10-26-2016, 02:46 PM | #1 |
Rep 55
Can coding affect your warranty
I am think about getting some basic coding done to my f31 , and was wondering if anybody ever had their warranty voided by BMW
Cheers Kenny |
10-26-2016, 03:40 PM | #2 |
Rep 32,881
FDL coding definitely will not as they can't even detect it. FA coding they can detect as it actually prevents them programming/updating your car, which I found out last week when they couldn't program my car because I had coded EBT. But they just rang me up and gave me the option of either them changing it back to standard (for £160!) or me changing it back.
Soul_Glo13343.50 |
10-26-2016, 03:49 PM | #3 |
Rep 3,216
It's one of those 'it depends' answers.
If you screw it up and brick your car, of course they won't cover you. If, on the other hand, the coding is absolutely nothing to do with the fault - for example you have a gearbox failure and all you've done is code EBT, then yes, your warranty will be intact. |
10-26-2016, 04:01 PM | #4 | |
Rep 55
10-26-2016, 04:03 PM | #5 | |
Rep 32,881
http://f30.bimmerpost.com/forums/att...8&d=1435767715 |
10-26-2016, 04:28 PM | #6 | |
Rep 55
10-26-2016, 04:55 PM | #7 | |
Rep 246
10-26-2016, 04:57 PM | #8 |
Rep 350
Interested to know this too.
Also like to know if the coding options are risk free?
Current - BMW 320D LCI M SPORT
Previous - BMW 320i XDrive M SPORT |
10-26-2016, 05:00 PM | #9 |
Rep 32,881
They fitted a new roof light control module, to try and fix the interior light problem, and they then needed to program (update firmware) all the cars modules.
10-26-2016, 05:02 PM | #10 |
Rep 32,881
11-14-2016, 09:58 AM | #11 |
Carl
20
Rep 73
I've just paid to have my 2015 F31 coded, this included:
- Stop/start off as default - Folding mirrors on lock/unlock - Fogs as welcome lights - Alarm beep option enabled - Digital speedo - DVD in motion - Boot open/close on keyfob - Enhanced bluetooth - Engine software update - Gearbox software update. I'm really pleased with all of the extra features unlocked and can notice the gearbox software update too (for the better), but reading this thread, I wanted to clarify with any of the coding experts on here if any of these codes will potentially give me issues with BMW should I need to go in for any warranty claims as the guy who carried out the work assured me it wouldn't and has not had any issues from any of his clients... |
hyakuhei50.00 |
11-14-2016, 10:28 AM | #12 | |
Rep 20,651
So the customer decided to load their own firmware to our hardware and not use the firmware we test, keep under config control, now their hardware is not working properly.... That's not a coding point of view, that's from a hardware warranty point of view in regards to firmware. |
11-14-2016, 12:06 PM | #13 | ||
Rep 9,097
Bmw launches those updates for improvement so I do not see that bmw has grounds to refuse the warranty work. They can say that all modules should have been updated to avoid issues though as that is recommended practice. But then there are many lazy dealers in London who only upgrade the modules which are absolutely necessary for the task / job. For those who are worried; 1- FDL coding is undetectable and you should not be worried. 2- VO coding for EBT / 2TB / 3AG, if you go for this then after coding the required module, reverse the changes in the VO otherwise dealer will struggle as in the case of teaston. As far as you keep your VO string to how it came from the dealer, you will be good. 3- updating modules / ecus such as engine or gearbox. You either do the complete car or leave them alone. Reason is that bmw can decline the warranty work if only few modules are updated. One example is that engine and gearbox are updated and will work to their optimal levels however dsc module will still be on old parameters which may / will leave some errors. These errors will not show on the dashboard but will be floating in the database and will be picked by the dealer.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
Soul_Glo13343.50 |
11-14-2016, 12:51 PM | #14 | |
Carl
20
Rep 73
However, the guy said none of his 800+ clients have ever had warranty claim issues and he only codes F model BMW's, so most still in warranty. Many of his clients are high end marks as well including his own M4. The gearbox and engine updates are BMW releases, but BMW did not do this when my car was in for a service last month. I mentioned this to the guy and he said they would only do the software update if parts were being replaced or I asked and paid for it.. I'm not sure if the guy has kept the original VO code, so I'm guessing I will struggle to get the car set back to default settings if I do need to go in for a warranty issue? Also, is it recommended I set it back to default settings if/when I take it back to BMW for an upgrade?? Cheers |
11-14-2016, 01:01 PM | #15 | ||
Rep 9,097
VO is a virtual spec sheet saved in your car. If you add anything which did not come from the factory, and bmw decides to do a warranty work and you car requires updating, then it can create some issues. However most dealers ring you and give you a chance to put the things / alteration back. I have done multiple retrofits on e-series and its mostly n54 owners who go through warranty work and usually oem navigation is put back into the car. Updating firmware / software is no issue at all, whether thats done at bmw or any independent garage as ultimately you are reducing bmw dealer's work in the event of a claim. However its better to update the whole car (all the modules) as opposed to selected one. And this does not require altering the virtual spec sheet (VO) of your car. I would not worry at all in your case as your modules were updated with bmw written firmwares. In case, if they ever say then just say that your indy may have done it. They will be glad as they will have to update less modules unless there will be updates for engine and gearbox modules at that time.
11-14-2016, 01:14 PM | #16 |
Rep 479
From my experience I can say that less than 20% of cars have firmware update done up to date. Every second bmw never been updated from factory integration level.
Most of dealers will never discover if some ecu's been flashed by others, of course depends of fault. |
11-14-2016, 01:41 PM | #17 |
Carl
20
Rep 73
Thanks for the feedback makkan00 and vorph
It makes more sense now reading through all the comments. As you've said, the guy just went in and ticked a few of the option boxes for functions BMW didn't give from factory and he found 2 updates available on the BMW software and updated them.. if it comes to it, I'll suggest an indy did it ;-) |
onstat89.50 |
05-23-2017, 02:23 AM | #18 |
(Incoming) G80 M3Cx
249
Rep 516
Sorry to bring back an old thread but how does one reverse the VO coding? I've coded EBT but I'm curious to know what I need to do to reset VO just in case.
05-24-2017, 02:12 AM | #20 | |
Rep 1,201
For example, for EBT you would have changed 6NH to 6NS in the FA list. Saved it in ESYS and then gone to HU_NBT for NBT Pro Media or HU_EntryNav for newer business media and pressed code. To reverse that, you would change the Vehicle Order FA list back to original (6NS to 6NH) and then "Code" back the relevant modules. You can change the FA within Esys. Esys then holds a local copy and you can VO code from that altered FA. As long as you don't then write the altered FA back to the car, the car will always hold the original stock FA. To then code back to original, just read the car and then VO code modules. However, if you have written it back to the car you will have to dig out your original order and write back. 99% of the time there is no need to write the FA back to the car. This can cause problems at the dealer if your original order FA list doesn't match what BMW have. (As I and teaston have found out). They cannot programme or update your software. FA - you change the order codes to add /remove or change the options of the car and then you can VO code the required modules to that order (FA list) FDL coding is changing individual settings, manually, inside an individual ECU module.
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d Last edited by stu14t; 05-24-2017 at 02:18 AM.. |
M3anLantern248.50 |
05-24-2017, 03:01 AM | #21 | |
Rep 2,118
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
05-26-2017, 01:32 PM | #22 |
Rep 263
Can coding EBT prevent OTA map updates? Had my car nearly 3 months and I'm still waiting for the 2017-2 OTA map update.
Can I manually force an OTA update? |
