avatar
Drives: 2011 535GT & 2000 Z3M Roadster
2016 BMW 335GT  [0.00]
2000 BMW Z3M  [0.00]
Send a message via MSN to Nachos23
Originally Posted by Shophopper View Post
Thanks Jaeger! If I may suggest a future improvement:
A lot of users seem to have problems adding a new release date to the lookup.xml file. For example: 2020-1 is not in the lookup file yet and nobody knows how long BMW will stick to the current byte pattern to identify releases. You might want to add edit boxes to enter the map type and release date as byte values, as an alternative to the dropdown boxes with fixed lookup values.
Can you enlighten me pls? I know how to update an editor and was able to find the NA Premium 2020 section within the xml file... how do I change the date and to what date to I change it to? Thanks!
2016 335GT & 2000 Z3 M Roadster
      10-17-2019, 09:08 AM   #232
Sunny 528i
Drives: 2012 528i
same, looking for the NA premium 2020 SWID or the lookup.xml file
All i have is from 2019:
<SgbmId id="NAVD_00005C4B_255_005_229" SWID_FscShort="002D0038" name="Road Map North America PREMIUM 2019" supplier="TAS" sop="07.28.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" />
<SwUpdate SwUpdateEntry=""/>
</SgbmId>
Anyone know what the 2020 lookup.xml lines are?
      10-17-2019, 06:29 PM   #233
Onizukachan
Great Teacher
No but it is 41 for NEXT.
Hopefully this will fill in a date gap,
Prod 9/24/2014
      10-18-2019, 07:16 AM   #234
Sunny 528i
Drives: 2012 528i
Prod 9/24/2014
You are correct it is 41 for Premium as well (0x2D 0x41)! But i end up doing the lifetime code and put "FF" in place of 41.
If anyone needs the lookup.xml lines for North America Premium 2020 see below:
SgbmId id="NAVD_000004D3_255_002_048" SWID_FscShort="002D0041" name="Road Map North America PREMIUM 2020" supplier="TAS" sop="07.28.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" />
</SgbmId
      10-19-2019, 05:12 AM   #235
RokasLTU
RokasLTU's Avatar
Drives: Volvo V50, BMW 318d
Something like this?
https://www.ebay.co.uk/itm/BMW-FSC-C...wAAOSwHX5dhap9
      10-21-2019, 12:09 PM   #236
dlovedesigns
Drives: 2008 328i
link expired
      11-06-2019, 12:11 PM   #237
snowghost_
Drives: F36
Hi, If anyone cane help, I am looking for FSC code.
I tried using the FSC generator but none of the codes are working.
Map type: Next
Region: North America
Map: Road Map North America Next 2020 -1
Vin: D955416
Production Date: 2015-01-21
      11-14-2019, 12:17 PM   #238
gylopl
Drives: BMW f30 & f32
I have question. All generator do not support NBT-EVO but some people are solding these keys. They have them from official distribution? Or they made some changes in generator?
      11-15-2019, 10:16 AM   #239
fontiablanco
fontiablanco's Avatar
Spain
Drives: BMW F10
Hi, I'm having trouble generating a valid FSC code.
Can somebody help me? I want code Fsc lifetime for maps Road Map Europe West Motion 2020
Bmw F10 Manufactured on 2011-05-09
VIN: C665579
REGARDS
      11-21-2019, 11:09 AM   #240
Stu667
Drives: 2014 320D F30
Could some kind soul please help me with an FSC for an F30, F167479, manufactured 30/07/2014? Currently has 2014 Route map installed, and I've download 2019-2 Europe West. Unfortunately none of the generated codes work for me, and I've tried the 4 closest dates. Thank you
      11-21-2019, 11:49 AM   #241
atzebmw
Do you have an OBD-ENET cable and E-Sys for your car?
So you can read the 1b-file and try to generate the FSC.
      11-21-2019, 12:04 PM   #242
Stu667
Unfortunately not. I've heard it can be generated via the VIN though, with the right software?
