02-23-2015, 12:13 PM | #89 | |
Rep 900
I actually find it a little hard to engine brake effectively with these 8-speed transmissions. There are so many gears. My old Explorer has a 4-speed automatic with a push-button overdrive, I can come all the way down from Summit County sometimes without using my brakes too much at all.
-Will
2013 535i xDrive M-Sport | 2005 545i Sport (Retired and missed) | 2001 X5 3.0 Sport (Retired) |
02-23-2015, 12:35 PM | #90 | |
Rep 2,210
Drives: '17 jackrabbit on crystal meth
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
02-23-2015, 01:20 PM | #91 | |||
Rep 693
What is the point? It's like telling Albert Einstein to prove his theories, but he's not allowed to use math. Why not just give the AWD summer tires and prove your point even more? LOL In any scientific test one must eliminate as many variables as possible. In a test with RWD+snows and AWD+ AS, you have two variables, so you can not test a single difference. As you said, ultimately it is the tires that decide traction (the drive wheels in use decide how if at all that traction is used), so if you are trying to decide if RWD is better than AWD in the snow, but purposefully hampering the traction devices as a variable between the two........you arrive at a flawed conclusion. Granted, the Audi system is better than BMWs unless of course you are on a solid ice sheet where the torsen is weak and the direct drive is not, but again, would you rather have an AWD that is slow to react but DOES react? Or a RWD that can not react at all? Quote:
Just takes practice, obviously dumping 3 gears at once, while not locking the wheels, will cause traction loss for a short time at least. Figuring out the good RPM to drop a gear just takes practice. Quote:
As for price, shall we talk comparison? As you stated a 4K TV doesn't cost $57k, it cost what $2k? And good cables easily $100-200 (gold plated, thick). So roughly 10% of the cost of the prime component. What percentage is $800 of $57k?
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded) 2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O 2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O 1983 Porsche 944 All stock |
02-23-2015, 01:37 PM | #92 | |
Rep 3,947
As for the Torsen, isn't it only weak if one wheel has virtually no friction? (Torsen requires all tires have some level of traction - not free spinning.) If all the wheels are on ice, then they would have similar traction across the board. Obviously you could have a system that applies brake to the wheel that is free spinning to get moving - it just wouldn't be a "performance" solution. Isn't this the case with the xDrive anyways because it as open front and rear differentials? |
02-23-2015, 02:45 PM | #93 | |
Rep 2,290
02-23-2015, 04:13 PM | #94 | |
Rep 3,947
The bottom line is you need to reconsider going down a hill where your brakes cannot effectively stop you in an emergency. It seems like the cases where you need AWD, and RWD won't cut it have been the following fringe/outlier cases: 1. Some guy claiming to have a drive way allegedly with a 40% grade. (Even a Humvee which has ridiculous gearing can only climb a 60% grade in perfect conditions/surface with the transfer case in LOW.) Yet, somehow a AWD xDrive 3 series can climb that 40% grade driveway in deep snow/ice. 2. You are descending down a long hill that is SO long that it will cause you to get brake fade under constant light and medium braking force. (Think about how hard you have to drive/brake on a track to get brake fade). Last edited by Polo08816; 02-23-2015 at 04:28 PM.. |
02-23-2015, 06:22 PM | #95 | |
Rep 596
Trust me, I did this last year with my 335xi and I was too lazy/cheap to get winter tires. It was a horrible experience in upstate NY winter.
2013 BMW 335i xDrive Sport Line
02-23-2015, 07:57 PM | #96 | |
Rep 1,370
Now lets watch Buddy and his amazing 500hp awd gtr and no snow tires flail around like an idiot because he spent 100k on a car and couldn't be bothered to spend 1% of that on snows Last edited by casualDIYer; 02-23-2015 at 08:04 PM.. |
02-23-2015, 08:10 PM | #97 | |
Rep 3,947
It's always laughable when you see an expensive branded car do a complete 360 on a residential street when it snows. People tend to not want to help out someone who spent $100k on their car and couldn't to be bothered to spend less than 1% of that cost on proper tires than someone who lives way more modestly and has trouble getting up a hill in a Honda Civic. Don't be that guy! The guy with an expensive car spinning his tires and going no where because he failed to plan and prepare. |
02-23-2015, 08:19 PM | #98 |
Rep 1,370
Any drive system on snow tires is better than all seasons. You're headed down a snowy hill. A kid runs out on the street. Now, how is AWD, FWD, or RWD going to make a difference? You only need to hit someone once with your car to make a tragic difference. In snow, snow tires are the way to go.
02-23-2015, 08:23 PM | #99 | |
Rep 3,947
02-24-2015, 10:15 AM | #101 | |
Rep 900
Not only is it better for control on slippery roads, but it also saves the brakes - there's nothing worse for them than being ridden down a long descent for the purpose of bleeding off speed. Generally, I don't go around town using engine braking rather than my brakes though.
-Will
02-24-2015, 10:16 AM | #102 | ||
Rep 693
Again, people who are biased will weight the discussion in their favor instead of opening their mind and admitting what they don't know. You are correct on both parts, torsen requires at least some traction, on a solid sheet of smooth ice, traction will be basically zero as the system goes from a little traction to no traction and back and forth. It would struggle in this rare situation. The xDrive is not the best performance solution as it operates as you stated, with open diff's and brake controls. Both are very good in the normal snow conditions you will find with the xDrive being better in just that one situation of nearly zero traction with torsen winning out on the track. Quote:
Perhaps you should open your mind (and your wallet), get some snow tires for snow and see how well the AWD does with the proper equipment. Or just continue spewing uninformed rants on the internet.
02-24-2015, 10:42 AM | #103 |
Rep 354
I have been following all 5 pages of this. Here is my input, for what it is worth. I have a E93 335is, which is on winter tires (on its 3 season, they need to be replaced for next season - my 335is as a total of 36k miles, winters on from nov-ar every yr). I also have a F30 328i xdrive which up to this week was on pretty much worn out all-seasons (had 32k miles on the tires/car up until 2 weeks ago).
The xdrive with worn out all-seasons out performed my 335is in the winter snow. I live on the side of a pretty steep hill where I would have to turn off my DTC for the IS and spin my way up the hill, where the xdrive had no issues, no slippage at all even with 32k miles. 2 weeks ago, I got a right rear blow out from a nail. I replace my 328ix with dedicated winters , it feels invincible. Granted new winters will feel better than used winters but i know the AWD all seasons were already outperforming my winters in the RWD. I hope I am wrong, I am going to take a job that requires a commute through mountains and in my heart I don't want to give up my 335is, but i also know that a AWD vehicle is the way to go. Maybe the community knows what is a good AWD vehicle to my IS, I am thinking either a Golf R or Audi TTS... help!? |
02-24-2015, 11:07 AM | #104 | |
Rep 3,947
But again, how do you define "outperforming"? If you're talking about forward traction in deep snow, then yes, AWD is pretty good at that. If you're talking about driving on a highway with hard packed snow during a commute, then any car with winter tires will "outperform" a car without winter tires because there is way more control at speed. Last edited by Polo08816; 02-24-2015 at 11:21 AM.. |
02-24-2015, 11:10 AM | #105 |
Rep 900
Mine as well, though the just-announced Mercedes C450 AMG looks interesting too. Go read about it before you poo-poo it for being a Mercedes.
-Will
02-24-2015, 12:09 PM | #106 | |
Rep 2,802
.....and BRAKING. Well said. |
02-24-2015, 12:22 PM | #107 | |
Rep 693
An AWD with snow tires will outperform a FWD/RWD car on snow tires everyday of the week in any situation you devise. Starting, stopping, and turning. Sitting in stop and go traffic is a pointless device as clearly, outside any other occurrences creeping along at 5mph the difference between types is minimal. But if that is the defining situation to determine our car choices, why are we not all in Honda Civic's? Or Kia Rio's even? The difference between ANY car in that situation is minimal. Going AWD is for those times when you can open it up, or the weekend trips, or anything else that we do in our cars. I mean, seriously....do you guys spend your entire life in stop and go bumper traffic? LOL Eh, going in circles at this point, to each their own. I will continue to recognize and enjoy the benefits and enjoyment AWD offer. Others are welcome to learn and grow, or not.
02-24-2015, 03:43 PM | #108 |
Rep 119
My input:
I'm in North Texas, and as the "northerners" know, we are f'ing clueless on how to drive on snow and ice. We got about 1/2' to 1" of SLEET Sunday night into Monday morning. That type of event shuts down this part of the country - schools closed, businesses closed, etc. I have a 2015 M3 with Pilot Super Sports - no way IN HELL did it leave the garage. However, I also have a 2009 328 xDrive coupe that we got in late December. I put Bridgestone Potenza all season run flats on it last month, and it handled literally EVERYthing that I could throw at it. Granted, we're talking about only an inch of ice, but starting, stopping, and even a bit of drifting was not problem at all. I was really impressed with the little xDrive coupe and what it was capable of out in the ice....We're expecting snow tonight and into tomorrow morning. My poor M3 is getting lonely in the garage.... |
02-24-2015, 05:08 PM | #109 | |
Rep 1,370
02-24-2015, 05:11 PM | #110 |
Rep 1,370
