03-18-2023, 06:58 PM | #1 |
Rep 5
340i M package spacers
Hello! I was planning on putting on the H&R sport spring set and I was wondering, after that, would 15mm spacers be too much for stock suspension? If yes, how much better would 12.5mm be?
03-19-2023, 02:27 PM | #4 | |
Rep 5,392
This video provides very good angles to judge for yourself what appeals to you. It uses a stock 340i XDrive with stock square BMW 400M 18x8.0 ET34 wheels and 225/45-18 Continental runflat tires. https://youtu.be/P-M1pvJ7A0Y |
alohasurftoad3081.50 |
03-19-2023, 02:37 PM | #5 | |
Rep 5
03-19-2023, 02:38 PM | #6 |
Rep 173
Drives: BMW 330i Sport Wagon
I'm running the Dinan lowering springs on an F31 and with the OEM 400M 18" wheels mounted on winter tires, I use 12mm spacers up front and 15mm out back. Tires are flush, no problem at all with the suspension or xDrive. I originally ran longer lug bolts than stock to accomodate the rear spacers, but switched to studs.
You'll like it at 12/15, I suspect, and you should not have any problems.
W///AgonHo FB - @WagonHo | IG - @wagon_ho
2019 F31 330i SportWagon | M-Sport | Black Sapphire Metallic over Black Dakota 2016 F31 328i SportWagon | Sport Line | Alpine White over Beige Sensatec (sold - 2019) 2004 B5.5 Volkswagen Passat GLS Wagon | Northern Green | 5-Speed Manual (sold - 2016) BMW CCA | National Capital Chapter since 2019 - SCCA | Washington DC Region since 2021 |
03-20-2023, 01:07 PM | #7 | |
Rep 332
I’ve been running my 12/15 for the past 3 years lowered on Eibach pro with both 722m 19’s and 660m 20’s with zero health issues |
03-20-2023, 02:15 PM | #8 | |
Rep 4,333
spacers increase the scrub radius(which affects dynamic toe), increase spring rate and turn radius. the increased track width at the rear of F3/4's will also increase understeer. there's also more shear load on the lug bolts or studs. all of this is on such a small level that it is unlikely you'd notice but the physics of what is happening. just so you know, they do more than just lower offset. |
johnung4528.00 |
