BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Super Cheat Sheet - PDF Attached! [Updated July 1st, 2015]
      08-26-2014, 10:08 AM   #45
Halsifer
Halsifer's Avatar
Drives: 2018 Audi RS7
Originally Posted by botho View Post
Hy Halsifer,
Thanks for this cheats compilation.
My car is a F31 2014/06 xDrive 330d Luxury.
Here are some tests and results :
HU_NBT, 3000, NAVI_FLIGHT ==> can’t find this in my CAFD_00000DED_003_009_015.ncd
HU_NBT, 3000, NAVI_AUTOZOOM ==> In right pane i see the new check box option but it’s grey
EGS, 3000, Applikation_LC ==> can’t find this in my CAFD_0000023F_016_016_029.ncd (but i have EGS, 3000, LC which seems to be the good one)
FEM_BODY, 3110, ASP_MAX_GESCHWINDIGKEIT_BEIKLAPPEN (Maximum speed the mirrors are allowed to fold) ==> I can’t have it to run ??? (tested Werte=FF or Werte=32, no effect, it closes under 40km/h)
HU_NBT, 3000, ASD_SOUND_OFF ==> Why trying to play with ASD on F30/F32 ? is it really work ?
HU_NBT, 3000, ASD_CONFIGURATION and HU_NBT, 3000, ASD_SOUND_4 ==> work, a new entry in NBT configuration bu can(t do anything ==> useless
HU_NBT, 3000, SL021_IBA_3 ==> you’ve done a mistake, it’s SL21_IBA_3
To be tested section :
HU_NBT, 3003, TIMESTAMP_DISPLAY ==> doesn’t work for me
This is awesome. Thank you for all the feedback and testing. Will be included in the next update!
Originally Posted by Steve_M_Sport View Post
I will pay good money to someone who can work out how to illuminate the white dashboard lights during the daytime for an F31
Doesn't it already illuminate white during the daytime?
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP
2010 Audi S5 4.2L [Sold]
2014 BMW 335i xDrive M-Sport [Sold]
2010 Audi A6 3.0T [Sold]
      08-26-2014, 10:15 AM   #46
Steve_M_Sport
Steve_M_Sport's Avatar
614
Drives: U06 230e Active Tourer
No it doesn't unfortunately. I had a 2010 F11 before the F31 and that had white dials illuminated during the day and orange at night. The F31 has no dashboard daytime illumination but orange lights at night.
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport
      08-26-2014, 10:51 AM   #47
Halsifer
Halsifer's Avatar
You know what, I'm an idiot. F3x's don't have a daytime backlight, so it cannot be coded in. I'll remove it next update. Sorry about the confusion.
2018 Audi RS7 4.0T
      08-26-2014, 11:19 AM   #48
Steve_M_Sport
614
Thanks - that explains why no one has been able to help with the coding - if it is impossible due to the F31 not having a daytime backlight then I will now stop looking for the solution.
Steve
      08-26-2014, 11:58 AM   #49
botho
France
Drives: 2014 F31 330d xDrive Luxury
Halsifer
Before upgrading your paper, concerning NAVI_AUTOZOOM, I need to do some extra test.
I only test in 3D mode and I want to verify if this work or not in 2D mode....
Regards
      08-29-2014, 02:30 PM   #50
Ganxxta
Drives: F32 4er Coupé
Also an Update from my side what works or not for F32:
Daydriving_light-> standard: works, setting is displayed and works
MAPPING_STANDL_V_L_PWM_LEVEL_1
MAPPING_STANDL_V_R_PWM_LEVEL_1 :Both not available
BC_DIGITAL_V: Works
BMW_LOGO: MPM doesn't work, M50d is shown
HINTERGRUND_FARBE_NACHT
HINTERGRUND_FARBE_TAG: Both not available
FH_TUERAUF_STOP_MAUT: works
KOMFORT_SCHLIESSEN:works
TCM_LOGIC_R_OFF_DOOR: works
M_VEHICLE: works
NAVI_AUTOZOOM: setting is shown but not selectable
FLA_AUTO_AKTIV: not available
HVAC_POPUP_AUTO_TOGGLE
HVAC_POPUP_SEATCLIMATE
HVAC_POPUP_AIRDISTR: all 3 don't show up
BC_MOTORTEMP_ENABLE: image is displayed, but no values-> doesn't work
ASD_CONFIGURATION
ASD_SOUND_4: Shows "Mini Sound Design", options not selectable
      08-29-2014, 03:07 PM   #51
Steve_M_Sport
614
That is very interesting and maybe what I have been looking for to turn the dashboard lights on during the daytime in my F31. I found DAYDRIVING_LIGHT in HU_NBT Section 3000 and mine is set to perm_off.
The other options are perm_on or standard - I will give this a try in the morning and fingers crossed it works
      08-30-2014, 03:19 AM   #52
Steve_M_Sport
614
Further research shows DAYDRIVING_LIGHT is for the DRL on/off option in Settings/Lighting
      08-30-2014, 03:50 AM   #53
Steve_M_Sport
614
Anyone know what this does ? Mine is set to nicht_activ
3000 Anzeige_Konfiguration, 32 > HINTERGRUNDBILD_ENABLE
Kommentar=VORHALT hinsichtlich kuenftiger Aenderung:
Entscheidet, ob das Hintergrundbild im Kombi dargestellt wird
Translation:
Comment = Lead respect kuenftiger change:
Decide whether the background image is shown in the Combined
What background image?
      08-30-2014, 08:04 AM   #54
Ganxxta
Apparently thats a flag to allow showing a background image in your instrument cluster, I suspect that might be used for the full blackpanel clusters like in the 7 Series etc. or they maybe wanted to put an ///M as background.
You can try but I doubt you will get any results.
      08-30-2014, 10:44 AM   #55
Steve_M_Sport
614
Ok thanks - not worth risking it so will give it a miss.
Although someone with an F32 has the option set to standard rather than nicht_activ ? What difference is there from an F32 to an F31 I wonder ?
      08-30-2014, 10:56 AM   #56
Halsifer
Halsifer's Avatar
Halsifer
Regards
Sweet, thanks. I have my car back so I'll give this a shot today.
BC_DIGITAL_V: Works
M_VEHICLE: works
ASD_CONFIGURATION
Perfect, thank you for trying these out. I'll mark them down next update.
Correct. This it the second code on the cheat sheet in Angel LED Brightness.
I believe this is for enabling or disabling the lines at the bottom on the instrument cluster screen. It is meant for F10's because they have these little accent lines.
2018 Audi RS7 4.0T
      08-30-2014, 03:28 PM   #57
fea30boy
fea30boy's Avatar
Drives: F30 320i
Tried the ASD_CONFIGURATION and ASD_SOUND_4 too in my F30, appears the mini sound in configurations, but as said before none selectable.
The only things that took me thinking in ASD is that the ASD_SOUND_1/2/3 was already set to AKTIV
      09-01-2014, 06:04 PM   #58
beppeM3+123d
beppeM3+123d's Avatar
205
Drives: bmw m3 dct + 123d e81
Thank you so much for this great file.
I want to share that on my f32 mpm on kombi, bc speed, door light on reverse gear, shut off radio on opening driver door, s&s memory function perfectly work.
But on Kombi 3001 no hintergrund function are available. Hintergrund is available with search on 3000 but other strange value nothing similar to a color selection!
I have a question about Led intensity setup: i would like to set value 100% 64 for front led circle in position 1 of the switch light, in this way i will get easy taillight already on! And on position 0 i get the only front led light on( plus i will code on NBT the flag of DrL to eventually switch off).
Can sombody help me to find position 1 coding values?
In the end: is it possible to add on Nbt modul the Bc speed flag for kombi like all other flag like date, eta, ecc?
Thanks in advance!
      09-01-2014, 08:21 PM   #59
cryptz
Drives: 2015 m4
does anyone know if the following is disabled? my hud changes from white to orange at night. i realize i do not have white lights behind the cluster during the day. i have messed with this setting but it seems to make no difference on my f32, it always changes to orange at night on the hud. also the general items on kombi come on white but fade to orange quickly with these settings altered.
KOMBI 3007 DIM_NACHT_EIN werte = FF werte = 32 Changes orange night colors of KOMBI to be white at night (No Navi Night Switch too)
      09-03-2014, 03:02 PM   #60
Halsifer
Halsifer's Avatar
Updated to v1.4 (9/03/2014 12:45PM PST): (Download in the original post as an attachment)
  • Added Section: 'INEFFECTIVE OR UNAVAILABLE CODES'
  • Added Code: 'VOL_MAX_ON' - Retain volume setting up to 100% at vehicle startup
  • Added Code: 'MEMORY_UMLUFT' - Remember Air Re-Circulation Setting from previous shutdown.
  • Changed Description: BMW Logo - '(Not working on updated cars.)'
  • Fixed: Launch Control code - Added both Function Names to Code
  • Fixed: Description in 'General Locking/Window Features & Convenience Features' section. (Explained how ASP_MAX_GESCHWINDIGKEIT_BEIKLAPPEN and ASP_GESCHWINDIGKEIT_AUTO_AUSKLAPPEN are dependent on each other.
  • Moved to Testing Codes: NAVI_AUTOZOOM - Users appear to find this unable to be selected.
  • Moved to Testing Codes: HINTERGRUND_FARBE_NACHT & HINTERGRUND_FARBE_TAG - Users unable to find these codes.
  • Moved to Unavailable Codes: FLA_AUTO_AKTIV
  • Moved to Unavailable Codes: HUD_TLC_ENABLE
  • Moved to Ineffective Codes: HVAC_POPUP codes
  • Moved to Ineffective Codes: ASD_CONFIGURATION
  • Moved to Ineffective Codes: BC_MOTORTEMP_ENABLE
  • Verified Code: ROAD_EDGE_WARNING_ENABLED -> Moved to 'Safety Features & Precautions'
If anyone decides to test out the codes in the 'TO BE TESTED' section, and finds out if it works or not, please let me know! :thumbup:
2018 Audi RS7 4.0T
      09-03-2014, 04:47 PM   #61
hmc
Drives: 2013 320i ZSP+ZMT
One more addition:
"FEM_BODY 3050 FH_TUERAUF_STOP_MAUT" only enable front doors.
In order to enable rear doors, you need to code "REM 3050 FH_TUERAUF_STOP_MAUT"
      09-03-2014, 04:48 PM   #62
Halsifer
Halsifer's Avatar
Originally Posted by hmc View Post
One more addition:
Good to know. I'll add that in quickly. Thanks!
2018 Audi RS7 4.0T
      09-06-2014, 07:24 PM   #63
KGB_123_99
Drives: '17 330ix M-Sport, '09 528ix
Hi folks,
Quick question about coding cornering lights. On the cheat sheet I see that I need to set all relevant values to aktiv. However, when editing my FDL I see the options in the image below.
Which one should I choose?
      09-06-2014, 07:32 PM   #64
Halsifer
Halsifer's Avatar
Originally Posted by KGB_123_99 View Post
Hi folks,
Oh, sorry about that. I'm pretty sure you'd choose F030enable.
2018 Audi RS7 4.0T
      09-07-2014, 07:42 AM   #65
capt_slow
capt_slow's Avatar
Drives: 2017 F31 328d
I just toggled the following on NBT_H:
HU_NBT/3000/AUTO_MAP_ZOOM
HU_NBT/3000/NAVI_AUTOZOOM
Cant find any menu options for autozoom nor will it automatically zoom during route guidance.
I did notice that once guidance has started, the nav will zoom out to show the route preview and then zoom back in to current location. I think this is part of new NBT software rather than those two options.
EDIT: Nevermind, I *think* autozoom is working now. The functionality only shows up on the Navigation split screen.
      09-07-2014, 05:32 PM   #66
KGB_123_99
Thank you for this great compilation of all the codes, Halsifer.
This is a great document so if you end up finding new coding possibilities, I hope you will keep on updating the cheatsheet!
I managed to code everything I wanted except BMW Live. I read on another post that perhaps it's not as simple as just activating
