05-03-2017, 07:09 AM | #1 |
Rep 3,030
Do my wheels stick out too much?
Hey guys I can't seem to make up my mind on whether or not I leave these as is or go with something else. I picked up these oem E60 style269 rims a few weeks ago for a hell of a deal...
I don't plan on lowering my car (yet...) so I'm not concerned about tucking but what do you guys think? I was going to see if I can adjust the camber out to taper the wheels in a tad. Open to your suggestions! My rides an xDrive model Wheel specs: Front 8.5/19 ET18 Back 9.5/19 ET32 Tire specs: From225/40/R19 Back 255/35/R19 The poking out is not unlike the guys fitting 437 M4 wheels on their stock suspension Fxx's.
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= Last edited by 7iM3less; 12-22-2018 at 12:56 PM.. |
05-03-2017, 07:14 AM | #2 |
Rep 3,030
First photo shows the rear
Second photo shows the front
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
05-03-2017, 08:11 AM | #3 |
Rep 381
As long as it does not rub what is the difference its your car, your preference.
2020 M550 bsm cognac 668 20's M-performance rear diffusor
05-03-2017, 08:13 AM | #4 | |
Rep 2,639
05-03-2017, 08:56 AM | #7 | ||
Rep 3,030
Thanks! Agreed on the satellite dish. Mines actually not even functional anymore. I just haven't had time to get up there to take it down.
2016 BMW F80 ZCP
05-03-2017, 08:38 PM | #10 |
Rep 3,030
Will putting coilovers or springs void the CPO warranty?
2016 BMW F80 ZCP
05-03-2017, 10:25 PM | #11 |
Rep 2,639
Just the suspension side of the warranty unless you get dinan springs.
Any other suspension parts other than dinan will void just that part. Basically how BMW works is, whatever part you replace, the warranty is voided for that part and the part it connects to. If something breaks, they have to prove that part is the cause. |
05-15-2017, 07:40 AM | #12 |
Rep 325
Drives: 2016 F36
Regardless of future plans on closing the gap or not, my point of view it's perfect. You're right at the point on changing the look to most drivers who will notice your ride looks aggressive but subtle enough that they can't pinpoint why it looks so good. You can tell best by getting in a friends car at driver level, one car length behind yours and look at her @$$. If you are happy about it keep it....as others said it's your opinion that matters.
◊ 2016 F36 xDrive N26 ◊ Black Sapphire Metallic ⁞ Dakota Black ◊
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ |
05-17-2017, 05:48 AM | #13 |
Rep 212
Looks great sir!
05-02-2019, 03:08 PM | #14 |
Rep 30
Sorry to resurrect an old thread, but...
You actually shouldn't have any poke out occurring. For the rears, you have 19x9.5 ET32 on the OEM 255/35R19 tires. Guys on here have been recommending 15mm spacers for the rear on OEM wheels. That would give: ET47 (OEM) - ET15 = ET32. Which equals the ET on your spec. It shouldn't poke out but should actually be flush with the fender. Now, the front ET18 will give a poke since, for OEM, ET26-24 would be flush with the fender. |
05-02-2019, 03:43 PM | #15 | |
Rep 3,030
I'm running 405's now with 10/15 spacers and the fit is spot on.
2016 BMW F80 ZCP
05-03-2019, 02:23 PM | #16 |
Rep 30
05-10-2019, 01:04 PM | #17 | |
Modder of everything I own
147
Rep 491
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
