01-20-2019, 01:37 AM | #23 |
Rep 58
this is the weight differences.
Piston: 320i - 0.482 kg 328i - 0.470 kg Rear Muffler 320i - 10.500 kg 328i - 12.610 kg Automatic Transmission 320i - 78257.960 kg (prob typo and should be 78kg) 328i - 80642.460 kg (prob typo and should be 80kg) Drive Shaft Automatic 320i - 8.975 kg 328i - 12.500 kg Front Pipe & center muffler 320i - 2.290 kg + 3.600 kg 328i - 2.961 kg + 4.500 kg Intercooler 320i - 2.930 kg 328i - 4.100 kg Last edited by combivan; 12-26-2019 at 10:38 PM.. |
CandyRedRC46242.00 |
01-20-2019, 08:08 AM | #24 | |
Rep 3,680
And yah you did say heavier my bad. But I would think that's more or less synonymous with bigger... unless the 328i FMIC is denser, which I'd doubt. I have no reason to doubt because realoem doesn't really get things wrong, but I guess I'm surprised. Almost 2 years of keeping up with this subforum and this is the first I've heard of this.
01-20-2019, 08:10 AM | #25 |
Rep 159
Interesting what differences there is for transmission as they are both rated for 450 Nm and similar transmission is used even for 335i. Maybe just different torgue converter or is that separate part and has different part number?
01-23-2019, 07:27 PM | #26 |
Rep 1,067
I was also surprised with the weight difference on the transmission, I thought they were the same.
01-24-2019, 12:35 AM | #27 | |
Rep 159
http://www.realoem.com/bmw/enUS/part...&q=24008601703 For 320i http://www.realoem.com/bmw/enUS/part...&q=24008627132 For 328i So hard to say if there really is any difference between transmission. Although they do have different part numbers |
01-24-2019, 07:15 AM | #28 | |
Rep 3,680
01-25-2019, 11:49 AM | #29 | |
Rep 58
02-01-2019, 05:23 PM | #30 | |
Rep 1,637
320i - 78257.960 kg 328i - 80642.460 kg This is 80 tons |
rjd_F302000.50 CandyRedRC46242.00 |
02-01-2019, 10:26 PM | #31 |
Rep 3,680
Yah I'm not quite buying the weight difference thing.
02-07-2019, 10:21 AM | #32 |
Rep 3
Improving compression on 320i?
Hey everyone, new to the forum, not a new owner.
I have a 2016 320i with a bms stage 1 piggyback tune. It's nice, made me fall in love with the car, but my ultimate goal with it is to hit 250 hp at minimum. I noticed a lot of discussion about the differences between the 320i and 328i, which seems to be mainly the compression ratios due to the pistons. Would it be too optimistic to change pistons in my 320i to achieve a better compression ratio? I'm not too knowledgeable with this aspect of cars, so I apologize if this is a dumb question. Thanks! |
02-07-2019, 10:49 AM | #33 | |
Rep 3,680
02-07-2019, 11:16 AM | #34 | |
Rep 420
But if I were you I would: Upgrade intercooler Upgrade charge pipes Catless down pipe Install full 3" cat back Then stage 2 bm3 flash |
02-07-2019, 11:55 AM | #35 | ||
Rep 3
02-07-2019, 12:26 PM | #36 |
Rep 420
I would think that it would be very reliable, but I am in Florida with zero emissions laws and I am not sure how that would work in New York. You would probably have to hold on to your stock down pipe and reinstall it every year or so, if they have testing up there. Or if that isn't for you, you could fork out some $$$$ for a catted high flow down pipe, which may pass.
02-11-2019, 02:53 PM | #37 | |
Rep 3
04-06-2019, 08:58 PM | #38 |
Rep 20
Hey guys quick question, I've been trying to find this and no luck. I'm trying to shoot the gun and finally buy my catless DP from vrsf or that's the brand at least. It's only has the one option n20 downpipe. The 328 and 320 share the same motor but not the same piping. So my question is will this fit or will I have to change my midpipe aswell?
04-07-2019, 10:12 AM | #39 | |
Rep 3,680
04-07-2019, 04:11 PM | #40 | ||
Rep 20
04-08-2019, 02:40 PM | #42 |
Rep 20
04-08-2019, 03:58 PM | #43 |
Rep 3,680
Oh boy, don't get him started
Not to speak for him, but here's my take. Some believe in the merits of a freer flowing exhaust more than others. It is my personal opinion that there are little realizable gains to be had by widening/opening up the exhaust on these cars (other than getting rid of the cat). I think the stock exhaust flows just fine once the cat is gone. However, the aftermarket standard is bigger = better, so a bigger exhaust pipe, whether it be the mid pipe or whatever, should make more power. I don't think it would really make a difference on an engine like ours that doesn't really produce all that much exhaust by volume, but others disagree. It's a different story on bigger engines that flow more gas, those types of cars benefit from a bigger exhaust. There are reasonable arguments on both sides of the coin. There is not, however, any dyno data to back up either side lol
04-09-2019, 03:52 AM | #44 | |
Rep 159
Dyno results would be great but there are not too much results of stage 2 anyway from 320i. Actually I have not found any. But I know that some tuners claims to get 280hp out of stock 320i. I mean besides software mods. https://en.bsr.se/tuning-kits/t/3015...20-b-n20-b20-d However, I would not believe those claims nor would want to test how long engine would last if the tune really pushes that amount of power without upgraded DP and FMIC. |
