02-28-2021, 12:03 PM | #46 | |
1296
Rep 3,533
flashing the car back to stock will give you the trans flash you had before. it's tied to your vin. yes the stage 1 flash would be what you want. if you have questions, ask xhp. they are the people to talk to.
02-28-2021, 12:45 PM | #47 | |
Rep 7,602
02-28-2021, 12:47 PM | #48 | |
Rep 7,602
02-28-2021, 01:04 PM | #49 | ||
1296
Rep 3,533
02-28-2021, 01:24 PM | #50 |
Rep 7,602
These have nothing to do with adaptations. Its XHPs programming and the way it changes the delay between pulling a paddle and changing the gear, based on which modes you are in (i.e., XHP has a larger delay than stock programming in comfort/D). I haven't personally tested stage 1, but even on stage 3 the delay is there, so i doubt stage 1 would be faster in that regard.
F20_M135i100.50 |
02-28-2021, 02:30 PM | #51 | ||
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
02-28-2021, 03:38 PM | #52 |
Rep 419
The delay is alleviated a bit in comfort by going into DTC with just a single button tap as we've discussed before. Of course not everyone wants to do that when they want those faster shift times in comfort but I've grown to like the interesting middle option still being in comfort and being able to get a the normal slower shifts if I'm just cruising or a bit quicker ones without going into sport / sport+. Of course I understand again some would rather it not be the way it is but I trust XHP's knowledge on that decision.
02-28-2021, 07:15 PM | #53 |
@_sunbish
282
Rep 611
I'm having issues logging into xHP as of a few weeks ago. If I remember correctly it shows my vin registered but it doesn't let me choose anything on the home screen, which isn't fully loading because nothing is clickable. I know my cables work because I can connect to BM3. Anyone experience similar issues?
02-28-2021, 08:52 PM | #54 | |
1296
Rep 3,533
03-04-2021, 06:51 PM | #55 |
@_sunbish
282
Rep 611
That wasn't the issue. I'm not sure what was, because I didn't change anything the other day but it loaded the app without an issue. Now the problem is that it won't take the custom shift maps I have entered for whatever reason. I know it took the flash because I did choose the option to start in 2nd gear when the gear selector is on D and start in 1st when the gear selector is in M/S.
Lmao I was typing this I was reading the note in the "MAX RPM" section and it clearly states 'Settings for kickdown active will stay stock'. So is there anyway to override this kickdown switch and make it shift at the desired shift point? |
03-04-2021, 10:26 PM | #56 | |
Rep 7,602
03-05-2021, 11:25 AM | #57 |
Rep 114
My experience with Xhp is that after running an e30 tune for about a month I switched back to a regular pump gas tune and there was a light hang between the gears when it was about half throttle in sport mode almost felt like someone was tapping the breaks ever so slightly.
03-05-2021, 11:45 AM | #58 | |
Rep 7,602
03-05-2021, 10:36 PM | #59 | ||
Rep 114
03-06-2021, 12:39 AM | #60 |
Rep 7,602
03-08-2021, 02:12 AM | #61 | |
Rep 114
05-09-2021, 09:12 AM | #63 |
1296
Rep 3,533
no
05-10-2021, 01:46 PM | #65 | |
Rep 7,602
05-10-2021, 04:15 PM | #66 | ||
1296
Rep 3,533
