01-31-2023, 04:01 AM | #1 |
Rep 38
M Sport shocks + Eibach Pro Street springs
Hello, for over more than one and a half year I'm running my 2014 BMW F30 320d with a pair of static BMW M Sport shocks with Eibach Sportline coilovers (the red ones), which are a bit shorter than the standard Eibach Pro Kit coilovers. Not long ago a mechanic told me that both the front shocks had leaked, and I'm curious if that could be from the short springs, or it could be from something else. If the springs are too short I'm thinking to replace them with the original M Sport springs that came paired with the M Sport shocks. Does any of you have any ideas? Thanks.
01-31-2023, 06:24 AM | #2 |
Rep 519
That could definitely have contributed as the stock shocks are not meant for lowering springs but there's many factors, age being the one that sticks out to me. Being as it's a 2014, that would have me thinking the shocks are old and just time to be replaced anyways. How many miles are on the car?
Why not just get shocks that are made for the springs if you like how the car rides and sits? Like the Bilstein B8, which is made for lowering springs like you have.
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
01-31-2023, 06:56 AM | #3 |
Rep 38
The M Performance shocks were not stock on the car when it was made. I put them just about one and half years ago (when I also added the Eibach springs). I bought them used but in good condition from a guy that replaced them with Bilstein shocks (if I remember correctly they came from a BMW F22 M240i with less than 50k kilometers). I remembered the seller said that one of the front shocks was replaced with a brand new one not long before he sold them to me. Also the mechanic that installed them in my car didn't say anything that they were worn out or in bad condition, so I think they were fine when I got them.
Anyway, I chose the M Sport shocks over the Bilstein ones because I got a good deal on them being sold as second hand (less than half the price of the Bilstein). So I guess at this point I either have to replace the leaking shocks with the same model and put the M Sport springs that I already have, which would be the less expensive option, or buy a new set of Bilstein shocks for all the four wheels and use them with my Eibach Sportline springs. Last edited by br4to92; 01-31-2023 at 07:07 AM.. |
01-31-2023, 08:13 AM | #4 | |
Rep 5,392
alohasurftoad3079.50 br4to925.50 |
01-31-2023, 08:25 AM | #5 | |
Rep 5,392
01-31-2023, 10:36 AM | #6 | |
Rep 38
My question then is if keeping the M Sport shocks + springs would keep the car's stability similar to using the Eibach springs with a compatible set of shocks like the ones from Blistein or Koni. |
01-31-2023, 12:10 PM | #7 | |
Rep 5,506
Auto Detailing Enthusiast!
01-31-2023, 02:07 PM | #8 |
Rep 38
By stability I was meaning that the car should incline less when taking turns.
01-31-2023, 09:02 PM | #9 |
Rep 5,392
Then what you are referring to as stability is called body roll. You should have more body roll with the higher M Sport springs & dampers than with lower red Eibach springs and Koni Yellow Sport dampers. I definitely would not use Bilstein B8’s. They are fixed at a stiff setting at the factory with no way to adjust if you don’t like it. While the Koni Yellows have an entire range of adjustments that you can make.
br4to925.50 |
02-01-2023, 08:48 AM | #10 | |
Rep 38
02-01-2023, 10:05 AM | #11 | |
Rep 898
Drives: F32 428i Xdrive
I have found with the install of my koni SA and the strut brace, car corners very very flat now.
02-02-2023, 02:25 AM | #12 | |
Rep 38
djacinto373.00 |
02-02-2023, 08:47 AM | #13 | |
Rep 5,392
Eibach does an excellent job picking their spring kits for the axle weights of various BMW models. And Eibach’s are typically a slightly higher spring rate than stock, maybe 10%. So the result is lowering with more control but not something that is an abrupt harsh change. Spring kits from H&R, Dinan, etc tend to be 30%, 50% or more higher spring rates so they can be adrift harsh changes in ride. Dampers can be similar. M Sport are an incremental improvement over stock dampers but not monumental. Koni Special Active are a big improvement in sportiness and comfort at the same time because of their unique design. Koni Yellow Sport are adjustable for comfort and lean towards sportiness. Bilstein B4 are their replacement shock. I’m not fond of the stock shocks anyway. Bilstein B6/B8 are their sport shocks and are more abruptly stiff/harsh. Fixed with no adjustment. Suspensions are actually very complex with many interactive components including tires, wheels, brakes (unsprung & rotational weight effects). One can easily make a poor component choice. Luckily there’s a finite number of reasonably priced mod choices. I found the stock chassis and suspension with the runflat tires to be too stiff/uncomfortable with way too much body roll in curves and very vague steering. In my mod choices on my daily driver, I’ve tried to increase comfort, while improving cornering and steering. Hope this helps! |
br4to925.50 |
02-02-2023, 08:58 AM | #14 | |
Rep 5,392
If you are running stock size tires 225/45-18 that is definitely contributing to body roll. I ditched my stock runflat 225/45-18 on 400M 18x8 ET34 for non-runflat 245/40-18 Michelin Pilot Sport 4S on the same wheels. Soon I’ll be going to new wheels with 255/40-18 MPS4S. (Continental DWS06+ are an all season performance tire option) Wider tires work with the suspension additions. They are a necessary upgrade if you want to maximize your suspension mods. |
02-02-2023, 09:48 AM | #15 | |
Rep 38
02-02-2023, 10:29 AM | #16 | |
Rep 5,392
Also this YouTube channel has really excellent/professional tire reviews. I’m sure that he has done videos on both tires. https://youtube.com/@tyrereviews |
02-04-2023, 03:13 AM | #17 | |
Rep 38
03-07-2023, 06:30 AM | #18 |
Rep 38
I have one more question, as it turns out it is a bit hard to find shorter shocks for my Eibach sportline springs, I'm wondering if replacing the springs with the Eibach pro kit ones which are longer would work with the factory M Sport shocks. I could do that instead.
