08-10-2019, 06:22 AM | #1 |
Rep 494
Normal stretch? 9.5 on 255-30
Hi guys!
So I just installed my new wheel on, and I was wondering what the hell is this stretch? On a 255 you can put a 10 inch wide wheel. This is a 9.5... I don't understand..!!!? Is it normal?! These are pirelli p zero runflat tire OEM, 255-30-20 in the rear. Front is ok
Bmw 435M 2014 Convertible SOLD!
Bmw 340i X drive 2018 New orange sunset, Manual transmission, M performance I & II, M performance front lip, side extension rear diffuser, tinted windows. : SOLD Back in old N55 love! Bmw 335 EBII M performance edition : ER Downpipes, VRSF Chargepipe, VRSF HD 6.5 Intercooler, BM3 Stage 2 93 octane, MPPSK, H&R Spring |
08-10-2019, 08:17 AM | #2 |
Rep 253
I think the fact it's a run flat has something to do with it, plus 255 is definitely on the smaller side for a 9.5". I have 9.5 rears with 255 runflats as well (Continental) and they also look stretched, but the rim guard still protrudes way past wheel, it's kinda weird.
I always assumed it had to do with the super stiff runflat sidewall which doesn't "stretch" like a normal tire, but maybe someone else knows more. |
08-10-2019, 02:34 PM | #3 |
Rep 909
On a 9.5J wheel 255 and 265 sizes are usually the recommended ones, with 275 being the max. So really there should not be any issues in this regard. If you are on good terms with your tire shop/buddy, I would just drive by there and have some other wheels NON-run flat fitted on for testing purpose in order to exclude this one. The test is quickly done.
08-10-2019, 03:47 PM | #4 | |
Rep 494
08-10-2019, 04:34 PM | #5 |
Rep 909
Indeed and as said I would just run a quick test if possible at a local tireshop or somewhere where they have this size of tires and try possibly a NON-runflat tire to exclude that as potential culprit.
Another thing that comes to my mind but is just a thought, could be that the rims you have are not ideal for accommodating the extra thickness of the sidewalls of run-flat tires and that the rear size accentuates this? I cannot think of anything else but would definitely drop by the local tireshop and check/test by mounting a non-flat tire on the rear and see what the outcome is. |
08-11-2019, 06:28 AM | #7 |
Rep 494
I might get new tire then... I don't know how it is that stretch honestly... not so sure about the look too. Is it that bad? Le can I drive like this without problem?
08-11-2019, 03:30 PM | #8 |
Cheapskate
4445
Rep 4,993
a 255 is absolutely not the right tire for a 9.5" wheel. The rule of thumb is that the tire width should be 1" wider than the wheel width. That's because Tires are measured across the entire width outside to outside, but wheel width is measured inside where the tire bead sits.
A 9.5" wheel is made for a 10.5" tire i.e. 275. Anything less will show some stretch. |
08-11-2019, 04:17 PM | #9 |
Rep 65
I have 255's on my 9.5" wheel. Stretch isn't even close to what I'm seeing from OP. Must have something to do with it being runflat. I would have loved to put 235/35/19 & 275/30/19 on my car, but there have been reports of this size rubbing.
Back Wheel - Continental DWS 255/35/19 on a 19x9.5 +43 wheel. Front Wheel - Continental DWS 225/40/19 on a 19x8.5 +35 wheel. Last edited by Regulator; 08-11-2019 at 04:22 PM.. |
08-11-2019, 07:02 PM | #10 |
Rep 253
So I think it's a bit of both, 255 is slightly small for a 9.5, plus the run flat sidewall. Clearly these Pirelli's run small because here's mine (9.5 on 255/35 Conti runflat) — keep in mind OP's was 255/30 so that also attributes in appearance of stretch. Mine has some stretch on sidewall but rim protector still protrudes pretty substantially...I almost want to say to verify tire and wheel size, something doesn't seem right.
[IMG]https://i.ibb.co/YZ4rFTW/EC980-D7-C-...F1-F878-C9.jpg[/IMG] |
kern4174445.00 |
08-12-2019, 06:33 AM | #11 | |
Cheapskate
4445
Rep 4,993
08-12-2019, 07:59 AM | #12 |
Rep 271
08-12-2019, 08:41 AM | #13 |
Modder of everything I own
147
Rep 491
Mine has 9.5" with 255/35/19 and looks like this, not sure what's up with yours OP. I have Go-Flat Michelin PSS
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
08-12-2019, 10:30 AM | #14 |
Rep 494
Difference is you have a 35 sidewalk, which give the tire more space to stretch. I don't know, maybe pirelli has a different look, curve and aspect that other tire.
kern4174445.00 |
08-12-2019, 01:35 PM | #15 | |
Cheapskate
4445
Rep 4,993
And I tried looking it up but couldn't confirm that Pirelli runs narrow. But I'd bet that plays an effect too. |
08-13-2019, 07:23 AM | #17 | |
Rep 494
I'll simply put new tire on the wheel! 235-35-20 and 265-30-20 in the rear, with non runflat tire! Hopefully it will correct the problem!
08-13-2019, 03:01 PM | #18 |
Rep 225
Here's 255 PS4S on 9.5 although it's not as bad as yours still pushed in a little.
Friend of mine has exact same wheel but a different 255 tire and his side wall looks more straight with the wheel. I was told that sometimes mounting technique makes a difference but I think it's the tire itself and 255 being small for 9.5 |
08-14-2019, 12:07 AM | #19 |
Rep 1,827
All you need is like 20 degrees of camber and air suspension! #stancelife!
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
08-14-2019, 06:33 AM | #20 | |
Cheapskate
4445
Rep 4,993
Those are 19" wheels. On 20" wheels, you'll see much closer to the stretch that OP has because of the shorter sidewalls. I feel like I'm talking to a brick wall, but good luck with the swap. 265 will make a bigger difference than switching to non-runflats. |
