European Auto Source (EAS)
      10-09-2019, 01:57 PM   #14961
Kevin_Trxn
Drives: '17 340i
Hello shawnsheridan
I have a 2017 340i f30 looking for the latest links as well! Thank you,
if you know the steps to code back up camera that info would be helpful as well!
      10-09-2019, 02:17 PM   #14962
Cpatel
Drives: N26 328i
Can someone help me code the following things, I couldn't figure these out myself (im using bimmercode if that matters)
1) Disable sunroof opening on comfort access (holding unlock button). I only want the front and passengers windows to open
2)I have a closing comfort access delay of 0 second. I want the mirrors to fold immediately. I set a delay for the front windows of 1.5 seconds but the rear windows do not have a delay. They start to close as soon as I press the lock button. How do I make the rear windows have the same delay as the front windows?
3) Is it possible to have mirrors unfold on engine start. I do not want them to unfold on unlock. Right now I have the mirror unfold threshold at 0MPH but that doesn't unfold them on engine start. I have to roll the car a little for them to unfold.
4) Fog lights when cornering. I saw a few threads but I was unable to get it to work. Maybe I was using incorrect code
5) When I hit the breaks, the outer light illuminate but the inner ones do not. Is there a way to have the inner lights illuminate as well?
6) My car came with enhanced bluetooth (I think, I have the box in the trunk). Sometimes when I select a song using the steering wheel controls, the check mark on the selected, to be played, song will appear and then disappear and the current song will continue to play. I am unable to change the song using the steering wheel. This is an intermittent problem.
All help is greatly appreciated
      10-09-2019, 06:58 PM   #14963
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by torukan View Post
Has someone full E-sys programm for my F30 with Token and Pin?
Best regards!
PM sent.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      10-09-2019, 07:01 PM   #14964
shawnsheridan
Originally Posted by Kevin_Trxn View Post
Hello shawnsheridan
PM sent.
If you have OEM Camera, then it is simple VO Coding car (Head Unit and TRSVC) for 3AG.
      10-09-2019, 07:54 PM   #14965
Kevin_Trxn
Drives: '17 340i
Hello shawnsheridan
PM sent.
Thanks!!!
      10-10-2019, 06:51 PM   #14966
radoslav
Drives: f22 30
Hi Shawn,
I am first time to the forum and just bought f 22 230 in florida, without heated seats. And i installed himself such heated chairs.
Could you please show the way for coding?
Thanks.
      10-10-2019, 07:43 PM   #14967
shawnsheridan
Originally Posted by radoslav View Post
Hi Shawn,
Thanks.
PM sent.
      10-12-2019, 01:55 PM   #14968
Araemo
Drives: 2017 340iX 6MT
Could I get the latest links please?
      10-12-2019, 02:06 PM   #14969
shawnsheridan
PM sent.
      10-13-2019, 01:03 PM   #14970
RokasLTU
RokasLTU's Avatar
Drives: Volvo V50, BMW 318d
Hi, I have a question:
I have VO coded a sport transmission and then FDL coded some things like logos and trunk opening. Everything works!
Now I want to remove an element from my edited VO and I'll need to VO code ECUs.
Does this mean I'm gonna lose all my FDL coded stuff and gonna need to code it again?
      10-13-2019, 01:04 PM   #14971
shawnsheridan
VO Coding an ECU wipes out all custom FDL Coding.
      10-15-2019, 03:11 PM   #14972
Cpatel
Drives: N26 328i
Is there anyway I can change the cornering fog light threshold and activation speed through coding?
      10-16-2019, 09:22 AM   #14973
Lgb0250
Drives: 2014 F32 435i M Sport
Hi Shawn. I am completely new to the BMW family. Have had Toyota’s for years and have used the Carista app instead of Techstream to code them.
I just ordered the ENET cable and Rj45 to lightning adapter so I can use the BimmerCode app. Could you please pm me the latest links I will need? Thanks
2014 F32 435i M-Sport
2018 Toyota Highlander Limited Platinum
      10-16-2019, 09:40 AM   #14974
shawnsheridan
PM sent.
      10-18-2019, 03:25 AM   #14975
RokasLTU
RokasLTU's Avatar
What option is for coding out an empty menu item in BC?
      10-18-2019, 08:50 AM   #14976
Maurici
Drives: Bmw F31 340I
Hello!! New to this forum and new with a BMWF31 340I...
I also own a BMW Z4 from 2003, and I'm quite fluent coding, but found that none of my knowledge gathered in the Z4 is now relevant for F3X cars.
I've been reading quite a lot of different places, and this appears to be the place to go. Been redirected from bimmerforums uk...
Could I have the latest links, so I can start to crack on, and hopefully learn and colaborate?
Many thanks
Amazing job with this post!
      10-18-2019, 09:13 AM   #14977
gecko.ch
gecko.ch's Avatar
Switzerland
Drives: F30, F20
Do you mean maybe this one?
Kombi 3000> BC_Leerzeile > aktiv
      10-18-2019, 09:40 AM   #14978
shawnsheridan
Many thanks
PM sent.
      10-18-2019, 12:27 PM   #14979
StredTech
Drives: BMW 420d xDrive
Hello
I've recently bought a F36 420d xDrive Gran Coupe - I'm assuming the cheat sheet still applies etc?
If someone could link me to the latest and greatest for the software it would be appreciated, going to build my cable this weekend
Thanks!
      10-18-2019, 12:36 PM   #14980
shawnsheridan
Originally Posted by StredTech View Post
Hello
Thanks!
ENET Cable is now readily available for less than $20 USD. Why anyone would build one, even if they had parts laying around, escapes me. PM sent.
      10-18-2019, 11:13 PM   #14981
colin.t.chiang
Drives: 2016 330e
Hi Shawn,
Can you please pm me the latest links?
TIA,
Colin.
2015 320d and 2016 330e.
      10-18-2019, 11:22 PM   #14982
shawnsheridan
Originally Posted by colin.t.chiang View Post
Hi Shawn,
TIA,
Colin.
PM sent.
