07-22-2018, 11:41 AM | #177 |
Rep 1,465
Is the burble mode similar to the MPPSK with the down-shifts and pops?
nzivkovic500.00 |
07-22-2018, 01:04 PM | #178 | ||
Rep 126
2017 340i xDrive
MPPSK More to come |
G.Newt810.00 |
07-22-2018, 01:59 PM | #179 | |
Rep 1,456
2022 CT4-V Blackwing 6-speed
07-22-2018, 02:35 PM | #180 | ||
Rep 126
2017 340i xDrive
07-22-2018, 06:28 PM | #181 |
Rep 286
My question is this: I really want the stage 2 performance gains since I’m already running the MPPSK tune from the factory with an aftermarket intake, but I do not want the run a DP because I don’t want to increase or change the sound of the exhaust. Is it possible to run a stage 2 without the DP? Does running 93 octane instead of 91 have any affect on this?
07-22-2018, 07:24 PM | #182 | |
Rep 259
Drives: 16' AW 340i xDrive
Their whole life sheep are scared of the wolf but in the end, it's the sheppard who eats them.
07-22-2018, 08:24 PM | #183 |
Rep 1,372
Meth or port injection on top of the flash/DP/intake.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
07-24-2018, 09:14 AM | #184 | |
Rep 703
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
07-24-2018, 09:34 AM | #185 |
Rep 579
Posted in the group buy thread:
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T |
07-24-2018, 10:29 AM | #187 |
Rep 579
Current: 2021 M340i
07-24-2018, 06:58 PM | #189 | |
Rep 79
07-24-2018, 10:04 PM | #191 |
Rep 462
07-25-2018, 07:12 AM | #192 | |||
Rep 216
The mppsk shows a torque value without comparison to the stage 1. Am I not adding the right values on the chart? Any way you could make some standard roger and after charts like everyone else does?
2017 340i M Performance Edition: Fashion Grey, MPPSK, M performance front splitter, rear diffuser, side sills, black grille, CF spoiler, 405M 20s, 8AT, full Marino interior and dash, adaptive suspension
07-25-2018, 08:48 AM | #193 | |
Rep 521
Personally, I have to get friends to look at it to really understand it, but there's good info there. |
07-25-2018, 10:16 AM | #194 | ||
Rep 216
Thanx for the heads up
07-25-2018, 05:48 PM | #195 |
Rep 189
07-25-2018, 09:58 PM | #197 |
Rep 2,964
07-25-2018, 11:10 PM | #198 |
Rep 1,372
I've gotten 4.1 on the Dragy with JB4 map 3, intake, 93 octane and 255 PSS on my M240i. If I had X-Drive, 3.9 would easily be possible at the same power levels. I don't worry about 0-60 too much, as I'm more into 1/8, 1/4 and 60-130 times, as those are better indicators of a car's true power potential. The 340i is around 100-150 lbs heavier than a 240i, so keep that in mind, but I bet a Stage 2 flash/DP/intake/93 RWD car will be able to flirt with breaking the 4 second barrier. Drag radials would certainly do the trick, as 0-60 is more about traction. It's a Catch-22 in that the more power you add, the more you're traction compromised off the line.
nikman011174.50 |
