05-04-2017, 11:48 PM | #67 | |
Rep 8,364
Holding power button does not always work on newer firmware. That just turns off display. |
05-05-2017, 12:11 AM | #68 |
Rep 451
Drives: 2017 X5 & 2020 X5
My sentiments as well, really at a loss as to why it won't show the updated icons.
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive |
05-05-2017, 07:45 AM | #69 | |
Rep 342
Hi. How simple is it to code? Do you have a step by step guide? Will the ID6_light UI be gone if the dealer updates the I-Level of the car in a software update/flash? Is the ID_6 light UI dependant on production date in order to be the default UI when doing a complete I-Level flashing so before 'x' month/year ID5 UI is flashed or enabled on ID5 hardware units and after 'x' month/year ID6_light UI is flashed or enabled on ID 5 hardware units? |
05-05-2017, 12:34 PM | #70 |
Rep 8,364
05-06-2017, 08:47 AM | #71 | |
Rep 36
I have fsc, coded my car, connect phone and car. Phone say carplay using. Car say carplay using. Just screen not show carplay. Also everything works perfectly. I delete 6nh and add 6ns and coding car. Carplay is gone. I make HU_NBT2:/3004/CARPLAY_SWT-> aktiv HU_NBT2:/3000/APPLE_ENHANCEMENTS->aktiv But i think i must find a few codes. Like screen show. |
05-06-2017, 11:33 AM | #72 | |
Rep 8,364
05-07-2017, 11:11 AM | #73 | |
Rep 36
Now i change 6NH to 6NS. I add 6CP for carplay? Or using carplay not added 6CP (like 6NH)? |
05-07-2017, 01:01 PM | #74 | |
Rep 8,364
Therefore, you can either VO code or FDL code and it will have the same result. |
05-07-2017, 01:09 PM | #75 | ||
Rep 36
But i asked i add 6CP and 6NS together and make fdl coding. And carplay is working? Unforgetten; i have fsc and after i use 6NH and carplay. |
05-07-2017, 01:37 PM | #76 | |
Rep 8,364
I repeat, your options are to either VO code or FDL code. |
steve@codemybimmer663.00 |
05-07-2017, 02:30 PM | #77 | ||
Rep 36
I have 6NH and not have 6CP. And i use carplay and id5 on my f30. My car has factory nbt but it is id4. We make an update and using id5 and carplay. (New fsc vs.) Now i delete 6NH and add 6NS and make fdl coding my nbt unit. And carplay is gone. I change 2 parameters on fdl and my phone + my car say carplay connected. But screen not shown carplay screen. I asked, how i fix this? My problem is thats. |
05-07-2017, 02:47 PM | #78 | |
Rep 8,364
05-07-2017, 02:51 PM | #79 | ||
Rep 36
I think it is fdl problem. Can you know? |
05-18-2017, 07:48 AM | #81 |
Rep 1,772
I changed from ID5 to ID6 lite on my 2017 340. I have CarPlay which I bought from the connected drive store.
When I changed to ID6 there is no longer the small icon on the main menu to switch to CarPlay. I can still use CarPlay but have to go into sub menus which is a bit annoying. Anyone know how I can get the CarPlay icon back on ID6? |
05-18-2017, 08:34 AM | #82 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
Back when we were playing with our converted units and it crashes or goes back to a default coding state, you'll see the menu appear like a list like on ID4 and not the horizontal tile layout.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
05-26-2017, 06:35 AM | #83 |
Rep 7
Quick Question
For an early 2017 F34 with factory ID5 on a HU NBT Evo , what would be the best way to enable carplay (6CP) The car came with Nav professional (609) and 6NH which later VO coded to 6NW (EBT) |
05-26-2017, 12:39 PM | #84 |
Rep 8,364
You need at least Nov 16 software (so an update may be in order) and then 6CP ordered for $300 through ConnectedDrive or non-OEM FSC codes for less.
06-08-2017, 08:47 PM | #85 |
BMW Aficionado
1357
Rep 1,821
Tried the same today on an NBT2 id5 unit from a 6 series GC with a 03/2016 production date ... guessing ISTEP was too old ... id6_light displayed an id4-like layout instead of the id6 lite menu i was expecting
06-08-2017, 08:55 PM | #86 |
Rep 8,364
I coded on '17 F13. ID6 only filled a 1/4-1/3 of the screen. ID6_lite displayed perfectly. Do you know I-Step?
06-14-2017, 07:55 AM | #87 |
Rep 103
Hi guys
Can you tell me if this coding update from iDrive 5 to iDrive 6 Lite (GUI only) is reversible? I would really like to try it on my F15 but i am quite worried about dealer voiding the warranty over it. I apologize if the answer seems obvious, i just want to be sure. I appreciate the help. |
06-14-2017, 08:02 AM | #88 | |
Rep 1,011
mkdan200448.00 |
