10-24-2018, 05:22 PM | #1 |
Rep 928
What size tires?
For 19x8.5 et +30 front and 19x9.5 et +35 rear? I would like most meat possible. I want to fit a 275/35/19 in the rear if possible rather than a 265? Up front I wanted a 245/40/19? Sitting on stock M-Sport suspension for now but will add coil overs in the future. Will those tires fit? I would like to stay away from 30 series tires.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
10-28-2018, 12:16 AM | #2 |
Rep 54
just put on 19x8.5 +32 245/40 and 19x9.5 +35 275/35 on factory sport suspension and fits fine no running with fully locked turns. will be doing h&r springs soon as well.
10-28-2018, 04:17 PM | #3 |
Rep 928
Sweet thanks for sharing. Do you have a pic? Those tires are slightly taller than factory right?
10-28-2018, 05:16 PM | #4 | |
Rep 26
'14 335i RWD FBO - VRSF Chargepipe - VRSF Downpipe - VRSF Intercooler – BMS Intake - NGK +1 Colder Plugs - BM3 Stage 2 e30 - JB4 w/EWG+bluetooth – Vertini RF1.1 19x8.5 +35 and 19.9.5 et 40 - Michelin 245/40/r19 and 275/35/r19
11-06-2018, 03:00 PM | #6 |
Rep 34,199
Hey, as an F30 owner myself I wouldn't recommend going wider than a 245 in the front. I ran a 19x8.5 and 19x10 using a 245 in the front and 275 in the rear. Going an wider than a 245 in the front will make it rub.
Have questions? Contact us below bmw@vibemotorsports.com. 800-814-8423 Ext 107 Ask for Tom https://www.vibemotorsports.com/wheels |
11-06-2018, 03:44 PM | #7 |
Rep 928
Thanks for the input. 245 sounds perfect.
11-14-2018, 07:44 AM | #8 |
Rep 928
The 275 was the biggest in the rear too I'll bet? Or would a 285 fit?
11-14-2018, 04:05 PM | #9 |
Rep 34,199
275 is the widest you can go without needing a spacer or running into issues of rubbing.
11-17-2018, 12:55 AM | #12 |
Rep 5,140
11-17-2018, 01:13 AM | #13 |
Rep 54
Thanks
Yeah the rear now rubs after H&R spring install. rear camber is maxed out at -2* will probably be switching to 235/40 and 265/35. I have MPSS as well which seem to run a bit wider. pics currently |
11-19-2018, 09:38 PM | #14 |
Rep 928
On the factory M-Sport springs there was no rubbing though? Probably didn't need to lower it with oversize tires huh?
11-24-2018, 03:39 AM | #15 |
Rep 54
no rubbing with stock sport suspension. yeah could get away with not lowering but i like it lower will be changing tires next week (235/40 and 265/35) as well to hopefully help with rubbing
11-24-2018, 09:39 AM | #16 |
Rep 178
Are you on H&r sports or super sports? Looking to go with a similar setup on my f32
BMW F32 428i BSM | KW V2 Coilovers | VRSF Catlesss Downpipe | Evolution Racewerks Chargepipe | Bootmod3 Stage 1 | Custom Borla Atak Exhaust w/ Quadtips
11-29-2018, 07:41 AM | #18 |
Rep 928
Got any pics of the 275/35 and 245/40 on the factory M-Sport suspension?
12-11-2018, 11:43 PM | #19 |
Rep 26
So I got my bilstein b8 shocks and struts installed with the H&R springs and when I take a hard turn or i go over a good bump/dip on the highway the back tires will rub. I will probably go with a 245/35/R19 and a 275/30/R19 when I get a new set of tires
12-14-2018, 07:25 PM | #20 |
Rep 928
I'm installing my 245/40/19 and 275/35/19 in 2 weeks on factory msport suspension. Might stay factory ride height with the taller setup and get koni fsc struts or bilstein b8's.
