05-14-2021, 12:41 PM | #1 |
Cheapskate
4450
Rep 4,993
"HPFP Crashing" Explained
"HPFP Crashing" is becoming a trigger word for B58 owners but luckily it's something that can be identified in logs and is typically fixed pretty easily. Check out the video for the lowdown.
05-14-2021, 01:42 PM | #3 | |
Cheapskate
4450
Rep 4,993
blacksapphire440i303.00 |
05-14-2021, 08:17 PM | #5 | |
Rep 19
kern4174449.50 |
05-16-2021, 04:19 AM | #8 |
2JZ-GTE
3045
Rep 3,996
I think it's 19 pounds, stage one is 17.2 psi
05-17-2021, 08:37 AM | #9 | |
Cheapskate
4450
Rep 4,993
it's a monitor for the hpfp piston travel. it doesn't control pressure or flow. |
05-17-2021, 04:00 PM | #10 |
Rep 282
the travel of the piston is fixed by the cam lobe .
the electrical connection to the hpfp is actually a fuel quantity valve . if its just a monitor , how is pressure regulated within the rail ?
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
05-18-2021, 08:52 AM | #11 | |
Cheapskate
4450
Rep 4,993
Edit: Ok I'm seeing what you're referring too. What I was trying to clarify was that people thought it was the fuel pressure sensor and that's not the case. I'll add some clarification to the video.
05-18-2021, 04:03 PM | #12 |
Rep 282
to me its still a closed loop
with the pressure sensor reading the pressure and the dme controlling the valve on the hpfp trying to maintain the required pressure in the tune . whenever your see dips in your logs logs , the valve is at duty cycle 100 and no more fuel can be supplied to the rail in order to maintain the pressure therefore you will need an upgraded hpfp with a bigger piston .
05-19-2021, 07:17 AM | #13 |
Cheapskate
4450
Rep 4,993
right, and my understanding was that it is monitoring flow not controlling flow. so i'll need to add some clarification in the video
07-30-2021, 12:37 PM | #14 | |
Cheapskate
4450
Rep 4,993
540iSUP704.00 |
