11-20-2021, 07:02 PM | #1 |
Rep 56
So I have a 2015 430d (pre lci) currently up to 79,000 miles (127,000km). I'm looking to lower my car for aesthetics and fit springs, perhaps acs or eibach?
However due to the age and mileage of the car are the shocks likely to be an issue I should replace as well or will just the springs be ok? If so what setup would you suggest to keep the costs reasonable. I'm also looking to not do anything to worsen the ride of the car, I already find it very crashy and I'm looking to change to non run flats to try to counter that. I have adaptive suspension too, if that changes anything. |
11-23-2021, 09:19 AM | #4 |
Rep 383
If you are doing the install yourself, I'd say it's up to you, and how you value your time down the road, unless the struts are determined to actually be bad.
If someone else is installing, I'd consider doing everything you can now, to save on labor cost doing it again later. |
11-23-2021, 02:43 PM | #5 |
Rep 56
I'm leaning more towards the all or nothing route at the moment to be honest.
Not sure exactly what my best route would be though. I'm not looking to make the car have less body roll or become a track beast or anything, just looking to have the lowered look and maintain or even improve the comfort of the car really. Do you have any suggestions about the best route. From a lot of what I've seen on here Acs/eibach springs with a bilstein dampers seems a popular choice. Thanks for the reply! |
11-23-2021, 05:07 PM | #6 |
Rep 191
I’ve just ordered mine after a ton of research. Not that that means I’ve made the best choice, but here’s my summary:
TLDR: KW Street Comforts £1231 + £300ish fitting. I’m on 90k miles, passive suspension. I’m convinced the shocks are worn and not dampening properly, so I was a definite for shocks and springs. I also wanted to lower the car for aesthetics, and to sort out the wallowy front end (it’s a 330d x drive F31) Didn’t want to make it into a track king, maintaining comfort was key. Options All costs are for the kit only. Install is anything from £200-£350 Bilstein B12 (Eibach Pro Kit). Can be had for £650ish ACS springs and B8 dampers £8-900 I think The B8’s aren’t custom tuned and seem to be quite hard / crash at low speeds and then don’t dampen particularly well at high speeds ACS springs and Koni Special Actives £8-900 Quite gentle at low speeds and good dampening at higher speeds. Check out the info in this thread for the different shock options https://f30.bimmerpost.com/forums/sh....php?t=1662711 Bilstein B14. £8-900 IIRC. Coilover system so you can dial in your ride height just how you want it. However the shocks are quite firm and the spring rate is higher than OEM so overall probably too firm KW Special Actives. I went with these. Apparently the spring rate is near OEM and you have adjustable rebound on the shocks so you can get a good level of comfort. Coilover so adjustable ride height. I was at the top of my budget with the KW SC’s - I waited for Black Friday which gave £200 off their £1431 usual price. To be fair you could usually find them for £1300ish at a few retailers. If you can push your budget further then the ACS Sport system is apparently a great option. It’s fixed shocks and springs, ie not a coilover so no adjustable ride height, but by all accounts it’s tuned perfectly to the car for the right drop and the OEM+ level of comfort and handling. I believe the springs are based on Eibach - you will see posts on here saying they’re just re badged Eibachs but I understand that this is not correct - they’re custom spec’d and manufactured and suit the car perfectly. Same with the dampers - they’re a custom valved unit based on the Bilstein B8, again, tuned to the F3x. Above that is the ACS RS which is a KW V3 based coilover system - different price bracket. If I had more budget, I’d have seriously considered the ACS Sport. I didn’t research Birds, but they do get a good rep on here too. Good luck! Last edited by tj_g; 11-23-2021 at 05:17 PM.. |
JoshU12.00 waxwing_f311.50 |
11-23-2021, 05:28 PM | #7 | |
Rep 10,256
Comfort is a function of ... - Sufficient suspension travel - Sufficient enough for compression and rebound cycles to absorb road imperfections while maintaining suspension geometry without bouncing up and down Lowered suspension has less travel and that _usually_ means less comfort. Coilovers with independent compression and rebound controls - ex: KW V3 - offer enough tuning options to help you find the optimum balance between performance and comfort. |
11-23-2021, 07:39 PM | #8 |
Rep 98
Drives: BMW 335i xDrive
@JoshU, I had very similar goals as you last year with my '15 335xi
I went the following; * Eibach 05-22 springs (European kit, slightly lower than the Eibach 06-22 kit) * Koni Yellow struts (I did not have adaptive suspension) * Replaced the factory F30 bump stops with factory F80 bump stops from local BMW parts dept. I'm very happy, nothing I regret with the path I took. I will say I was concerned with the ride quality, however it was not as harsh as I feared and the handling was much better. I will say that road imperfections were a lot more noticeable after being lowered. However I just recently replaced my wheels/tires, and went with a meatier non-run flat tire and it made a huge improvement to the ride quality and I would argue it is now practically the same ride quality as factory suspension with factory run flats. If you consider going the Eibach route, I recommend looking at this thread; Any EIBACH SPRINGS on F30 335i X-DRIVE? https://f30.bimmerpost.com/forums/sh....php?t=1501682 Also, if looking to do the install yourself (I did, and I would not consider myself a mechanic by any stretch) I highly recommend this incredible video from Farkle; |
11-24-2021, 04:07 AM | #9 |
gds
Rep 25
Nice review. I would like to ask what tires do you use and the dimensions of tires and wheels that you used before(the run-flat ones).I m on 225/45/18 R/F Bridgestone potenza S001, Koni yellow, normal m sport springs and Eibach sway bars and the ride is not good in low, city speeds.
11-24-2021, 04:14 AM | #10 | |
gds
Rep 25
11-24-2021, 06:01 AM | #11 | |
Rep 98
A few weeks ago I switched to APEX 18x9 ET30 ARC-8 wheels (square) with non-RFT high performance all season Conti DWS-06 Plus 255/40-18's. This kept my same rolling diameter, did not increase wheel gap, and I'm super happy with the decision. This is the largest square setup I could fit on my car, I'm not rubbing however just barely as there is no additional space up front. FWIW- I had planned to go the Michelin route, however the Conti's had a better price, better lifespan, American made, and were highly recommended. I also liked the previous Conti's, with the exception they were RFT's. |
gds4.50 |
11-25-2021, 06:38 AM | #12 | |||
Rep 56
Also if you could tell me where you got them for such a great price or have any particular places you'd recommend for purchasing these sort of things it would be appreciated. I'm leaning more towards the Koni/ACS combo just for the simplicity and price I think but it's ever so close and I could certainly sway either way. I just need to decide and then find a good garage in the Oxfordshire or Sussex area. I will also have to code out my EDC but that should be simple enough. Quote:
It appears you've gone for a sportier setup than the one I'm after however I'm interested in your tire solution - I love the look of the meaty tired you're running. I'm staggered with 225/40/19 and 255/35/19 and wondering how I could get a similar look while probably preferring to remain staggered. |
11-25-2021, 09:13 AM | #13 | |
Rep 98
I originally was going to go the staggered route as well, however the combination of not being able to rotate along with the added consideration of X-drive I opted to go the more conservative route with a square setup. https://support.apexraceparts.com/hc...-Fitment-Guide P.S. here are two pics of my front tire for reference, if it helps. |
JoshU12.00 |
11-27-2021, 05:18 AM | #14 |
Rep 8,493
To the OP.
It depends on your wants/needs, i.e. whether you are simply looking for aesthetics or whether you want to improve the dynamic capabilities of the car, but from direct experience I'd be wary of going down the ACS route if you opt for 'springs only'. Plenty of people have found the ACS springs to be fine, but I found them to be not a big enough improvement (spring rates) to be worthwhile. In short, they were too soft. It also didn't help that I retained the OEM adaptive dampers which were either under-damped (Comfort) or too too stiff (Sport). BMW may have improved the system since my 2012 car, but on the pre-LCI cars the dampers are a real weak point. I'm not advocating super-stiff springs and a rock-hard ride - that can be really detrimental. I ended up having the springs and dampers replaced with a far better setup (Ohlins). As with any significant cost, do your research first. It's not something you'll want to do twice. I'd strongly recommend changing the springs and dampers at the same time and making sure, as best you can, that you select well-matched units.
JoshU12.00 |
12-05-2021, 03:32 AM | #15 |
Rep 66
Not sure about the pricing for ACS springs over there, but why not go for the Eibachs springs instead. For my F30 I went with the Eibach 05-22 springs and I'm pretty sure they are the same or very close as the ACS, just a lot cheaper.
I went with the Bilstein B4 struts, and the OEM struts were definitely on their way out with only 90,000kms. So 100% recommend switching those out. |
JoshU12.00 |
12-07-2021, 01:00 PM | #16 |
Rep 56
So following the info gathered from this thread and my own research online I've opted for a full refresh with KW Street Comforts which I picked up at a great price.
Quite excited to see the look of the car lowered and with 10/12 spacer setup. And even more so looking forward to the improved handling and ride. I wonder if anyone has any experience with the EDC delete - I'm buying the coil overs without any delete kit and going down the coding route, I assume the fitment will be fine and just chuck up a few error codes I can ignore until I sort get it to a coding specialist? Also just on the off chance anyone else has fitted these coil overs, how did you set it up with regards to damping? Just something in the middle? |
