01-05-2024, 04:18 PM | #1 |
AH3 Owner
201
Rep 310
Drives: BMW 335i ActiveHybrid 3
335i N55 metal glitter in oil filter (edit: new bearings, now rattles)
A mechanic let me know that they found a tiny amount of metal glitter in my oil filter. ('13 N55 335i with 100K miles). They said to just keep an eye on it and it could even be normal. They did an OFHG job and checked the filter. OFHG job was done early last year, but since then the gasket kept leaking and bolts became loose on their own. I finally abandoned that shop and brought it to a new place where they correctly fixed the issue. It was then they noticed the filter glitter.
I'll be sending oil to Blackstone. Another shop recently did a BG EPR ( https://www.bgprod.com/catalog/engin...e-restoration/ ) treatment. Could this have caused temporary glitter? Or am I heading to rod bearing issues? BG commented that the flush might have broken loose all of the particles that were stuck somewhere attached to grime and sludge from years back and that's what is now in the filter. Oil changes have been done every 5K miles for the past 3 years during my ownership. The car drinks oil pretty fast when using 5W30. Upon switching to 5W40 it has been normal. No codes apart from a rare Vanos code that comes maybe once every 2 months, claiming that adjustment is not possible. Last edited by NxTH; 01-26-2024 at 04:42 PM.. |
01-05-2024, 04:40 PM | #2 |
Rep 7,607
What kind/color of "metal" glitter? I guess you may have to wait until the blackstone report to know if it was glitter and not flakes.
Are you EWG or before the changeover? |
01-05-2024, 04:46 PM | #3 | |
AH3 Owner
201
Rep 310
I'm in Finland so the whole Blackstone process might take awhile. Shop said that they sometimes see glitter and it's not a sign of anything necessarily, but it needs to be kept an eye on. I might just go a step further and replace bearings regardless. Just curious if it's possible it's coming from the vanos instead. |
01-05-2024, 05:39 PM | #4 |
Rep 482
Can you explain what does PWG/EWG have to do with this?
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
01-06-2024, 09:32 AM | #5 |
AH3 Owner
201
Rep 310
01-06-2024, 05:50 PM | #6 | |
Rep 10,358
https://static.nhtsa.gov/odi/tsbs/20...51166-9999.pdf
"Drive more, worry less. "
Burnout27.00 |
01-06-2024, 08:30 PM | #7 |
1296
Rep 3,534
Pwg cars tend to fail more often. Plus really easy to do after an ofhg if they don't do the correcting priming procedure etc.
01-07-2024, 08:58 AM | #8 |
Rep 482
My question is why is this more present on PWG cars? Using PWG vs EWG is a marker of build change, I'm curious what changed since the turbo itself isn't causing this.
01-07-2024, 09:06 AM | #9 | |
1296
Rep 3,534
E series pwg n55 cars are the worst (almost like a hybrid n54/55) and progressively gets better when you get the the ewg cars. Might be one specific thing but likely it's a combination of little things to end up causing this.
01-09-2024, 05:04 AM | #11 | |
AH3 Owner
201
Rep 310
01-10-2024, 09:07 AM | #13 |
AH3 Owner
201
Rep 310
Rod bearings will be changed next week. I will post a photo of them here after.
01-19-2024, 07:19 AM | #14 |
AH3 Owner
201
Rep 310
Will be getting the car back on monday. Shop let me know the bearings were pretty shot. Definitely confirms the fact that you can't be too careful with the N55. The moment you see glitter, it's best to tackle the bearings as soon as possible.
01-19-2024, 11:23 AM | #15 |
Rep 7,607
01-19-2024, 01:24 PM | #16 |
Rep 482
+1 on pictures. But also, bearings are a symptom of a oil starvation. Wonder if it was due to not priming the oil circuit properly after the OFHG replacements.
01-19-2024, 03:51 PM | #17 |
AH3 Owner
201
Rep 310
Photos coming early next week when I get to see the bearings. The shop doubted it was due to the other shop's OFHG installation, but rather just excessive wear over time.
01-20-2024, 03:54 PM | #18 |
Rep 10,358
Highly probable
01-22-2024, 08:44 AM | #19 |
AH3 Owner
201
Rep 310
Here are the rod bearings. I don't really know what I'm looking at, but to a novice it looks like excessive wear and some scratches?
thejeremyman94363.50 |
01-23-2024, 08:57 AM | #20 |
AH3 Owner
201
Rep 310
And today, I have something that sounds like rod knock after the bearings were changed:
Car is going back to shop later this week, but I assume the engine is now toast? Last edited by NxTH; 01-24-2024 at 12:13 PM.. |
01-23-2024, 10:17 AM | #21 |
Rep 383
That doesn’t sound like rod knock. Hard to say what it is, likely something not put together correctly during assembly. Timing chain maybe? (Just trying to think of what components get messed with when pulling rod bearings)
Hard to say if it’s catastrophic, or just another repair. |
01-23-2024, 11:06 AM | #22 | |
AH3 Owner
201
Rep 310
