04-22-2019, 07:51 AM | #1 |
Rep 433
Tire pressure: Which source to believe?
This weekend we had a couple of cool mornings. On checking the TPMS before driving yesterday, I see it reads 30 psi in each tire. So I plug in the air pump and air each tire up so that the analog gauge appears to read about 38, and check each with my pencil gauge, which gives about 36-38. Imagine my surprise when I re-enter the car and TPMS tells me each tire is now at a big 32!
Which data source do you believe? I'm impressed with BMW's trip computer, for example. The fuel consumption since I reset it at my last fill-up said 26.6, and darned if that wasn't *exactly* the figure I got when I calculated the fill-up Saturday. So I'm inclined to think the TPMS might be pretty accurate. But my other two sources report differently. If I follow the TPMS, I guess I'd have to air the tires up to a pump gauge reading of about 40 in order to have TPMS report 34, which is where I'd like the tires to be. (The door placard says 32 all around.) So which source do you rely on? Last edited by Wolfus Aurelius; 04-22-2019 at 07:58 AM.. |
04-22-2019, 08:38 AM | #2 |
Rep 2,432
Drives: 2021 M2C
I gotta go with what my car is telling me. You just need to trust it? :
04-22-2019, 09:01 AM | #3 |
Rep 1,502
Pencil gauges and the built-in gauges on air pumps can be very inaccurate. Get a high-quality gauge that’s been certified/calibrated (ANSI B40.1) to use as a reference.
I use this one, but pick your favorite: https://www.amazon.com/JACO-ElitePro...%2C192&sr=8-12 |
Lance_Goodthrust4.50 BEM-S44515.50 |
04-22-2019, 09:23 AM | #4 |
Rep 16,079
My gauge is on my inflator:
https://www.amazon.com/EPAuto-Heavy-...%2C1141&sr=8-5 It always agrees with my TPMS, and since it's part of the inflator there's no need to separately inflate and measure. |
04-22-2019, 09:28 AM | #5 | |
Rep 433
Sure, I can always pump the tires up a little higher, say to 40 on the pump gauge, check the TPMS, and let some air out if need be. I was wondering which source all of you go by. |
04-22-2019, 09:43 AM | #7 |
Rep 426
Doesn't the TPMS need a few minutes of driving to accurately measure, or is that the old style where it measured the difference in rolling diameter?
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
04-22-2019, 09:53 AM | #8 |
Rep 433
Right; I started up the car, but the display reminded me of that. So I drove a block or so, and then it reported 30 all around.
BeerHerder250.50 |
04-22-2019, 10:00 AM | #9 |
Rep 5,456
Drives: F30
My experience is very similar to OP...
Handheld gauges usually read a few PSI higher than what the car thinks the pressure is. I just keep that in mind while filling and checking tires. Reading through the lines... I guess that means we are using shitty, uncalibrated tire gauges? |
BeerHerder250.50 |
04-22-2019, 11:12 AM | #10 |
Rep 1,560
As others have said, if you want to really know the pressure in your tires get yourself a good accurate race gauge. The TPMS is designed to recognize a change in pressure and don't really need to be able to tell you the correct pressure, just a change in the pressure from when you last set it. Many off the shelf gauges are just toys, and won't be accurate. A good race gauge should be calibrated to be accurate.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
04-22-2019, 01:41 PM | #11 |
Rep 975
My analog gauge is usually only 1 or 2 psi higher than what the TPMS says.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
04-22-2019, 06:27 PM | #12 | |
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
chiefneil771.50 |
04-22-2019, 07:12 PM | #14 |
Rep 3,748
Tire pressure depend on what driver prefer. The recommended tire pressure on the car door card is manufacturer recommended for efficiency...this is how they get that mpg.
You can adjust to your preference. |
04-22-2019, 08:59 PM | #15 |
Rep 16,079
04-22-2019, 10:18 PM | #16 |
High Miler
29
Rep 44
What does reference pressure mean?
CTK
04-23-2019, 03:22 AM | #17 |
2JZ-GTE
3038
Rep 3,992
I have a nice Air pressure gauge accurate to +\- 0.1 psi which is about as accurate as da Costco tire nitrogen air which is always within +\- .5 PSi of my TPMS. My TPMS sensor always accurate plus or minus half a psi
04-23-2019, 07:05 AM | #18 |
Rep 16,079
The pressure that the TPMS uses as the baseline. It will give a warning when pressure drops roughly 4 PSI below that. If you have your reference pressure set at 35 PSI you'll get a warning when it drops below 31 PSI or thereabouts. You wouldn't want that if you normally run at 32 PSI, it would give a warning every colder than normal morning. To prevent premature warnings and insure timely warnings fill the tires to your normal cold tire PSI, then do a reset to establish that as your reference pressure.
kerny767829.00 |
04-23-2019, 07:59 AM | #19 |
Rep 4,876
04-23-2019, 08:57 AM | #20 |
Rep 529
Every car manufacturer will tell you their tire pressure numbers in their TPMS are approximate. Read your manual.
About 30 years ago I bought a real nice tire pressure gauge triple checked to be accurate. It's the bible. Every little idiot in the stealership with a pencil gauge is ordered away from the vehicle. Something you may find interesting about Honda's TPMS: I live at 9,000 feet altitude. My Honda Pilot's TPMS system get's tricked and can't compensate for the altitude. As a result, I have to drive around constantly with about 6 p.s.i. too much air in my tires so the TPMS system will think and read-out the "correct" tire pressure. It was that way in my 2007 Pilot and it's that way in my 2018 Pilot. (Japanese are a model of consistency). The BMW F32 TPMS system that lives right beside the Honda at 9,000 feet elevation, doesn't have that problem. But it also is a few psi inacurate compared to my gauge, as expected. podman |
04-23-2019, 03:21 PM | #21 |
Rep 166
Also part of the equation is checking cold tire pressure, then driving. Pressures go up quite a few lb's when warm. And if you're having a track day, you need to check it when hot.
Perry
2015 328i X-Drive, M-Sport, Cold Weather Pkg, Lighting Pkg, Premium Pkg, Harman Kardon, Black Grilles, Hands-Free, M-Perfomance side sills, X-Drive floor liners.
04-24-2019, 06:56 AM | #22 |
Rep 554
And all this time I've been believing that my little pencil gauge was what's to go by. Off to Amazon to buy one of those aforementioned race/calibrated gauges...
Boston CCA 383036
'20 M340i '18 MB GLS550 '07 4Runner V8 Limited 4WD |
