BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW F30 Ambient Lighting Set
      06-18-2015, 03:53 AM   #1
bryan06
bryan06's Avatar
25
Drives: BMW F30
Hi,
I have F30 with no lines, but I have lighting package on the car. I didn't have options about Ambient Lighting on the Idrive before coding.
I have coded my car with below codes,
HU_ENTRY, COLOUR_SWITCH, Activ --> it was no active, I have changed to aktiv
HU_ENTRY, COLOUR_SWITCH_LINES, sport --> it was no active, I have changed to Sport
I can see Ambient Lighting menu with Classic and Sport on Idrive after coding. I'm choosing Sport light from Idrive but I can not see near the Ambient set Sport or Classic when I choose Sport or Classic. it's empty.
I think that it should be like following,
I can see and choose Classic and Sport under the Ambient menu. but I'm seeing the like following, so it's empty.
What can be the problem?
Thanks in advance,
      06-18-2015, 12:22 PM   #2
Adamr916
Adamr916's Avatar
Drives: 2014 328d
You may just have the orange ambient light. If I remember right, only the sport line and m-sport got the sport lights, that's why we didn't get the air bag light the head rests.
Another reason is that you may not have had ambient lighting at all, which is why you didn't have the option.
      06-18-2015, 03:18 PM   #3
bryan06
bryan06's Avatar
25
Drives: BMW F30
Yes, I have just orange ambient light, I have tried to open sport ambient. but not works. I wonder that my problem is coding or hardware(led) is not support it.
      06-18-2015, 03:59 PM   #4
kitster
Drives: G31 M Sport
Switching between the two makes so little difference. Personally the option is a not worth the effort.
      06-18-2015, 04:20 PM   #5
HFW003
HFW003's Avatar
5684
Drives: 2024 M340i xdrive
F30 no lines do not get both colours
      06-18-2015, 06:24 PM   #6
KGB_123_99
Drives: '17 330ix M-Sport, '09 528ix
Orange light is better anyways, classic BMW. I tried the white light and didn't like, but that's a personal preference of course.
      06-19-2015, 04:17 AM   #7
bryan06
bryan06's Avatar
25
Drives: BMW F30
As far as I understand, you coded your car to open white light without no line.
How did you try white light? Also I want to try it.
Thanks,
      06-19-2015, 08:26 AM   #8
KGB_123_99
Thanks,
I had white light, the sport line can switch between orange and white. Just saying that I still stick with orange.
      06-19-2015, 08:50 AM   #9
bryan06
bryan06's Avatar
25
Drives: BMW F30
Ok, I see, you already have two colour options due to sport line package.
      06-19-2015, 12:12 PM   #10
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Bryan06,
I have 2014 no-line F30. Ambient lighting is only one color in my car, orange. Originally, I wanted to be able to change between white and orange; but now, I actually find that orange quite good because at night as it does not affect my night vision and matches the night time color of the dashboard & HUD (which change to white during daylight).
Al
Retired: 2014 328i
BMW CCA
      06-22-2015, 04:00 AM   #11
bryan06
bryan06's Avatar
25
Drives: BMW F30
Originally Posted by RSnic View Post
Bryan06,
Yes You're right, orange is good. I just wondered white light. But I couldn't coded, No problem, I love my car like this
      06-23-2015, 06:15 AM   #12
RSnic
RSnic's Avatar
Bryan06,
I'm with you!!
Al
Retired: 2014 328i
BMW CCA
      07-11-2016, 02:57 PM   #13
jakk
Drives: F34 335
Hi did you get any further with this ????
its exactly what i want to do, i have no line but i have checked the cup holder leds and there is orange and white leds and ive checked the wiring to it there is as feed to a orange led and a white led so I think the hardware is there just have not optons
      07-11-2016, 03:07 PM   #14
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
I have the lights package and coral red interior. the white looks like crap on the red so i leave it on the classic bmw orange
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      07-11-2016, 09:10 PM   #15
hsk1610
Drives: 2013 328i xDrive
As everyone said, if you have a no line CIC, the entry for ambient lighting is under HU_CIC under colour switch and the ability to change lines from not aktiv, sport, xline, modern, and luxury and have the option to change the color show up on the display but will not do anything to actually change the ambient color.
      01-03-2018, 06:46 PM   #16
MalsBmw
Drives: Bmw 320d
I’ve figured out the coding.. my f30 only had the orangelight. Now with coding i’ve managed to switch between orange and white. But i have to say when you switch over from orange to white, you don’t have the leds on the cupholders, doorpanels etc.. unless you replace them. (Cause there is no white led in it..)
Changes need to be done in (with esys):
FEM
CS_typ Change to two_colours
PIA_DEFAULT_CD change to Frabe_2
MAPPING_LCI_7_FUNCTION change to cs_2
Hu-nbt
Colour_Switch set to aktiv
Colour_Switch_Lines set to sport
And there you go.. you can now switch in your idrive from classic to sport and the light will change..
      01-10-2018, 09:43 PM   #17
ettam88
ettam88's Avatar
Drives: f31 my2013
for example, i didn't have in my F31 the ambient light package
with this coding, MalsBmw , I will have on my NBT the switch between orange/white?! (I wanna retrofitting the door strip led and I'm concluding the AC/radio trim pannel retrofitting)
      11-16-2018, 03:51 PM   #18
Mago304
Drives: 2015 330i
I retrofitted the door strip led, but it is not changing those colors from red to blue. It only changes the AC/Radio Trim panel. Any ideas?
      12-19-2018, 12:20 PM   #19
gizmo1908
Netherlands
Drives: F30 320i
How dit you wire door trim and ac panel? i will do this to within 2 weeks
      12-19-2018, 12:23 PM   #20
Hammer Werke
Drives: '15 328d Touring
M-sport with both colors here but I also prefer the orange.
      01-17-2020, 02:39 AM   #21
mickyle1995
Drives: bmw 4 series f32 420d
FEM
Hu-nbt
thank you youre a legend!
