07-26-2019, 12:23 PM | #1 |
Rep 11
F30 xDrive 19x9.5 et33 SQUARED fitment
Hello all -- I'm looking to buy a set of wheels but their sizing is pretty limited. I definitely want a squared setup but 8.5" is too narrow for my taste, and 9" isn't offered. So 9.5" et33-35 is what I"m working with. Does anyone have any experience running this spec (or very close to it)? Keep in mind that I have no suspension mods or fender mods (will do these if necessary).
I saw one user awhile ago run 19x9.5 et35 squared, but he was only a mm away from hitting his strut (although he claims he had no rubbing issues in ANY situations); with that information in mind, I'm inclined to go with et33, but that may rub the fender? Any help is appreciated! |
07-30-2019, 11:24 AM | #2 |
Modder of everything I own
147
Rep 491
I'm running a square set up
Wheels are 19x9.5 5x120 ET20 Tires are 255/35ZR19 My tires poke out a bit past the fender, I didn't adjust camber at all from stock. There is about 3/4" between the inside of the tire and the strut so you could go with a larger offset and then tweak it with a spacer if you had to.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
07-31-2019, 09:19 AM | #3 |
A family of bimmers
2747
Rep 7,742
that looks terrible in my opinion.
OP, why the need for 9.5 wide wheels on your 328? especially at stock height. I run 8.5 up front with a 235 and its plenty meaty. You can even go 8.5s with 255s square and be fine. whats the desire for trying to shove a 9.5 wide wheel up front?
07-31-2019, 03:04 PM | #5 |
Rep 77
08-01-2019, 08:03 AM | #6 |
Rep 272
08-01-2019, 08:27 AM | #7 |
Rep 77
08-01-2019, 09:14 AM | #8 | |
Rep 272
I think conti's run narrow. The Federals I run always run wide ~10mm. I feel like I could fit a 245/35 as-is, i just would have to be selective on the brand. Going narrower while experimenting with the sizes is the safer bet than going wide and trying to make the tires fit. |
08-01-2019, 10:14 AM | #9 | |
Rep 11
08-01-2019, 10:23 AM | #10 |
A family of bimmers
2747
Rep 7,742
i've said it in other threads. the reason for the sale is they wont fit. sometimes a sale just aint worth it if it requires a whole lot of work to fit them. I too have xdrive and run staggered VMR wheels using 235/265
08-03-2019, 04:57 PM | #11 | |
147
Rep 491
OP just showing the you what mine looks like with my set up
08-05-2019, 11:44 AM | #12 |
Cheapskate
4450
Rep 4,993
With a 235-245 up front it'll work but as you see it'll look goofy. Unless you want to look like you're driving a skateboard, not worth it. Save up and buy wheels that fit. Black Friday sales will be here in a few months, and the classifieds is full of quality used options.
wdeerfield2746.50 |
08-05-2019, 12:05 PM | #13 |
NewFinishColumbia/detailer
604
Rep 2,096
Great color.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
08-05-2019, 01:53 PM | #14 |
Rep 11
Yeah, I appreciate the picture, man! Much more useful than the other guy's comments -_-
08-05-2019, 01:55 PM | #15 | |
Rep 11
Also, what are "the classifieds"? |
08-05-2019, 02:16 PM | #16 | |
Cheapskate
4450
Rep 4,993
Yes they will still poke. The wheels are too wide in the front and you'll need a spacer to compensate, causing it to poke more. Do your research on here if you want more concrete evidence. You'll find 18x8.5 et35 with 245 square all day on x-drive cars sitting flush. You want yours to stick out over 1/2" more, go right ahead. These are the classifieds. https://f30.bimmerpost.com/forums/fo...play.php?f=473 good luck. |
wdeerfield2746.50 alohasurftoad3078.00 |
08-05-2019, 08:38 PM | #17 | |
Rep 11
Looks “too wide” to me. |
08-07-2019, 03:32 PM | #18 |
147
Rep 491
Thanks! To each his own.
08-08-2019, 06:45 AM | #19 | |
A family of bimmers
2747
Rep 7,742
08-08-2019, 07:42 AM | #20 |
Cheapskate
4450
Rep 4,993
08-08-2019, 09:49 AM | #21 |
A family of bimmers
2747
Rep 7,742
kern4174449.50 |
08-08-2019, 09:59 AM | #22 | |
Cheapskate
4450
Rep 4,993
No one wants you to fail, just saying you're teetering on the edge of what works and likely to have issues. When you stop being honest about your mistakes and feed more crap into the community pool, more people just have the same issues. |
wdeerfield2746.50 |
