BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > CANADA > Engine Oil Level Sensor
      10-26-2020, 11:17 AM   #1
CPRO723
CPRO723's Avatar
Drives: 2013 F30 335iX
Hey,
I have a 2013 335i (F30 N55). The car has roughly 45k km's. When I go to measure my oil level, the idrive is constantly reading MAX. I do the oil changes myself approx every 6000km. Last oil change I put 6.5L in to start off with as that is what I found was recommend. Throughout the whole 6000km sequence, the oil level constantly read MAX, but when I went to change it, it was at roughly 5.7L. Any suggestions as why the oil level sensor may be working or not.
I recently changed the sensor thinking maybe it has gone bad but doesnt seem to be the case because it is still reading MAX even through I am 3000km into this oil change run.
I am not to sure how this level sensor is suppose to work, I'm new to the BMW world. Any help or tips is appreciated
      10-27-2020, 10:27 PM   #2
zibbit
Drives: '18 X3 M40i
I don't believe the oil quantity measuring system is all that accurate. It's more of an "educated guess" the best of times.
      10-29-2020, 11:35 AM   #3
CPRO723
CPRO723's Avatar
ummm ok, how do you know when you need to add more oil? Does the ECU pick that info up by monitoring the oil pressure?
      11-04-2020, 09:13 PM   #4
sunnymamba
Drives: 2013 F30 335ix
Originally Posted by CPRO723 View Post
Hey,
Same here, I put in 7 litres, I take out 5 and my level reads full every time
