10-17-2021, 01:54 PM | #23 | |
Head Fry Cook at McBurgertown
507
Rep 1,005
How did you overcome the shifter linkage issue? |
12-13-2021, 12:31 AM | #24 |
Rep 69
Neither of the shift linkages will put your shifter in the center of the boot.
After extensive measurements and building a little jig I cut the linkage and the shifter bracket In half and added I think like 3/4” to both ( shift bracket is aluminum, linkage is steel) no photos, but I got the shifter to sit PERFECT in the center of the boot. What I figured out, and what made it so important to get the shifter dead center in the boot, is that the shift throw is longer in the new trans.. the throw is MASSIVE using my original f30 shifter and on 1-2, 3-4, 5-6 shifts, the shifter almost hits the front and back of its allotted shifter space.. I also had to dremel the bottom of the shifter in a certain spot to allow it to throw that far.. ALSO The n54 shift bracket isn’t made for my f30 shifter, so I had to dremel cut and grind all sorts of weird spots to allow the shifter to navigate through the gears without hitting the bottom of the shifter/ linkage off the shift bracket.. So it was actually a lot of work and honestly the only hard part of the swap (now that we know the solution the tcase issue I had) If your a decent fabricator you’ll figure out how to make this shifter setup work eventually just gotta put the hours in! IMO I need to get a f30 short throw shifter with this new trans to be back to normal.. BUT the gears hold great, no synchro issues, and I beat on it pretty good now that the clutch is broken in and it is so great!! Great success I couldn’t be happier with it |
terryd5150507.00 |
03-27-2022, 07:12 PM | #25 | |
Rep 15
If you ever get around to updating anything with this project or the short throw shifter upgrade to fix the long throw it would be really appreciated. Could you maybe describe what you had to dremel? I attached a pic of the two brackets side by side Thanks man your documentation is really helpful |
terryd5150507.00 |
08-15-2023, 09:04 AM | #26 |
Rep 76
Any updates on this?
Running same issue. Have a 13' 335i, RWD 6-spd. Bad 1-2 and I want to know best way to fix this. Def dont have the skills to do a full swap and fabricate/modify to make this work. |
08-15-2023, 01:01 PM | #27 |
1296
Rep 3,533
Replace the trans.. its the only way to fix it
08-15-2023, 07:52 PM | #28 |
Rep 403
What about using a 2010-2011 e90 n55 transmission? They look almost the same and are way way cheaper. I have an issue with my second gear on my 2013 335 xdrive and im not sure what to do. Here in Canada the price of a refurbished transmission is 7000 with taxes.
08-16-2023, 06:00 AM | #29 |
1296
Rep 3,533
They all have similar issues
08-16-2023, 09:27 AM | #30 | |
Rep 3,947
08-17-2023, 06:19 PM | #31 |
Rep 106
08-17-2023, 06:40 PM | #32 |
1296
Rep 3,533
Yup.. plus it's a pain to swap in as you have to do other stuff because it lacks some sensors that the newer ones have. It's slightly better though.. slightly but you will have the same issues with the synchro and gears.
SpoolinAddict19.00 |
03-01-2024, 10:57 PM | #33 | |
Nomad
Rep 26
