BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > '17 340i xDrive Roadmap
      01-18-2018, 02:28 PM   #1
rockymtnpilot
Drives: 2017 BMW 340i
Hey guys, I got bit by something the other night. So far the only side effect is the overwhelming urge to blow cash on my car that I could use for, idk, food/water/shelter/etc.
Here's the roadmap in chronological order I've drafted for blowing said income. Feedback is appreciated. For reference I have the 2017 340i xDrive with 6MT and MPPSK.
- BMS Billet intake
- Catted DP (either DS-1 5" or the ER 4.5")
- Possible JB4 over the top of it all
- Maybe...MAYBE WMI after all is said and done
Mostly I need to hear pros and cons for the DP. Thanks in advance!
2017 340i xDrive
MPPSK
More to come
      01-18-2018, 04:27 PM   #2
wassy4
Drives: 2016 340i
- BMS Billet intake
Do JB4 first, then downpipe, then intake, then every other mod you want to do.
Intake doesn't really give you a noticeable gain and the induction noise will not be loud until you are tuned and pushing more boost.
Pros of downpipe:
- Faster turbo spool and increased throttle response
- Louder turbo spool
- Slightly louder exhaust note and burbles (much louder on WOT)
- Close to 15-20whp gains with catted
Cons of downpipe:
- Risk of CEL (easy fixes available so this is a moot point)
- Slight gas smell
Gas smell is really not bad at all, especially with a catted dp.
Current - 2018 M2 | VRSF Chargepipe | VRSF Catless Downpipe | Dinan Catback | Turner Motorsports Intake
Previous - 2016 340i M-Sport | AWE Tuning Touring Edition Exhaust w/ Non-Resonated Performance Mid Pipe | Agency Power Intake | Active Autowerke Activ-8 | VRSF Catless Downpipe
      01-18-2018, 05:31 PM   #3
rockymtnpilot
- BMS Billet intake
Pros of downpipe:
Cons of downpipe:
- Slight gas smell
I already have the MPPSK remap and exhaust which is why I was inclined to do the JB4 last. As far as the DP go, I'm looking for a comparison between those two different ones. I'm thinking the extra .5" between them might be nonconsequesential.
2017 340i xDrive
MPPSK
More to come
      01-18-2018, 05:33 PM   #4
wassy4
Drives: 2016 340i
- BMS Billet intake
Pros of downpipe:
Cons of downpipe:
- Slight gas smell
The .5 doesn't really matter but isn't the CG cheaper?
      01-18-2018, 06:27 PM   #5
rockymtnpilot
It's about $140 more
2017 340i xDrive
MPPSK
More to come
      01-18-2018, 09:40 PM   #6
G.Newt
Drives: CT4-V Blackwing 6MT
If you're deciding between downpipes, I'd go with the CG. I haven't heard of any CEL lights and it's also the widest DP.
Also, I wouldn't recommend JB4 first as he's MPPSK, and likely closer to the ubiquitous "fuel limit/cap". The intake/DP might add another 15-25. The other argument is that he's not getting maximum gains for the intake/DP w/o JB4.
I dyno'd 344hp/355 torque, then 333hp/375 torque with just CG DP, intake, and catback exhaust. So there are some decent gains to be made even w/o a tune.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      01-18-2018, 09:48 PM   #7
wassy4
Drives: 2016 340i
He didn't make it clear that he had MPPSK so it changes things a little. To OP, you could also look at JB+
      01-18-2018, 10:34 PM   #8
rockymtnpilot
I wonder if instead of raising the fuel cap you could spoof it into thinking it's delivering less than it is. Guess it doesn't matter. I'm not trying to make my daily insufferable.
2017 340i xDrive
MPPSK
More to come
      01-19-2018, 06:37 AM   #9
jalkster
Drives: X3MC
If you plan on going meth eventually, go catless. If not then the CG will be fine
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T
      01-19-2018, 09:08 AM   #10
Bullitt1841
Drives: F36 B58
I have MPPSK and the first thing I did was JB4. It's the smartest thing to do because you can start logging and learn how the car behaves and reacts to different things. I'm also partial to the JB4 because I put 120,000 miles on my last one with my N54.
Forget the JB+ on the MPPSK. It WILL drive worse, and without logging you won't understand why.
I also have a BMS intake and meth kit, but that came after many months of logging and learning how this engine worked.
      01-19-2018, 11:10 AM   #11
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
Don't you guys worry about the heat with that short intake? I dunno if I'd want that on my _turbo car in the summer ... definitely not for a track day. So hot.
I do want the turbo spooling induction noise though. I can't hear this thing at all. I'm really tempted to do the classic ricer swiss cheese airbox mod and go drill a couple holes. I won't though .. but I really want to.
      01-19-2018, 08:03 PM   #12
G.Newt
http://www.n54tech.com/forums/showthread.php?t=23993
Terry already proved this is not the case with N54 engines. The "ending" temp was actually a few degrees cooler with the intake vs the stock airbox.
      01-19-2018, 09:18 PM   #13
B58 parts
B58 parts's Avatar
that's terrific ... I didn't know the 340 had an N54 ...
      01-20-2018, 01:37 PM   #14
rockymtnpilot
Points for sass
2017 340i xDrive
MPPSK
More to come
cmplaya211.50
      01-26-2018, 08:57 PM   #15
rockymtnpilot
I just ordered my JB4. I'll make an appointment with the dyno once it comes in and provide data
2017 340i xDrive
MPPSK
More to come
