03-28-2023, 03:16 AM | #771 |
Rep 38
Drives: 2018 M3 Comp in Sakhir Orange
OK, my bad. I was starting in the wrong place. I'm in now. However, I still cannot get it to update. It doesn't seem to see the update on the USB stick. I've tried several different folder structures. I'd have thought you just dump the whole (unzipped) ENTD_xxx folder into the root, don't you? I did try moving the contents of that folder into the root but that didn't work, either. Grrr. I don't remember having this much trouble before.
03-28-2023, 08:21 AM | #772 | |
Rep 41,044
\BMWData\CDDB\GRACENOTE\ Extract .zip file and Copy the Gracenote folder and the following files to the BMWData\CDDB\GRACENOTE\ folder: content_evo.xml content_evo.xml.sign
03-28-2023, 11:36 AM | #773 |
Rep 38
Yeah, that's how I tried it first but it didn't work. BMW can be very picky about USB sticks, so I've tried 3 different ones, one of which is USB 2.0, in case it doesn't like USB 3. I've tried partitioning them to 8GB, in case it doesn't like 32 or 64GB. I've tried both USB ports. But it still doesn't see it. When I get to the Gracenote screen in the menu, the update version just shows dashes and there is no update option. I've done map updates using these sticks, though, so they should work.
03-28-2023, 12:04 PM | #774 | |
Rep 41,044
03-28-2023, 12:55 PM | #775 |
Rep 38
Yeah, I've always used the dash port before. I tried the console one, too, just in case. I don't get why it doesn't work. Everything looks correct. But it's given me a headache now, so I've given up. Thanks, for your help.
03-28-2023, 01:13 PM | #776 | |
Rep 41,044
BMWData\CDDB\GRACENOTE\GRACENOTE Do you?
03-28-2023, 01:48 PM | #777 |
Rep 38
Yep. Plus the .xml and .sign files in the first Gracenote folder.
03-28-2023, 01:50 PM | #778 |
Rep 41,044
Ok, I give up.
03-28-2023, 01:59 PM | #779 |
Rep 38
Me too!
03-28-2023, 02:08 PM | #780 |
Rep 38
It's the 'D' in BMWData. It has to be upper case.
03-28-2023, 02:15 PM | #781 |
Rep 41,044
Really? It worked?
03-28-2023, 02:19 PM | #782 |
Rep 38
Yep. BMW drive me nuts sometimes. Even Microsoft aren't that anal about folder names. I'd created the folder as BMWdata instead of BMWData. Also, the first GRACENOTE folder is in upper case. I already had that correct but I bet that would have stopped it, too. And the second one is Gracenote - mixed case.
03-28-2023, 02:24 PM | #783 | |
Rep 41,044
03-28-2023, 02:25 PM | #784 |
Rep 38
Yeah, and I bet it has to match that exactly or it doesn't work.
03-28-2023, 02:27 PM | #785 |
Rep 41,044
03-28-2023, 02:29 PM | #786 |
Rep 38
Right, that's quite enough of that rubbish for one day. It's pizza o'clock so I'm outta here. Thanks for sticking with it.
03-28-2023, 02:31 PM | #787 |
Rep 41,044
03-30-2023, 10:49 AM | #788 |
Rep 38
I've been pondering this. Like you do. The software that runs on the car is not Windows. It doesn't use FAT or NTFS. Much of it is free software that BMW have downloaded from the internet. That's why you can download free software updates from their website. They can't charge for it 'cos they don't own it. I'm guessing much of it runs on LINUX. 'Cos it's free. Windows will not allow a folder (directory) called BMWData next to one called BMWdata (in the same parent folder). It will see them as the same name. But pretty much everything in LINUX (and UNIX) is case sensitive and would allow this, as it will see them as two separate directories. So, if a piece of software running in LINUX is looking for an update in a directory called BMWData, it will not look for it in one called BMWdata (unless it was specifically coded to check both). Although Windows can't read UNIX filesystems, LINUX can read FAT (and NTFS). So it wouldn't have a problem reading a USB stick formatted with FAT32, but it would still distinguish between those directory names.
03-30-2023, 01:48 PM | #789 | |
Rep 41,044
EVO is running QNX.
03-30-2023, 02:35 PM | #790 |
Rep 38
Which is just 21st century UNIX
04-03-2023, 08:41 AM | #792 |
Rep 41,044
Last working NBT version is Gracenote-DB for NBT & NBT-EVO 03-2017 China & Korea. This is 6 years old. You have something even older in car?
